Question about Symbol PDT 3100
PDT3100 - the button that activates the laser sticks...
The button is difficult to release after it has been pressed. Should this scanner be replaced?
There was not a fix to this issue, we will continue to use scanner as is. Thanks.
Posted on Jun 08, 2009
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
I'm trying to send data from the PDT3100 to the computer but am receiving "error 96". How do I proceed?
if it is stuck in command prompt (DOS) carry out the following to get the system to reboot.
Power off the reader. Press folowing key and maintain them pressed: "Func" "Space" "M" "Power", release "Power" and release other keys. Now the system is reset.
Sep 28, 2011 | Symbol PDT 3100
How do i rest
Instructions
  1. PDT 3100 21 Key Terminal
    • 1
      Power off the PDT 3100 by pressing the "I/O" button.
    • 2
      Press and hold the "UpArrow," "4" and "Enter" buttons.
    • 3
      Press and release the "I/O" button.
    • 4
      Release the "UpArrow," "4" and "Enter" buttons. The scanner will restart.
    PDT 3100 35 Key Terminal
    • 1
      Power off the PDT 3100 by pressing the "PWR" button.
    • 2
      Press and hold the "UpArrow," "Func" and "Space" buttons.
    • 3
      Press and release the "PWR" button.
    • 4
      Release the "UpArrow," "Func" and "Space" buttons. The scanner will restart.
    PDT 3100 46 Key Terminal
    • 1
    • 2
      Press and hold the "A," "B" and "D" buttons.
    • 3
    • 4
      Release the "A," "B" and "D" buttons. The scanner will restart.
May 04, 2011 | Computers & Internet
51.2m error
This is a problem with the magenta cartridge in your printer. According to hp's website, you can try the following to fix it:
  1. Press the green (Select) button to continue.
  2. Turn the printer off, and turn it on again.
  3. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the (Select) button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
  4. If this message persists, contact an HP-authorized service or support provider.
Hope this helps
Please rate this solution, thanks!
Mar 09, 2011 | HP Color LaserJet 5500 Printer
I need to create small application doe PDT3100. Is
we have been programming these old dos units for over thirty years, you can contact me at 800.933.2839 x251
Thank you, Kim Ganoe
Mar 19, 2010 | Symbol PDT 3100
HOW TO RESTART PDT3100?
Yves
Feb 17, 2010 | Symbol PDT 3100 Portable Terminal
HP 5500 can not print with 59.CK error code on display
You probally need to contact an engineer on this one, from HP trouble shooting manual
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
1. Press the green <Tick Symbol>(Select) button to continue.
2. Turn the printer off, and then turn the printer on.
3. If the error message returns, turn the printer off.
4. Perform a cold reset.
a. Turn the printer on.
b. Watch the control panel.
c. When the memory starts counting, press and hold the green <Tick Symbol> (Select) button.
d. Continue holding the green <Tick Symbol> (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
e. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
f. Press (Down Arrow) button once. The control panel will display COLD RESET.
g. Press <Tick Symbol> (Select). The printer will perform a cold reset and then continue its power-on sequence.
5. If this message persists, contact an HP-authorized service or support provider.
Sep 22, 2009 | HP LaserJet 5500 Printer
Symbol pdt3100; scanner is stuck in scan, laser will not release
It will either be the trigger or the scanner ribbon. More likely to be the trigger.
Mar 25, 2009 | Symbol PDT 3100
I am having trouble scanning a document on the Ricoh Aficio 2018D, I also cannot locate the user manual, can you please advise how to scan on this machine?
If the scanner has not been configured, or network settings have changed, the setup for scanning on this unit is unfortunately quite difficult for a novice. the manuals are readily available at Ricoh.com, under Downloads, but this will not help very much with the scanner config.
Sorry:(
Dec 08, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Programming a PDT3100 scanner
Hi there
First I need to know if you got the software that is on existing pdt3100 on a computer? once I know the answer to this I can start to tell you how install software on pdt3100's
mant thanks
Robert
Nov 18, 2008 | Symbol PDT 3100
Symbol PDT 3100 Logo
174 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
