Question about Refrigerators
I have a GE PSS25NGNA side by side. Freezer is at 15 and fridge is at 41 (settings 37 and 0). Just started a couple of days ago. Took back panel off in freezer no frost on evaporator coil and evaporator fan is running. Please help.
  • 6,784 Answers
Ok, if the compressor is running in a good cycle and, it is not shutting off and on in a quick manner, this will confirm a temp sensor issue. You can tell if the refrigerant is low if your compressor continues to cycle on and off. if its cycle is normal(about a 3 to 5 minute running cycle), this is a good charge state and, the temp sensor should be replaced asap.
Normally, if the compressor assembly was faulty, you would get a freeze over and the evap fans would also be inoperable as well. this is just a faulty temp sensor issue. click below to order your new tempreture sensor.
The part number is
WR55X10025 and, it is located in the damper assembly.
Posted on Jun 04, 2009
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
Ge eterna series fridge side not working
Could you look inside the freezer compartment and after unplugged remove the panel to see if ice is blocking the vent to fresh food compartment. If there is ice it could be something is not working with the defrost cycle. Your refrigerator has a control board that handles these processes but other factors can cause ice buildup in vent. Thanks, Sea Breeze
Mar 26, 2009 | GE Refrigerators
Not cold enough
I opened the bottom panel at the back of the fridge and cleaned the coil because it was completely covered with dust and lints and less than an hour later the fridge side temp started going down and the freezer took five hours for the temp to start going down when we didn't open it for that much time. It's back to factory setting now and thanks for the blogs that I read that I was able to try different possibilities. Your site is very helpful.
Mar 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Side by Side is getting too cold on the fridge side.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer frozen solid freezer cool fridge not
HI look for this part in the freezer. its the most common one to fail.replace it
Oct 14, 2008 | GE GSS20IEP Side by Side Refrigerator
GE refrig model PSH23SGPABS
The main board needs to be replaced.
May 05, 2008 | GE Refrigerators
Fridge doesn't get cold enough
you have either a Defrost heater / a defrost timer/ or a defrost bi-metal that is bad. if you post your model # i can look it up and show you how to set it into defrost to see if the heaters are ok
Since you replaced the timer already that leaves two things you need to check set it into defrost if you know how and remove the panel in the back wall of the freezer you should see the heater(s) are on if not check pwr 120vac at the heaters if 0 volts the bi-metal is bad
Feb 22, 2008 | GE GSS25LGM Side by Side Refrigerator
GE Arctica fridge PSS26LRBSS - temp control blinks '0'
set to 0 for freezer, and 37 for fridge. give it 24 hours to stablize. blinking could mean it is adjusting.
Sep 09, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
145 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
