Question about Xerox Phaser 7300DN Laser Printer
Color problem on half the pages
I inherited a Xerox 7300 dn.  I've tried adjusting the colors as best I can.  The problem now is that on the top half of my pages, the pictures are true to colors, but the bottom half is very red.
Any suggestions?
Thanks
    Problem Solver:
  • 11 Answers
Possible that one or more drums needs to be replaced.
Posted on Dec 06, 2007
Cannot print in color to a xerox phaser 7760 dn ps
If you print a test page from the printers control panel, does it print in color? (Like the supplies page)
Mar 24, 2014 | Xerox Phaser Office Equipment & Supplies
Xerox 7300 DN color printer, I am getting an error message "Fuser Fan Failure" reference code U32. What does this mean, How do I fix this? Do you know of any people who service printers in the...
It means you need to replace the fuser rear cooling fan the part number is 116-1024-00. New it is about 100 dollars you can find a refurbished one for 35 to 40 dollars. I am sorry i dont know anyone the the dc area that services printers.
Apr 19, 2011 | Xerox Phaser 7300DN Laser Printer
Colors do not align
Apparently, turning the unit off for 30 seconds, then back on will force the Phaser 7300 to do a color alignment procedure (according to Xerox support).
Then, if the problem persists, you are instructed to follow a very detailed troubleshooting procedure which I will leave with you in the following link:
Xerox Phaser 7300 Misregistration Issues
I hope this helps!
Nov 03, 2010 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300 color misregistration
I hope this helps!
Mar 15, 2010 | Xerox Phaser 7300DN Laser Printer
Phaser 7300 dn prints full yellow color background on every page even if the background copy shows no color.
Most likely the yellow drum unit is causing that problem. The charge roller gets worn and makes whatever color it is in print out all the time. That would require replacing the yellow imaging unit.
Feb 20, 2010 | Xerox Phaser 7300DN Laser Printer
Phaser 7300 - one color fading on diagnostics page
Are you using third party toner? That is one thing that causes that problem. Use only xerox toner.
The other thing is that your image unit could have come defected, if it was brand new. Try changing the image unit and that should fix that problem. Good luck. 016-1993-00 image unit & toner 016-1977-00
Oct 02, 2009 | Xerox Phaser 7300DN Laser Printer
Color printing problem~only green, yellow, blue
The TekColor correction options provide simulations of different color devices. Automatic is the default correction for general image processing. Use the following table to determine what option you want to use.
TekColor
Description
Automatic Applies the best color correction to each graphic element: text, artwork, and photographs Office Color sRGB Display: Approximates the colors on a computer display.
sRGB Vivid: Produces brighter, more saturated colors than sRGB Display. Press Match SWOP Press: Matches specifications for Web Offset Publications.
Euroscale: Matches Fogra glossy paper specification.
Commercial: Approximates U.S. commercial press target.
SNAP Press: Matches specifications for Newsprint Advertising Production. None Applies no color correction. Use with other color management tools, such as International Color Consortium (ICC) profiles, ColorSync, or the PANTONE Color Chart for the printer. Black & White Converts all colors to shades of gray
From the workstation, select the color correction in a supported driver.
Microsoft Windows 98 SE / ME / 2000 / XP/ Server 2003 / NT 4.x Operating Systems (OS):
NOTE: Some of the color corrections are grouped under Office Color or Press Match.
  1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed.
  2. Click on the [Properties] button located on the top, right of the window. The Properties window will be displayed.
  3. Click on the [TekColor] tab.
  4. Select the required color correction.
Apple Macintosh OS 9.x:
  2. Click on [General], and then select [TekColor] from the pull-down menu.
  3. Select the required color correction.
Apple Macintosh OS X, (version 10.2 and higher):
  2. Click on [Copies and Pages], and then select [Image Quality] from the pull-down menu.
Dec 05, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser 7300DN Laser Printer Logo
70 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
