Question about Konica Minolta Minolta DI1610FP Multifunction 200 x 400 dpi resolution, 33.6 Kbps modem speed, scan and fax functio... Printer
Install preventive maintenance kit for Konica copier
Can I install a preventive maintenance kit in my Konica copier by myself?
    Problem Solver:
  • 15 Answers
Hi yes U can see konica minolta sit Ucan downlode users and GO
Posted on Jan 15, 2010
F 51-3 konica minolta
Posted on Apr 06, 2011
Plotter hp 4000 message maintenance #2 required
Maintenance kit 2 includes the following
This Preventive Maintenance Kit contains the following components:
?? Complete Carriage Assembly (? Page 8-53).
?? Ink Supply Tubes and Trailing Cable (? Page 8-33).
?? Scan-Axis Motor (? Page 8-59).
?? Belt Assembly (? Page 8-58).
?? Most Left Spittoons (? Page 8-43).
?? Middle Left Spittoons (? Page 8-44).
?? Scraper (located on the Service Station).
Once installed, you reset the counters, link for manual:
http://www.partsnow.com/docs/service-manuals/hp-designjet-4000-service-manual.pdf
Feb 11, 2015 | HP Office Equipment & Supplies
HOW I WILL GO IN SERVICE MODE OF A PRINTER
Clearing the Maintenance Count and Service Message: HP LaserJets servicepin.jpg
If the display panel on your HP LaserJet reads "Perform Printer Maintenance", "Perform User Maintenance", "Maintenance Kit Low", "Maintenance Kit Very Low", or anything along those lines it means your printer needs a preventative maintenance kit, which includes a fuser and various rollers. Once you have installed the maintenance kit the message will only go away if you clear the maintenance count.
Oct 31, 2014 | Ricoh Aficio SP C410DN Laser Printer
How to remove on screen preventive maintenance time m5
there is no M5 preventive maintenance only M2 and M3 please conform
May 10, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
Code sc29-03 in konica minolta 7272
CD231 at power up.
Solution:
CAUSE: Complete fax kit was not installed.
SOLUTION: These three items make up the complete fax kit, FK502, MK706 and MK704. If not installed together, the C250/C252 will display code CD231.
hope that helps
Konica Printer Support
Dec 20, 2013 | Konica Minolta Office Equipment & Supplies
Code d'erreur sc29-03 minolta di650
Sir/Mam,
When was the last time your machine had a 250,000 Preventive Maintenance kit installed. Very 250K copies/print the Developer and certain parts need replacement, the drum at 500K. The code your machine has is telling you that either the drum is bad a sensor/sensor board is bad, or the drum is old and needs replacement. Also possible the sensor needs to be cleaned. Have to remove the drum cart then the drum to get to it. Recommend a tech do it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 01, 2013 | Konica Minolta Start Up Kit for DI650...
C2801 bizhub 750
Sir/Mam,
There is a sensor that monitor the drum some times it gets cover with toner and can not do its job of monitoring the drum which it has to do before copying/printing Sometimes you may also get "please wait" same problem. Have to remove the drum assy. Two bolts and center bolt. Then pull out assy. BE CAREFUL DONT NIC THE DRUM!!!! Then you remove the drum and clean the sensor. (Two sensors the white covered one, clear one is for paper jams) When was the last time a 250,000 copy Preventive maintenance kit was installed? and Drum replaced at 500,000 developer also replaced at 250,000 copies/prints. every 250K PM kit install.
May 10, 2013 | Konica Minolta Konica 600/750 Mount Kit...
Wrench symbol on Konica 7115 means what?
PREVENTIVE MAINT. Replace drum, cleaning blade,developer etc. comes as a kit for the technicians to replace, clearing counter without doing things not good machine uses the counters to adjust voltage on certain parts and is the only way it knows new parts installed clear counter and not replace parts causes codes and image problems
Jun 25, 2012 | Minolta Office Equipment & Supplies
Maintanance kit replace
Problem:
The machine displays the Replace Maintenance Kit after the Maintenance Kit has been replaced.
Cause:
There may two causes for this issue.
  1. The machine does not recognize that the Maintenance Kit was removed. This would likely be caused by a defective Drum Maintenance Pivot Plate.
  2. The machine corrupts the CRUM on the new Maintenance Kit. This may be caused by a defective Drum Maintenance Pivot Plate or IO Board.
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix.
  1. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message does not change to "Maintenance Kit Missing," replace the Drum Maintenance Pivot Plate and install a new Maintenance Kit.
  2. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message changes to "Maintenance Kit Missing," replace the IO Board and then install a different NEW Maintenance Kit. If the problem persists, replace the Drum Maintenance Pivot Plate and install a different NEW Maintenance Kit.
ETI v1.3.20.0 610606.Replace Maintenance Kit Message after it Has Been Replaced 2007-11-18 21:37:39
Mar 30, 2008 | Xerox Phaser 8400 Laser Printer
Dirty printout and paper jams
Hi Hazel,
Sounds like it needs a maintenance kit. This will include a fuser, which should resolve the problem of the repeated horizontal lines and ghosted words. It will also cause more frequent paper jams when it needs maintenance.
A manual for installing a maintenance kit can be found online but sometimes will come with the kit. Google it anyway as it will give you an idea of the work involved.
Hope this helps!
Mar 12, 2008 | HP LaserJet 2200dn Printer
Konica Minolta 7022- How to clean- Getting Dark Lines on Copies
Beings as it is close to 100k, it is due for a PM (preventative maintenance) kit to be installed (this model has a 100k PM cycle), and also a web, corona wires, charge grid, and feed rollers (if worn) should be replaced at this point, and of course cleaned.
The drum and developer "should" last 200k (this can vary greatly).
$200 for a general cleaning on that series machine... that's entirely too much, and he will most likely tell you it's due for a PM. A competent technician would be able to install the kit, replace the above parts in under 2 hours easily.
I wish I could be of more help, but given that is almost at the end of its PM cycle, it could be anything.
Feb 12, 2008 | Konica Minolta Minolta DI1610FP...
Konica Minolta Minolta DI1610FP Multifunction 200 x 400 dpi resolution, 33.6 Kbps modem speed, scan and fax functio... Printer Logo
326 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
