Question about Microsoft EXCEL 2004 for Mac
Vlookup in 2004 excel for mac o/s
Only get the formula to show, will not return the cell i am trying to bring over.  can't find out how to format it to show the vlookup
  • 864 Answers
First make sure there is an "=" sign at the beginning of the formula.  If there is and the formula still shows in the cell go to Preferences and click View.  Make sure the "Formulas" box under Window Options is not checked.
Posted on Jun 04, 2009
What is formula new excell
I certainly can't take the time to explain v lookup to you in this forum, but I can direct you to several sites that you can familiarize yourself with it. It's going to take you time to to understand it.
http://spreadsheets.about.com/b/2008/03/17/excel-vlookup-3.htm
http://spreadsheets.about.com/od/excelfunctions/ss/vlookup.htm
http://www.techonthenet.com/excel/formulas/vlookup.php
Jun 21, 2009 | Microsoft Computers & Internet
Dont understand how to use vlookup in excel 2007
This tutorial also helped me much to understand how vlookup works:
http://www.myhowtoos.com/en/excel-howtoos/84-how-to-match-values-in-excel-using-vlookup
Feb 18, 2009 | Microsoft Computers & Internet
How to use vlookup in openoffice using different sheets
=VLOOKUP(A2;Sheet1.$A$3:D27;2;0)
The cell I created this formula in was Sheet 3 Cell C9 - to show the different sheets
A2 is the cell I want to look up
Sheet1.A3:D27 is the range of cells that contains the data I want to return, The first column relates directly to cell C9 is Sheet 3. I locked the first cell in my range as I wanted to apply the same formula across other cells hence the $
2 is the number of the column that has the data I want to return, I had a choice in this formula of 4 columns
0 is the value to complete the formula
Feb 11, 2009 | Microsoft Excel for PC
How to use vlookup
you can a tutorial here.
please rate.
Feb 06, 2009 | Microsoft Excel for PC
VLOOKUP FORMULA PROBLEM
VLOOKUP(A1,Sheet2A2:B20,2,FALSE)
The assumption here is A1 in Sheet 1 is the cell you want to reference, This cell can be pasted - Any problems let me know.
Jan 21, 2009 | Microsoft Excel for PC
What is vlookup & hlookup?
1024x768 Normal 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} These are Excel functions for Lookup tables. The purpose of Lookup tables is to bring a value to the table, find the closest (or exact) match, and then return another value.
An example is the federal income tax table. On your tax return you get your gross income and number of dependents, go to the Lookup table, and find your taxable income.
The V in VLOOKUP means that the table is vertical; HLOOKUP has a horizontal orientation.
If you use the Insert Function button in Excel and paste either function, the dialog box will explain each required field separately with examples.
Dec 02, 2008 | Microsoft Excel for PC
HELP with macro config
Hi Hss Holdings,
The easiest way to do this is to use a formula called vlookup. You need to have the raw data some where in the workbook, but it can be a separate sheet. Put all the raw data in a table, make sure the account number is on the furthest left column, then start entering the formulas
vlookup(value_to_find, table_to_check, column_index_number, range_lookup(true/false))
value_to_find = the value you want to find on the left most column of the table
table_to_check = the table you want to find the data from
column_index_number = the column number of the data field you want to return into this cell, 1 = the left most column.
range_lookup = false for an exact match, true for the nearest match
Say the table is on sheet2 between A1 and E300
B15 is whatever you type, so no formula needed here
B12 =VLOOKUP(C1,Sheet2!A1:E300,2,FALSE)
G12 = B12 =VLOOKUP(C1,Sheet2!A1:E300,3,FALSE)
etc
Jul 12, 2008 | Excel (SS8SATAS5128400R)
Vlookup
Check if the first parameter entered is of the cell for which you are doing lookup.
I mean sometimes its possible if you want to do a lookup for say cell A2, by mistake you enter it as =vlookup(A3,........)
Jul 07, 2008 | Microsoft Excel for PC
Excell vlookup formula
Suggest you do some debugging in steps:
1. Open the 'bills up to 022908.xls'
2. Use an empty cell to "=CONCATENATE(D3,L3)". That way you can see what values are being generated.
3. Copy the values of that cell and see if you can find them in Col G of 'bills up to 022908.xls'.
Once its broken down into pieces you can usually see "the error of your ways."
Hope this helps.
Mar 09, 2008 | Microsoft Excel for PC
Excel formula of vlookup
hi there
this is i found for you ...and i hope this would give you what you are looking for..
http://www.contextures.com/xlFunctions02.html
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Feb 20, 2008 | Computers & Internet
Microsoft EXCEL 2004 for Mac Logo
254 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
