Question about Vivitar 283 Flash
Is my flash safe?
My 283 has a serial # of 472****. Is there any way to tell if this is one of the post 1987 flashes safe to use on modern cameras (i.e. less than 6 volts)
    Champion:
    Scholar:
  • 216 Answers
Yes, by contacting atdlee@netzero.com
Posted on Jan 18, 2008
Please can anyone suggest which flashguns are safe to use with a Pentax K20D without frying the electronics ? I have an old Vivitar 283, and a Pentax 240 AF, but would really like one with TTL response....
I would not use and old style flash gun on modern digital cameras the voltage acroos the points will indeed fry the electrics. Have a look at the Yougnuo range of flash guns Great functionality and not too expensive
Feb 23, 2015 | Vivitar Cameras
Vivitar 283 won't fire
Since the flash is working on test, it means the connection to the camera via the hotshoe is not working. With the flash on and ready light showing that the flash has charged, take a small thin copper wire and short between the the metal spring on the side of the hotshoe (in the slot) and the round metal contact tip of the hot shoe. This should cause the flash to fire if the internal connections to the shoe are working.
If the shoe is working then it must be the camera that is not working. Many modern digital cameras cannot fire older flashes directly, because the voltages on these older flashes are too high. This could damage the camera or if the camera has protection against the high voltage, that will make it impossible to fire the flash. In that case you need an adapter. These are available cheaply. You should try borrowing a modern flash to test that your camera is still working and has not been damaged, if it is a modern electronic camera.
Nov 26, 2017 | Vivitar 283 Flash
Vivitar 283 on a digitial camera?
It depends on the variant of the 283. Take a look here.
Aug 27, 2012 | Vivitar 283 Flash
Can the Vivitar 283 be used safely on Nikon Digital SLR Cameras?
I assume you're asking about the 283, not the DF-283 which is compatible with digital cameras.
As for the 283, yes, if you put an adapter such as the Wein Safe-Sync between the camera and the flash. Under no circumstances should the flash be mounted directly on the camera.
Nov 29, 2009 | Vivitar 283 Flash
Is it compatible to use with a Nikon D-50?
No, the Vivitar 283 does not have TTL (Through The Lens metering capability) and the voltage in the flash may be much higher than that in the camera. Some of the old 283 flashes had a very high operating current that, when the flash is left one and removed from the camera can damage the camera operating circuts. Find a Nikon SB 400, 600, 800 or 900 speedlite, or a Promaster 7200 or 7500 for a great less expensive flash for this camera.
Nov 20, 2009 | Vivitar 283 Flash
Hi my name is Curtis can you tell me IF my Vivitar 283 flash will work on my c-750 Olympus, TTL camera it have an hot shoe,but flash don,t fire. I have talked to Olympus about it(on answer). I took it to a...
No the 283 is not compatible with your camera. The 283 is manual only and not TTl. The canon flash is also not compatible with your Olympus. You need an olympus compatible flash.
Nov 16, 2009 | Vivitar 283 Flash
What is the trigger voltage for a 283 bought in 1996 and is it safe to use on a nikon d80
take multimeter and see the voltage must be not more then 5 to 6 only you can check the voltage near the hot shoe or cord
Oct 24, 2009 | Vivitar 283 Flash
Vivitar 283 with new Nikon Digital camera
the nikon D80 has a 250 volts safe range and i have the same issue but readin on the internet i learned that yo can now the voltage of your flash with a voltage metter ond the hot soe.
Vivitar 283 has diferent ranges of voltages depending on the year of fabrication so older ones can achieve 300 volts and earlier have 230 volts so the best is to get a vivitar 285hv for about 75dollars or a safe sync for about 55dollars, you can find all on ebay or other brouser the safe sync converts up to 400 volts to a safe 6 volts that are yust the normal voltage for digital flashes.
Jan 06, 2009 | Vivitar 283 Flash
The s/n that i have on my disc wont work when i try to use it in the setup wizard so i can put my pics in my pc
ivitar Entries
May 29, 2008 | Vivitar Cameras
Vivatar 283 and Nikon D70s
The Vivitar 283 was manufactured in China & Japan over a number of years & the specifications did change over this period.
The older Vivitar flashes had a voltage on the shoe which could reach 150 volts whilst the later ones had voltages of only 5 to 9 volts.
If you have, or can get hold of, a small voltmeter then you can measure this voltage.
Turn on your flash & let the unit charge up to 'ready' & connect the meter between the contact in the centre of the shoe & the little contact tucked away in the lip of the shoe. (DC volts not AC) There is no danger to you in doing this!
This should tell the voltage on the shoe of your unit & if it is 15 volts or less, it will be fine with your digital Nikon camera. If more than 15 volts than best not to use it.
Hope this is of some help!
Mar 10, 2008 | Vivitar 283 Flash
Vivitar 283 Flash Logo
71 people viewed this question
Top Vivitar Cameras Experts
Tony
SHARCNET-USA
SHARCNET-USA
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
