Question about HP Compaq Motherboard
Im trying to install agp...how do i disable the on board vga
  • HP Master
  • 4,806 Answers
Hi there.
Remember that if you are swapping from on-board graphics to a card you have to go into the BIOS and tell the machine that the primary graphics adapter is AGP/PCI Express.
Plug the VGA cable into the on-board graphics port, start the computer and enter the BIOS, tell the computer to use the AGP/PCI card as primary, press F10, save the changes and exit the bios.
The computer will try and restart so let it boot to post and turn it off, then put in your card and try to boot again.
Please post back if you need more help or advice.
Good luck and thanks for choosing FixYa!!
Posted on Jun 04, 2009
    Brigadier General:
  • 10,406 Answers
First, install the AGP video, and connect your monitor to this card, and restart your computer. If the "startup" messages show on your monitor, then there is no need to disable the onboard video. Also, try restarting with an additional monitor connected to the onboard VGA port, to see if the two screens show the same information at "startup", and later, after Windows has completed its startup sequence.
Foxconn motherboard n15235 no viedio
That motherboard is either a P4M800P7MB-RS2 or a P4M800P7MB-RS2H, even thou it has N15235 stamped on the board. The board
Supports VGA display function (S3 Graphics UniChromeTM Pro IGP)
but, also has an AGP 8X slot. A slot that allows you to install a AGP 8X (AGP 3.0) card. A AGP 8x is the VGA interface specification that enabled enhanced graphics performance with bandwidth speeds up to 2.1 GB/s.
Hope that answers your question.
Mark
Apr 23, 2010 | Foxconn 6627MA-RS2H Motherboard
Im having no signal to the monitor and a vga error on the mother board try everything
It means there is problem in your VGA Card. VGA Card is Built in OR Insert in PCI Slot or AGP Slot Just change your Card
Problem will be solve . VGA Card Drivers
Mar 12, 2010 | Biostar TA790GXE AM3/AM2+/AM2 AMD 790GX...
I am installing a new saphire graphics card on an ACER M460. Dont know what slot to use. Also, the istructions tell me to remove any exsisting vga card and to disable any on board graphics capability from...
Open cpu cabinet there is PCI card slot fix your graphic card into it.
Some graphicc card is SGP card Check on motherbord you find 1 slot AGP above PCI slot fix your card into it if it is AGP.
Motherbord has normally 3 PCI slot.
AGP card is always 1.
For disable onboard graphic.
When you power up the computer press F1 or F2 or "del" key to enter in bios.
Then go to advanced and vga configuration disable vga there .Then save settings and exit.
Let me know if you need further assistance.
Nov 16, 2009 | Computers & Internet
Disable video graphics onPTGd1-LA
Every motherboard manufacturer has different ways of implementing the setting up of the display priority of the slots. If you add a PCI-E or AGP VGA card on a based board, there's no problem for the board to see your add-on card as the first display. If you add a PCI-E VGA card or a AGP/Super AGP VGA motherboard board, you will need to set up the display priority. Every board manufacturer has its own system of setting the priority up. Some of them will implement it in the BIOS, in the item "Integrated Peripheral"," Initial Display First", you can choose "PCI-E or AGP slot". However some other manufacturers implement the settings by using jumpers, if this is the case in your situation you will need to refer to your manual or contact the manufacturer for further help. The best solution is to seek help from the manufacturer of your board. Hope this might very helpful to you and good luck!
Aug 10, 2009 | Computers & Internet
No video from the board
Check the motherboard user guide for how to reset to default factory settings. If the BIOS is set to work with the on-board only and the on-board VGA is dead the motherboard is supose to detect that and switch to AGP. If is not doing that chances are not only the on-board VGA controller is gone ... the motherboard is gone too.
Try with a PCI video card.
1.Reboot with the AGP or PCI video card installed - assuming the on-board is gone but the motherborad still OK.
2. Press DELETE key
is supose to go in BIOS settings menu.
Browse and Look for on board VGA adapter ENABLE/DISABLE setting or something similar.
(My bet ? You need a new motherboard.)
Jan 12, 2009 | Intel Motherboard
Motherboard installation
Hello mecompe,
If you installed an AGP graphics card before your fist boot of the system, you will not receive display. By default the onboard graphics is set to boot display. (If this is the case, remove the AGP graphics card & boot the system). The Asus P4SGX-MX can only use a 4x AGP 1.5volt (only) card.
There is an order of sequences to perform before installing/ adding an AGP graphics card on to the board when the board also uses an integrated graphics card.
First, shut down the system & unplug the power supply from the PC. Connect your monitor to the VGA port at the rear of the board. Remove the AGP card. Re-connect the power supply & boot the system. You should have display? Re-boot the system. As the system starts up press the delete key on the keyboard every 2 seconds. The bios main menu will load. (Open your manual). Go to
section 2.4.3, page 2-20 under Advanced, PCI configuration. Set Primary VGA bios to
[AGP VGA Card]. Save the bios & exit. The system will auto restart. Press & hold the power on/ off button on the PC case until the system shuts off. Unplug the power cord from the PC. Insert the AGP card into the AGP slot. Connect your monitor to the AGP card.
Check all internal data & power cables, (Incase something came loose). Re-connect the power cord & boot the system. You should have display! Install your video software.
If your using the integrated VGA PCI graphics card, go over the bios settings page 2-18 & 2-20.
Need the Asus manual? Click this link;
http://support.asus.com/download/download.aspx?modelname=P4SGX-MX&SLanguage=en-us
To view the manual you'll also need Adobe PDF reader, click this next link for Adobe.
http://www.adobe.com/products/reader/
(The green led (light), means standby. The board is receiving 5volts DC.
If you still do not have display just let me know.
Good luck mecompe!
Mike
Oct 28, 2008 | ASUS P4SGX-MX Motherboard
How to disable onboard VGA
I believe if you install an AGP card the onboard VGA is supposed to be automatically disabled. Did you buy an AGP card?
Nov 28, 2007 | Foxconn P4M800P7MA-RS2 Motherboard
Msi motherboard
Try using the cd rom on the second cable as a master.
Let me know whats up
Nov 15, 2007 | Intel Motherboard
VGA?
connect to the VGA on board, then in bios you can change the setting for VGA, you should set it to "AGP first" or "AGP Primary" This will mean that it will look to the AGP slot first.. hope this helps
Oct 01, 2007 | Acer Aspire™ T180 PC Desktop
HP Compaq Motherboard Logo
87 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
