Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
How can I program my door opener to my 2009 impala. opener mfg in 1995. model no. is 139.53646srt1. hand remote no is 139.53879. the learn button is green not red.
  • 504 Answers
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
Posted on May 30, 2010
GT3-R -can
This is a dual frequency transmitter. (315/390) You need to select one button to program the TYPE 1 frequency of 390 MHz. Here's how:
Backwards compatable programming instructions for GT3-R dual-band remote: This is a 3 button remote, which can be used to operate up to 3 garage doors using IntelliCode radio controls. This remote is defaulted to operate the new IntelliCode 2 Genie garage door openers, but you can also program individual buttons to operate other IntelliCode 1 (pre 2011) models of Genie garage door openers made from 1998 to present. To change a button to operate a pre 2011 IntelliCode opener, the default IntelliCode 2 setting must be changed to IntelliCode 1. An LED light on the remote displays which mode the remote button is in: Red = IntelliCode 1 / Green = IntelliCode 2 To set one of the 3 buttons to be IntelliCode 1 (red), follow the instructions below:
  1. Select a button on the remote that has not been programmed.
  2. Press and hold that button for 10 seconds. Both Red and Green LEDs come on and stay on.
  3. Press the same button twice to toggle IntelliCode selection from IntelliCode 2 to IntelliCode 1.
  4. Press the same button again to confirm toggle. the LED should be Red. The IntelliCode selection for this button is set to IntelliCode 1.
You are now ready to program the remote to your garage door. Follow accompanying instructions for "Programming to IntelliCode 1 Genie garage door opener," or see below instructions: Programming Instructions: Gently press the Receiver Learn Code button on the power head receiver of your Genie garage door opener (motor head on ceiling in garage). This small, black, unmarked button is located behind the light lens at the motor head and is nearest the floppy 6 inch antenna wire that protrudes from the motor head. When pressed, a radio signal indicator light will start blinking red for 30 seconds. After pressing the Learn Code Button, press your transmitter button twice for your system to grab the frequency and code it in. (Keep the transmitter you're tuning at least 2 feet away from the power head while tuning.) Press the transmitter button once more to test the system and start your door moving.
Jan 06, 2012 | Video Game Consoles & Games
I really need your help. My Craftsman unit model number is 139.53615SR manufactured 1/92. I have a three car garage. The original two remote controls were lost and since then I've used the setting in my...
Have your neighbor bring over his remote and open or close your door with it. Then hold the smart/learn button in for 6 seconds on your opener. Then see if he can open your door. He shouldn't be able to because that procedure erases the memory in your opener. No remotes should work. You need to get that remote #53778 back and program it and then see if your neighbor can open your door. If he can open your door at any point after you have held that button in for 6 seconds you need to get a new door opener.
Oct 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to program consel garage remote opener on 2003 impala
Press and hold the 2 outer buttons on the homelink until the light goes out or flashes rapidly. Then hold the button down on the remote and the button on the homelink you want to operate the door. Then if your opener has a colored learn button, press the colored learn button on the opener head and then press the homelink button up to 5 times depending on the brand. If it has dip switches ship this step. Your homelink should be programmed.
Sep 13, 2010 | 2003 Chevrolet Impala
I have model 139.53671 SRT gagrage door opener
If that is the right remote for the opener you need to locate the smart/learn button which is on the rear of your opener near where all those white wires go. Hold the button down on the remote and then press and immediately release the smart/learn button. It should now be programmed.
Jan 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Re-program Chamberlain garage door openere.
Try programming your opener this way. Locate the smart/learn button which is just to the left of all those white wires. Press and hold the button on your remote while you press and immediately release the smart/learn button. Do this for each remote. Do not hold the smart/learn button in as it will erase the memory and your remotes will not work.
Sep 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can not program both keypad & remote to operate at the same time
One of your units has reverted from "rolling code" to "billion code" and as you have found they will each work but will not work with each other. The problem is finding out which unit reverted. The most common one is the hand remote but that could be wrong.
Aug 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
HomeLink works in vehicle... unable to program hand held or remot
When did your remote and keypad quit working? Was it when you programmed the Homelink? It sure sounds like you have a bad logic board.
Jul 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do u program garage door opener for chevy impala 2003
YOU WILL NEED TO REPROGAM "ALL" YOUR REMOTES AND CONTROLS AGAIN USING THE GARAGE DOOR OPENER BUTTONS ON THE GARAGE MOTOR .....
HAVE ALL YOUR REMOTEA YOU NEED TO PROGRAM IN HAND FOR QUICK OROGRAMMING.....
Dec 30, 2008 | 2002 Chevrolet Impala
Craftman garge door opener changing code on key pad
having all the remotes you want programed with you, find learn button on back of opener. hold button until little light goes out- no remote will work now, with each remote Press learn button once,Press big button on remote-light bulb on opener will blink on/off if bulb is working-do this each hand held-keyless is same way, put you 4 #'s in HOLD enter button-light bulb blinks on/off you have 15 sec. for each time you hit the learn button. also best to start off with new 9 volt battery before you start programing
Aug 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
224 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
