Question about Acer Aspire 4315 Notebook
Loading setup problem, take along time to start booting from  hd
  • Acer Master
  • 2,404 Answers
Put a different know working hard drive into the laptop and try loading the operating system cd onto it and it should load like normal and that will verify that the original hard drive is bad.
Posted on Jun 26, 2009
What is load setup default
So you reinstalled the operating system ? then returned to set faisafe or optimised defaults
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load
failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
otherwise it will keep booting from the cd /dvd drive
hope this helps
Oct 24, 2012 | Acer Extensa 5420-5687 Notebook
How to format my computer
You have to format a hard drive with a third party disk unless its a usb data drive
Restart your computer
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
hope it helps
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
Hope it helps
Apr 20, 2012 | Computers & Internet
How to install an os on an old pp2180
hope this helps you
Apr 18, 2012 | Computers & Internet
Windows xp start up disk doesn't work
if you are referring to the installaion disk
restart your computer during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
hope this helps you
Apr 16, 2012 | Computers & Internet
How to install windows xp in lenovo e71
hope it helps
Hope it helps
How do I reformat my harddrive using widows xp
Hope it helps you
Apr 11, 2012 | Microsoft Windows XP Home for PC
MY PROBLEM IS THAT I DONT HAVE A MOTHER FORMATE DRIVES
if you are referring to a format on your hard drive
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
Hope this helps you
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps you
Mar 29, 2012 | IBM Computers & Internet
Imedia system32 error
okay this is a confusing post/question. you can always start a machine from bio regardless of what operating system you're running. if you're attempting to boot from the disc, tap f12 @ boot until you get a one time boot menu and choose the dvd/cd drive. that should load the setup file. the windows disc does not load setup onto the hard drive. if you're running xp when you have the option hit 'r' to repair the computer, when you get into command prompt type sfc /scannow. this will search and fix all system files. you can also try chkdsk c: /r this will fix any errors in the file structure. good luck
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jan 30, 2012 | Packard Bell iMedia Computers & Internet
How to format a pc
Hope this helps you
hope this helps you
www.WipeDrive.com
Dec 06, 2011 | HEWLETT-PACKARD Computers & Internet
Hello: I have a computer running Windows XP Media Edition SP2. Several weeks ago, I started experiencing boot up problems with my computer. It stops booting in normal mode. It will boot in safe mode. When...
It looks like you installed the wrong drivers for your motherboard.  It can cause a Blue Screen Of Death.  Also how many hard-drives do you have in that computer?  IDE?  Are the jumpers set to CS?  I find that CS causes problems.  If you have 2 devices on a ribbon cable make one master w non ATA   and the second device as slave.  Also the boot.ini could be confused.  Is the boot.ini on the wrong hard-drive   Did you accidentally put 2 operating systems on the same computer?  lots of things could have caused this.
Nov 09, 2009 | Microsoft Windows XP Professional
Acer Aspire 4315 Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
