Question about HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350
Constant check paper light..
I switch to more expensive paper thinking it would fix the problem seems like it goes then paper gets stuck half way with various clicking sounds, then when i cancel print it comes smoothly. any one had or has this problem thanks for the help
  • 167 Answers
Try cleaning your printer and its rubber rollers. Also make sure there is no object stuck inside the printer that prevents the printer from loading the paper smoothly. may be you have no other problem.
Posted on Oct 27, 2007
How do i fix my printer which says door open ?
Open the door to check if the paper is not stucked inside or anything, it might be that the door pin might be broken so is not well closed. perhaps you can uninstall and re-install it once again from control panel of your computer if its linked..if not just switch it off and on after some ten min...I hope that helps
Sep 14, 2015 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
Nov 03, 2009 | HP PSC 1350 All-In-One Thermal Printer
Ink cartridges stuck after replacement
HP PSC 1350.
Very sensitive printer. Due to dust, the catrdges are getting stuck at right side. Please clean the steel roller where the catridges are rested. Clean it with nice cloth and if possible put 3-in-1 oil in that area only for the smooth flow of catridges in that steel stem or roller.
This might happen iif we are not installing the orignal and genuine catridges and there is a chance of ink gettng leaked onto the printer.
Kind advise is if the printer is old, please put an annual maintenace service contract with local authorized hp Printer Dealer which will solve your problem once for all.
have a nice and good working day.
Jul 16, 2009 | HP PSC 1350 All-In-One Thermal Printer
HP 1350 Says theres a paper jam and won't clear. All lights on.
Try unplugging the printer from power, (Turned off of course) Wait 5 minutes, plug the printer back in. Now open the case like you're going to clear a paper jam, or change ink cartridges. Close the case. Press the Power On button of the printer.
Jun 05, 2009 | HP PSC 1350 All-In-One Thermal Printer
Paper Jam HP 1350 All-In-One
The back of the HP psc 1350 DOES open! I got a 4x6 photo paper stuck too. After finding no help in the HP software manual, I accidently noticed that if you look closely at the back that grey area that looks like it should come off does! If you look closely you will see an arrow to the left of the gray panel. You can push right and pull toward you at the same time and the panel comes off where you can easily take out the stuck photo paper.
Nov 06, 2008 | HP PSC 1350 All-In-One Thermal Printer
Hp psc 1350 -check cartridge
Power off switch for a 5 minute .
It doesn't work try to reinstall the printer driver
Or check whether the printer cartridge is fit well in the printer
May 16, 2008 | HP PSC 1350v All-In-One InkJet Printer
Problem with HP PSC 1350 All-In-One InkJet Printer
All of the lights flash and it wont print or do anything else. The ink cartriges are new I replaced them right before it happened can you please help?
Feb 04, 2008 | HP PSC 1350v All-In-One InkJet Printer
Turnon printer ,cardridges run fast back and forth on shaft hitting case
The paper may be unclean or the paper rollers. Another cause is the paper out sensor is damaged. In all cases you need to clean the printer, paper rollers, and the paper try.
Don't for get to check if something is stuck. somewhere.
Oct 20, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350 All-In-One Thermal Printer Logo
128 people viewed this question
Ben Johnson
