Question about HP Pavilion dv6000z Notebook
FAILURE to boot
My system can no longer boot to windows also with constant noise
  • 99 Answers
Is the constant noise a clicking noise? does it say operating system not found?
Posted on Jun 30, 2009
Tip
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 | Computers & Internet
Getting message "Disk Boot Failure Insert system disk and press enter" using window xp platform and have MCA fee antivirus software
this happens either the boot sequence have changed or your hard drive is not recognised by the BIOS
Jan 26, 2013 | Computers & Internet
Computer reboots constantly
You are probably getting a Blue Screen Of Death (BSOD,) but the PC is restarting too fast to read it.
turn it on and after the first re-start, press [F8] about 3 times every 2 seconds, (do NOT just hold it down.)
When successful, the Advanced Boot Options Menu will appear, (if it did not, then you missed it, keep trying.) Using the Arrow-up and Arrow-down keys highlight the option that says :
"Disable Automatic restart on system failure"
This will be valid for only 1 boot, then it will go back to constant looping, (unless you do the above again lol.)
When it BSODs you need to write-down the Stop Error displayed along with any file(s)-named to be causing the error.
A common one is 0x000000D1 Driver IRQ not less than or equal
This is a device driver error....see if you can boot into one of the Safe Mode options on that Advanced boot options menu. If you CAN, then use System Restore to go back to a day BEFORE the problem began. [note: if you have a virus, the problem will likely return.]
Tallon41
Sep 17, 2012 | E-Machines eMachines Desktop PC
After installing some recent windows updates, I then did a restart to the computer. The computer no longer will boot into windows. It ' boots to windows xp logo and then changes to a blue screen after...
This may help.
http://www.user-guides.co.uk/cddownload/Samsung/N120-12GBK/Samsung-N120-12GBK-Fix-Repair-NTLDR-Missing-Corrupt-or-Compressed-Boot-Disk-CD-98-XP-2000-502214.html
I have never used one as I have my own boot disc.
Feb 15, 2011 | Samsung N120-12GBK Netbook
System restore disc 1 erased & overwrote hard drive. Second disc won't start. All i get is a lengthy paragraph that boils down to : MEDIA TEST FAILURE, CHECK CABLE. PXE M0F: EXITING PXE ROM.\r\n ...
Your computer is using the network-connection to try to connect a "network boot server", to try to load a bootable image across the network.
The 'MEDIA TEST FAILURE, CHECK CABLE' is the error-message when no "network boot server" responds to a "network boot request".
The 'EXITING PXE ROM' message is the exit from the P(re) (e)X(ecution) E(nvironment) part of the R(ead) O(nly) M(emory) inside your computer, since the "network boot" did not proceed.
So, insert "Restore Disk #1" and restart your computer, and FORCE it to "boot" from the CD-ROM device -- not from the disk-drive. When prompted, insert "Restore Disk #2" to continue the reinstallation of Windows. When prompted, remove the disk from the CD-ROM device, and restart your computer.
Note that it's also possible that your disk-drive is "dying" -- any attempts to install Windows on it have FAILED. Thus, any time to "boot" from those "not-written" files will cause problems.
Dec 28, 2010 | Toshiba Satellite P205D-S8804 Laptop
Automatic restart my laptop.Windows vista
If you are able to boot the computer in safe mode, you can disable the Automatic Restart from the Control Panel.
Open Control Panel.
Click on the System and Maintenance link.
If you're viewing the Classic View of Control Panel, you won't see this link.
Click on the System link.
In the task pane on the left, click the Advanced system settings link.
Locate the Start up and Recovery area and click on the Settings button.
In the Start up and Recovery window, locate and uncheck the check box next to Automatically restart.
Click OK in the Start up and Recovery window.
Click OK in the System Properties window.
You can now close the System window.
From now on, when a problem causes a BSOD or another major error that halts the system, the PC will not automatically reboot. Rebooting manually will be necessary.
If you're unable to fully start Windows Vista due to a Blue Screen of Death error, you won't be able to disable the automatic restart on system failure option as described in the steps above.
Try the steps below:
Just before the Windows Vista splash screen shown above appears, or just before your PC automatically restarts, press the F8 key to enter Advanced Boot Options.
You should now see the Advanced Boot Options screen.
Using the arrow keys on your keyboard, highlight Disable automatic restart on system failure and press the Enter key.
After disabling the automatic restart on system failure option, Windows Vista might continue to load. Whether or not it does depends on what kind of Blue Screen of Death or other problem Windows Vista is experiencing.
Since you disabled the automatic restart on system failure, Windows Vista will no longer force a restart when it encounters a Blue Screen of Death.
Now that you have the STOP Code associated with the Blue Screen of Death, you can troubleshoot the problem:
The following is the list of BSOD error codes with troubleshooting, you can find the troubleshooting steps using the error codes in the MS website also..
http://pcsupport.about.com/od/findbyerrormessage/tp/stop_error_list.htm
Hope this helped you. Please do rate me.
Thanks!!!!
Dec 21, 2010 | Computers & Internet
I can not access my computer after imminent failure message
> imminent failure message ... cannot access
Bad luck that the 'imminent' failure was _SO_ soon followed by _complete_ failure.
Buy a new disk-drive. Disconnect the old disk-drive.
Install Windows to the new disk-drive.
Reconnect the old disk-drive, as a 'slave' disk-drive, and hope that you can access the files on it, even though you could no longer 'boot' Windows from it.
Oct 26, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Replaced battery problem continuues comp.won't come on. A quick flash of awakeness but nothing . Other times we get a sustained response thumping noise and then nothing.
Pardon for the quip on semantics, but thumping seems a bit... well... drastic. A rattle could indicate one thing and a constant/intermittent clicking (of sorts) indicates a different problem.
A kind of rattle or I suppose a 'throbbing' could indicate that your cd/dvd drive is out of balance (this would only be obvious if there were a disk in the drive and usually immediately apparent when trying to boot up), but this doesn't usually keep the computer from booting to a POST screen.
Another indication of this 'throbbing' could be that your cooling fan has lint or other debris lodged in it. This would definitley keep the computer from booting as several computers won't boot (desktops as well) unless some kind of rotation is recorded as coming off of that particular fan.
If this happens to be the case, I would recommend that the laptop be professionally cleaned as simply trying to use compressed air would just ram the debris in harder. So complete dis-assembly is the only way to get to the obstruction.
If the noise is more like a rattle (constant or intermittent) then there is a likelihood that your hard drive is about to completely fail. Again, this would be more identifiable within Windows as there is a new software alert that pops up warning you about such a failure.
Redundantly, this by itself wouldn't keep the computer from at least booting to a POST screen and possibly into some kind of error message.
The last thing I would recommend is to try powering the system up with the AC adapter alone and see if the same symptoms occur. If so, there is obviously more deeper routed issues. The worst being a catastrophic motherboard failure.
Hope this helps...
Sep 25, 2010 | HP Pavilion dv6000z Notebook
Windows live quicktime control host failures
Since the quicktime would not update properly, you probably have a bad install of it, so you'll also have a bad uninstall. Restart your computer with the Windows disk in the CD. When it asks you to press a key to boot from CD, press the space bar (or any other key). Let the files set up, then when it asks you to press "R" to repair the system, press that, and let the system do a repair from the original disk. That should fix the system.
Feb 13, 2010 | Microsoft Windows? Vista Home Premium...
HP Pavilion dv6000z Notebook Logo
173 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
