Question about Toshiba 42H81 42" Rear Projection Television
Need a sky remote code 4 new tv toshiba zv555d
Code alows me to use volume control on sky remote 4 my tv.
  • 325 Answers
Please follow the steps below:
TV
RED + SELECT
TV
0156
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Posted on Sep 17, 2009
Program toshiba remote RC_3910 to sky remote need code
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 04, 2014 | Televison & Video
NEED SKY CODE FOR AKURA APL3221W-HDID
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed see:New Remote Control Prices . To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state 'Sky rev' (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at: Sky please remember to use your back button.
Akura 0042 246, 292, 397, 065, 440
Apr 09, 2011 | Televison & Video
Hi, what is the sky remote code for Toshiba TV model 32BV500B? Thanks.
I've found two codes that work fine on a revision 8 Sky remote control and a revision 8r remote:
0056 (LG/Goldstar)
981 (General reset)
Both codes enable volume, channel selection and power on/off.
Nov 11, 2010 | Toshiba Televison & Video
Cant find right code for my sky remote for 42lh2000
I have just purchased a LG 42LH2000 Tv but can't seem to get my Sky Plus control to work the volume does anyone have a code to help
Jun 18, 2010 | LG 42LC2D 42 in. LCD HDTV
Need a code so that i can operate my LG tv. model no. 37LG5010 using my sky remote.
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Codes are 0065, or 0405,or 0037
Code are 0065, or 0405, or 0037
Code are 1293, or 1206, or 0206
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Apr 25, 2010 | LG 37LG50 37 in. LCD HDTV
Batteries changed sky + remote now does not work - TV Toshiba. Do I need a code to align my remote to my tv again?
Yes, very often after removing the batteries to replace them in a sky handset, you do need to re-code the hand set to your type of TV. Refer to your user guide for the code number for your type & model of TV.
Jul 22, 2009 | Sky ARF E- Belt CP Collective Pitch...
Technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
Jun 03, 2009 | RCA DIRECTV Satellite Remote Control
Cannot find code to program sky remote control
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0156
cheers
Little Dish Fitter
Mar 12, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Pair sky+ remote to tv
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Code: 0206
4. Point your Sky remote control at your TV and press the vol + & vol - buttons. If this turns the volume up and down as you'd expect, then the tv should be set, press Select and the remote should work
Jan 10, 2009 | LG 42LG50 42 in. LCD HDTV
My sky remote wont control the volume on my tv
Hi Re Easytouch 42" HD TV - look for Hisense - I took a guess and LCD3204 EU code 376 - remote works but buttons don't tally up - getting there slowly!
Just bought a madeforyou 4:1 remote that is programmed on my PC.
Ok - not proper solution yet but nearly there!
Dec 19, 2008 | Televison & Video
Toshiba 42H81 42" Rear Projection Television Logo
240 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
