Question about Boatmates products are the final word in...
2004 MERCRUISER 4.3L EFI NEED # EXHAUST BOOT ONE PC MANIFOLD RAN HOT ON STARBOARD SIDE TUBE N/G
  • 600 Answers
Google search for mercruiser spares, there are severel in the USA and in Ontario Ideal Supply carry them,
Posted on Jun 08, 2010
How can I get my choke to open
The tube you're looking at is called a "heat riser". Warm air from off the exhaust manifold will rise in the tube, and warm the carb. If your choke doesn't gradually open with that, then most likely, it's stuck or the temperature coil is broken. Check that the choke can be easily moved with your fingers. .. Lubricate as needed.
Nov 02, 2014 | Cars & Trucks
2004 mazda tribute idles high and manifold glows red hot after only 20 minutes after running
When you say manifold, I assume you mean the exhaust manifold. If its the one you can see (there is an exhaust manifold on the back of the engine also for the rear 3 cylinders) its a clogged or fried catalytic converter. There are a couple of catalytic converter cleaners on the market you can try, but most likely it will need to be replaced. Was there another problem recently i.e. bad coil pack etc?
Feb 24, 2013 | 2004 Mazda Tribute
It leaks water into the passenger side floor
YOUR A/C DRAIN TUBE IS CLOGGED YOU WILL NEED TO LOOK FOR IT AND WITH A BLOW GUN AND COMPRESSED AIR BLOW BACK INTO IT TO PUSH DEBRIS FROM IT FOR WATER DRAIN. THE DRAIN TUBE IS LOCATED ON THE OUTSIDE OF THE FIREWALL IT WILL BE CLOSE TO THE EXHAUST MANIFOLD. UNDER THE A/C EVAPORATOR CORE HOUSING.
Aug 27, 2011 | 2004 Lincoln Town Car
2004 ford escape exhaust manifold torque specs?
Fig. Left side exhaust manifold bolt torque sequence-3.0L engine
Fig. Right side exhaust manifold bolt torque sequence-3.0L engine
Both cases, exhaust manifold and new gasket, torque the bolts to 15 ft. lbs. (20 Nm).
Good luck (remember to rate this answer).
Oct 22, 2010 | 2004 Ford Escape
Freeze plug location on 1998 gm 4,3L
Welcome to FIxYa.com
under neath exhaust manifold on block
Regards, Lee Davidian
Thank you for using FixYa,com.
Oct 21, 2010 | Oldsmobile Bravada Cars & Trucks
Replace exhaust maifold gasket on 2.0 liter, 140
Hi
Locate the exhaust manifold, there will be 8 bolts attaching it to the engine block. Remove these bolts, they may need penetrating fluid to loosen them. Slide the manifold off the exhaust studs.
Remove the gaskets, scrub where they have been with a wire brush and refit new ones. Use some gasket sealant to affix them and replace the manifold. Start at the middle studs and work outwards in a criss-cross formation.
Torque up the studs to the correct settings (check the manual) and don't overdo it as you could crack the cylinder head (been there done that).
Start the motor and check for any leaks around the manifold, if so, check gaskets again for a good seal then try again.
Hope this helps and please vote for me :)
Jul 12, 2010 | Boating
How to change an exhaust manifold leak 7.5L
Right-Hand
Removal
  1. Remove spark plug heat shield (12A406).
  1. Remove distributor to spark plug wires (12286) using Spark Plug Wire Remover T74P-6666-A.
    1. Disconnect muffler inlet pipe.
    1. If equipped with secondary air injection, disconnect the secondary air injection check valve tube (9B480).
    1. Remove attaching bolts and right exhaust manifold (9430).
    1. Inspect joint faces for signs fo exhaust leaks, cracks or any defect that would make exhaust manifold unfit for use
Left-Hand Removal
1. Remove oil level indicator tube (6754).
  1. Remove spark plug heat shield.
  1. Remove distributor to spark plug wires using Spark Plug Wire Remover T74P-6666-A.
  1. Disconnect EGR valve to exhaust manifold tube (9D477). If equipped with air injection, disconnect the secondary air injection check valve tube.
  1. Remove attaching bolts and exhaust manifold (9431).
  1. Inspect joint faces for signs of exhaust leaks, cracks or any defect that would make the exhaust manifold unfit for use.
Installation
  1. Clean mating surfaces of right exhaust manifold or left exhaust manifold and cylinder head (6049). Clean mounting flange of right exhaust manifold or left exhaust manifold and inlet pipe(s). Clean mounting surface for air injection tube or right exhaust manifold. Apply light film of Premium Long-Life Grease XG-1-C or -K or equivalent meeting Ford specification ESA-M1C75-B to right exhaust manifold or left exhaust manifold.
  1. Position right exhaust manifold or left exhaust manifold on cylinder head. Install attaching bolts and washers, starting at fourth bolt hole from front of each right exhaust manifold or left exhaust manifold. Tighten bolts to 34-47 Nm (25-35 lb-ft), working from center right to both ends.
    1. Position inlet pipes to right exhaust manifold or left exhaust manifold. Install attaching nuts and tighten to 34-47 Nm (25-35 lb-ft).
    1. Position the secondary air injection check valve tube and the secondary air injection tube gasket (9C435) at rear of right-hand exhaust manifold. Install attaching bolts and tighten to 19-25 Nm (14-18 lb-ft).
    1. Attach the secondary air injection manifold tube (9B449) to left-hand exhaust manifold fitting (located under EGR tube). Tighten nut to 30-40 Nm (22-30 lb-ft).
    1. Attach the secondary air injection check valve tube to rear of right-hand cylinder head. Tighten bolts to 75-85 Nm (56-62 lb-ft).
      1. Connect EGR valve to exhaust manifold tube to left exhaust manifold, if removed. Tighten nut to 53-72 Nm (39-53 lb-ft).
      1. Install spark plug heat shield and distributor to spark plug wires.
      1. Install oil level indicator tube to left exhaust manifold, if removed. Tighten nut to 13-24 Nm (10-18 lb-ft).
      2. Start engine (6007) and check for exhaust leaks.
Hope this helps you...WF †
Mar 10, 2010 | 1996 Ford F250 Crew Cab
Need head bolt, intake manifold, and exhaust torque specs
Cylinder Head Bolt Step1- (25 FT.Lbs) Step2(45 Ft.Lbs) Step3(65Ft,Lbs).....Intake Manifold(35Ft Lbs)....Exhaust Manifold Center (20Ft Lbs) All Others (20 Ftlbs).....Thanks
Mar 06, 2010 | GMC Suburban Cars & Trucks
Have a 2004 3.0 MerCruiser -have winterized( drained block & exhaust) but don't see where you add anti-freeze as unit will be outside to Spring-live in Michigan.Thanks
You do not need to add antifreeze. If it has 2 blue hoses on the right side of engine then pull those and point down towards the bilge. If it does not have that then pull the plug on the right side of block. Pull the plug out of the bottom of the exhaust manifold. Loosen the hose clamp on the water pump and pull the hose off. Put the hose clamp and the 2 plugs into a ziplock bag and ziptie them to the steering wheel so you dont loose them. That is all that you need to do. You should also use Sta-Bil to stabilize the fuel in the fuel tank. Then you are done!
Sep 28, 2009 | Boating
Boatmates products are the final word in... Logo
397 people viewed this question
Top Boatmates GPS Experts
Are you a Boatmates GPS Expert? Answer questions, earn points and help others
