Question about Bravo Sports Barbie: Junior Skate Combo (Girls Size 6 12)
I just bought barbie adjustable inline skates from a second hand store but i don't have instructions on how to adjust them. can you help?
  • 51 Answers
Their is usually 2 plastic prongs or knobs on th bottom side where the skates connect squeeze them together and pull the skate out or upward
Posted on Jun 04, 2009
Hi Bought this TV second hand. There is no remote or instructions. Any idea where I can find both. Thank you
Most electronics stores, like BestBuy, and many drugstores like Walgreen's carry universal remotes that can be adjusted to work with almost any TV. As for instruction manuals, google the manufacturer's site. You should find the brand name on a label on the back cover of the set.
Jul 22, 2015 | Televison & Video
MAKE MY TONEARM STOP SKATING
It's possible your weight adjustment has been mis-adjusted since you last used your turntable. On the tonearm, there should be a weight adjustment wheel. Turn this all the way towards the needle (IN). Now, adjust it backwards until there is no resistance in the tone arm - this is your zero point, reset the wheel on the weight adjustment knob to read 0. Now, adjust it forward to 3 grams of downward pressure. This is usually the minimum amount of force needed on a record. If it still skates at this setting, adjust it with gradual amounts of greater force until the skating stops.
Jan 11, 2008 | Audio Players & Recorders
How do I adjust the size on the ABEC 7 Schwinn inline skates?
get the directions from their web site and follow them
Oct 13, 2014 | Cycling
I need to convert these training skates to inline skates
Buy a set of training wheels, install them on skates. Also, look in the diaper aisle for training pants. Put them on outside of your pants, so people will know your "training" thus stay out of your way.
Aug 30, 2014 | Generic Chicago Skates Boys Training...
Jvc service center
If it does this when playing a 12 inch record then it could be that the device has been set to play a 7 inch record. The skating across is either a worn stylus, wrong skate setting (if it has one) or not enough stylus pressure. To correct the pressure one. Make tiny adjustments to the weight on the end of the arm. Each time you need to test by playing a record. If it sits in the groove and doesn't skate, plus doesn't make a rumble sound, you have the pressure right. Too much pressure causes it to rumble, too little and it will leave the groove. If the weight is numbered try it at 3, then take it up to 4 + in small steps, testing it each time you move up. It's a case of trial and error to get it right.
Dec 29, 2017 | Audio Players & Recorders
My arm slides across.dont no how to adjust counter weight.
hello george!
first of all remove any needle protectors provided, there is some "weight" on the arm (at the opposite end from the needle). Release the tonearm, you have to turn the weights untill the arm is in balance, then turn 2 and a half so that the needle will go down (2.5 grams), this is the optimum pressure for the needle (pick-up), some people will tell to do more pressure on the pick-up but this will result in higher wear down. On the other hand necessarily this is needed for environments with higher vibrations like discothekes. Be careful not to allow the needle to drop onto the mat or the turntable platter during this adjustment.
The next step is to adjust (if available) the anti-skate adjustment. Set the antiskate adjustment to the same number as the needle pressure setting (i.e. 2.5 grams would be an anti-skate setting of 2.5). If you are back cueing or scratching, then set the anti-skate setting to 0.
regards
Thank you for using FixYa! A four thumbs up rating is appreciated for answering your FREE question!
Apr 12, 2011 | Pioneer Audio Players & Recorders
How do you adjust the hand brake? I can get them
The bolt that attaches the brake to the bike needs to be tightened/adjusted
Nov 23, 2009 | Dynacraft Girls 16" Barbie Bike
Technics 1210 tone arm Problem
This table should have an "anti-skate" adjustment. This is out of adjustment and putting to much tension on the arm. This adjustment is designed to insure that the needle tracks in the middle of the groove rather than one side. If the arm is out of balance and this os out of adjustment, the symptom you describe will occur. Hope this helps, Dan
Jun 08, 2009 | Technics SL-1210 Turntable
Problems with weights on turntable arm
http://www.turntableneedles.com/FAQs_ep_33.html
found instructions above.
scroll down to
"How do I adjust tracking pressure and anti skate?" under the section of "OTHER"
Feb 14, 2009 | Teac P-988 Turntable
Need Barbie B Book operating instructions
We just bought a second hand unit as well. I've just located the manual on-line:
http://www2.oregonscientific.com/assets/manuals2/GC68.pdf
Oct 13, 2008 | Mattel Barbie B Book
Bravo Sports Barbie: Junior Skate Combo (Girls Size 6 12) Logo
349 people viewed this question
Top Bravo Sports Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Bravo Sports Toy Expert? Answer questions, earn points and help others
