Question about Casio EXILIM ZOOM EX-Z70 Digital Camera
I bought 2 16gb sdhc cards and cant format them in
I bought 2 16gb sdhc cards thru EBAY and cant format them in my casio camera. I updated my camera firmware from the casio website which is supposed to allow cards larger than 8 gb to be used. I notice the cards are formatted in raw format when I check their properties. I also tried the panasonic sd formatting software and it didnt work. Any suggestions?
  • 11,896 Answers
You can try to format them on your computer if you have sd drive. Otherwise I would suggest returning those ones and get something different. Sandisk is a good brand.
Posted on Jun 04, 2009
It's showing C.13.01 fault fashing and asking to Reinsert the memory stick witch is still in
would you pls try to FORMAT the memory card when it is in the camera thru your camera
MENU ?
it will correct the problem..if you cant FORMAT in the camera, take the card out and try to format it on your computer (you may need Memory Card Reader " THAT COMPATIBLE WITH YOUR MEMORY CARD.THIS IS THE EASIEST WAY TO DOWNLOAD YOUR PHOTOS/VIDEOS to PC too....As an example of this unit pls visit the URL below....you can buy it any electronic Market too...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
26-IN-1 USB 2.0 MEMORY CARD READER FOR CF/xD/SD/MS/SDHC
http://cgi.ebay.com/26-IN-1-USB-2-0-MEMORY-CARD-READER-CF-xD-SD-MS-SDHC-/290583009260?pt=PCC_Drives_Storage_Internal&hash=item43a818d7ec
Jul 13, 2011 | Cameras
When i insert my memory card into my brand new CASIO EX-55O/0 camera,a message comes up and says "card error"
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out (of which your camera was made before SDHC. You can only use 2GB or less cards). Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 16, 2011 | Casio Exilim EX-S500 Digital Camera
My screen says CARD NOT INITIALIZED. I cant get the camera to work.
Well, the error literally tells you to format the card. The format function should be in your settings menu. Before you do this, make sure that you've copied all you want off the card and then use the camera's 'format' function to reformat the card. I advise using the camera for the format function because this guarantees the correct file system. If you use your computer to format it, you may easily get the wrong one. However if you need to do it this way, see which file system is currently in use on the drive before you start. Go to "My Computer" and right click on the drive which is the memory card, and choose "Properties". Examples of filesystems are "FAT" (probably FAT16), "FAT32" and NTFS; to make sure your reformat is successful, ensure you use the same filesystem as before.
If this fails, the other possibility is that you've bought an SDHC card and fitted it to a camera that can only accept SD. In this case
you bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Jan 23, 2011 | Fuji Cameras
Hello my camera doesnt accept hp 4gb sdhc card.when i placed card in, it says card error.... Also,i cant format when sd card is in and ''card error'' on screen...(my sd cards are brand new) plese give...
Okay we have a problem, to properly answer this question "we" collectively need to know what make and model the camera is. However one clue to your problem was that you said SDHC and 4gb.
I'm going to give you a diagram on the SD card type lock make sure it's in the correct position (not locked) Also the SDHC is a newer style memory card and 4 gig is a ton of memory for point and shoot cameras.
If the card lock thing doesn't work and you still can't format then I'm going to say that your camera can't handle the memory capacity of the 4gig SDHC memory card.
Don't panic yet, you may be able to go onto the camera manufactorers web site sift through the models and find the firmware updates for your camera. Updating to new firmware editions could open the possibilities of using a larger card.
Here is the diagram hope this is all that is needed.
Diagram
Jan 05, 2011 | Cameras
Hi I bought 16GB SDHC Transcend class 10 memory card. I formatted on my computer (Windows Vista), but when I put in the camera it doesn't work, black screen. Please help me, why doesn't it work, am I...
You didn't tell us the model of your camera so it's difficult to say whether or not your camera will accept such a large card. I can tell you this, however, ....never format a card on a computer if you intend to use it in a camera. It puts the wrong operating system on the card. Always format in the camera. Try that and see if the card works.
Sep 26, 2010 | Casio EXILIM Digital Camera
Kodak easyshare M1093 refuses to format disk
The recommended card for your camera are those SDHC type or 2GB-16 GB SDHC card, try to use at least 2 SDHC card if this failed it means the memory card reader of your camera is already defective. Just in case this will happen try to contact Kodak at 1 800 235 6325 ext 12.
Feb 09, 2010 | Kodak EasyShare M1093 IS Digital Camera
Will an SDHC card work in the HP photosmart R927?
No, it won't work unless HP provides a firmware update. Hp has two websites that mention what type of sd cards are compatible with your camera. One says it is and the other says it isn't. I have a HP R967, which is similar to yours. I bought an HP sdhc card from a HP website that said both our cameras could use it. I own several of this model camera, (I bought 3 to give as gifts) and the sdhc causes the cameras to display 'wrong format.' I suggest calling HP's headquarters and asking them to provide a firmware update similar to the one that HP offered for the HP M537 camera and that Casio offered for their older cameras to let them use this type card, which is what I've been doing.
Sep 29, 2009 | HP Photosmart R927 Digital Camera
Bought a SanDisk 4GB SDHC card but camera won't accept.Should I have bought an SD memory card instead?
That camera does not support SDHC cards only SD memory cards, take the card back and i expect they will gladly swap it for you.
Regards.
Jul 09, 2009 | Nikon Coolpix 3200 Digital Camera
SDHC card won't work
Your card is an SDHC, your camera supports only SD/MMC cards. I know this because i found thisp ostlooking for a way to make it accept SDHC cards, a software update could easily work in theory but someone would have to write that update. Technology changes fast doesnt it.
Dec 22, 2008 | Kodak EasyShare Z710 Digital Camera
Open Questions:
See all Casio EXILIM ZOOM EX-Z70 Digital Camera Questions
Casio EXILIM ZOOM EX-Z70 Digital Camera Logo
161 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
