Question about HP LaserJet 3050 All-In-One Printer
Connecting 3050 to router...
We have a desktop upstairs, the printer and router are located in the basement. I have connected the printer by ethernet to the router. Cannot print. Pls help. Thanks in advance.
1} At first configure ip to printer as per u r setup.
2) connect ur desktop to Router (it should be ping)
before doing that ur router should be configured properly Fast Eathernet port 0/0,or as respectively
3) then start u hp setup CD in u r machine.
4) it will run and detect the printer.
Posted on Dec 22, 2007
Printer is linked to my desktop as well as my laptop. Works from desktop fine. From laptop, I have to touch my desktop keyboard and it prints, otherwise status says offline (laptop) HELP !!
If you connected the desktop with a hardwire connection (ethernet cable or usb cable) and the laptop is connected wirelessly, then the Desktop needs to be "awake" for the laptop to print. What I did was connect the printer to the network with an ethernet cable to the router, either wireless router or standard. Then you have a seamless connection for both computers independent of each other.
Dec 17, 2014 | Brother MFC-5860CN InkJet Printer
Acer Laptop top connects to internet. Upstairs Desktop will not
Is the router hard wired to PC?? If not connect it with an ethernet cable.
Sep 11, 2012 | Acer Aspire 5735-6041 Notebook
I am running qwest DSL through a Linksys wrt160N that is brand new. it will work next to the router, but not upstairs or in the basement which is less than 15 meters. The upstairs bedroom is directly above...
If you have concrete floor slabs the the wireless signal from the Linksys will have a difficult time penetrating the floor slabs.
The wireless card in the computers will show a low signal strength.
Try altering the Linksys aerial to a horizontal position and also positioning the Linksys to another location.
You could be getting interference form other wireless sources, check the wireless channels of other wireless router/access points in your area. If they are broadcasting on the same channel then configure your Linksys to broadcast on an unused channel or one that has the weakest signal strength.
If none of these methods work then I would suggest you run network cables from the Linksys to upstairs and downstairs and not use the wireless connection.
If network cabling option is not an option then consider extending the wireless range with wireless repeater access points.
Nov 07, 2009 | Linksys WRT160N Wireless Router
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Desktop won't connect with printer connected to laptop
Make sure both computers can share files and can ping each other, if not, it's just a firewall issue. Try to disable your firewall first.
Oct 23, 2008 | Linksys Wireless-G WRT54G Router
Di-604 & di-524
Ethernet will travel over 2 pairs from the basement to your space that has to be less than 100 feet away. You can run it over flat cable, but not get 100 base T, but it is still going to be as fast and quicker than a wireless bridge and regeneration.
If I understand what you're trying to do, it will acutally take 3 routers or 2 and a wireless access point. The key would be to set up one router as a wireless and the other as a bridge. That gets your ethernet signal to the back of the router. Now, you need a wirelss access point or 3rd router to make it be wireless in your space.
Most modern premisies are wired with 4-pair cable. Even if they didn't make home runs from your space to the basement, there ought to be at least 2 spare pairs in the house cable. Those 2 pairs can feed ethernet to your space where you just have to plug in a router and configure it as an access point, or let it be a wireless router for that matter with or without being a DHCP server. In my wildest dreams, I can't even think of a 5 story structore being more than 150 cable feet away, well withing the 300 feet allowed for ethernet.
Let us know what you finally do.
Carl
Oct 18, 2008 | D-Link AirPlus DI-524 Wireless Router
2WIRE wireless router/DSL from AT&T
unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Sep 15, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Printing from laptop
if u installed a printer software in the laptop, be sure that the printer is connected to it...
Mar 04, 2008 | Canon PIXMA MX310 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
129 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
