Question about Honda Garden
Need specs.for Honda rototiller motor
Specs.for Honda FG100 rototiller motor.Have tiller motor apart now need valve settings,and timing gear to cam instruction.
    Sniper:
  • 60 Answers
Hello
The valve clearance is 0.08 for intake valve and 0.11 for exhaust valve . To do the timing you have to remove the spark plug and set the piston at top dead center (all the way up) and on the cam pulley you have a mark (like a triangle) that you have to align with the fan cover bolt hole . Hope this help
Posted on Aug 29, 2009
The cam to crankshaft.... the plastic gear has a dot that you can see. mark the tooth with a sharpie so you can see it visible. its a cicle on the cam gear. on the crankshaft the cylinder needs to be at top dead center so when you put it back in all the way to the top. on the gear there is a notch that you line up the tooth on the cam to the two on the crankshaft. Its easier if you take the flywheel off to put it together. Hope I made sense
Posted on Aug 30, 2009
Honda FG garden tiller 110, stoped running, took it apart, the timing belt loose, what do I need to fix it?
model was launched 1998
replace the timing belt sounds logical
take photos of how the crank and valve cam cogs line up before replacing the timing belt
Honda FG110 ROTOTILLER USA VIN FAAA 1000001 TO FAAA 1199999 Parts Diagrams
Jun 22, 2016 | Honda Garden
How much grease to put in gear box on a honed fg100
If it is heavy grease and not a 90 weight or better gear oil, you can pack it full. Use solvent and pressure to get all the old stuff out.
Oct 06, 2013 | Honda 25cc 4-cycle Mini Tiller
How to line up cam to crank
line up the timing marks on the crank gear to the cam gear
Feb 13, 2013 | Honda FG100 Border Edger Attachment
Motor runs but the tines want turn
Either the clutch is gone or the transmission gear is stripped. These need to be properly greased annually so that this happens less. The transmission replacement can be done but the dealer will charge you about what you paid for it ($250) or if you know someone handy they can order the parts here: http://www.planopower.com/store/honda/fg100.shtml and rebuild it for you. It would cost about $85 for a full transmission rebuild.
Good luck.
BW
Jun 19, 2010 | Honda 25cc 4-cycle Mini Tiller
Have this rototiller without a manual and need to know about fuel
the mixture is usually on the machine somewhere--if not go the honda website and look up info for that model
May 08, 2010 | Honda 25cc 4-cycle Mini Tiller
I need a worm wheel for a Honda minitiller FG100.
You can buy parts for this from www.petessmallengine.com
I had to replace the tine shaft w/worm wheel assy. This is usually the weak point in the transmission. The worm is made out of brass.
Jan 03, 2010 | Honda 25cc 4-cycle Mini Tiller
Honda FG100 Tiller - Tines wont move
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
May 02, 2009 | Honda Hmantis Mantis Garden Tiller with...
I am looking for fender for honda fg100 rototiller?
If It is a Honda FG100 like in the title the part number is 65141-V06-003
If it is a FG110 like in the description the part number will be 63411-V25-000 FENDER, RR. and 65141-V25-000 FENDER, FR.
Nov 24, 2008 | Honda Hmantis Mantis Garden Tiller with...
Garden Logo
713 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
