Question about Regent Medical Regent& Painter's Halogen Work Light
Outdoor halogen light does not shut off
I have a dusk to dawn outdoor light that does not shut off automatically at dawn as it did originally. is there a reset button to resolve this or should i do something else
    Problem Solver:
  • 18 Answers
Some can be reset by removing power for a few minutes.
It would help to have the owners manual for the particular light because I have had some that went into different modes of operation by turning the switch off and on a prescribed amount of times
hope this helps
Posted on Jun 08, 2009
I want to replace my existing single bulb porch light with a 2 bulb motion activated light. It would be operated with the existing switch. Is this ok to do?
Yes. Must keep switch turned ON.
Outdoor lights will only come on when motion is detected, otherwise light bulb does not come on. So the indoor wall switch does not work as override since the motion sensor takes over as the sole switch.
Copy following link for wiring illustrations:
http://waterheatertimer.org/How-to-wire-occupancy-switch.html#motion
Other solutions include adding separate motion sensor light nearby and keep porch light so you can turn on-off when desired.
Another option is to add photocell to outdoor light so it turns on automatically at dusk.
Another option is to use outdoor yard timer with dawn-dusk capability:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Another option is to replace indoor wall switch with with dawn-dusk timer, that can also be used as ordinary on-off switch so you can turn porch light on-off when desired. Timer such as Intermatic ST01C offers simple 2-wire connection.:
http://waterheatertimer.org/ST01C-program.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 18, 2013 | Electrical Supplies
How do I set the timer for a GE relocatable power tap EMP700UL-PC?
1) Copy following links:
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
http://waterheatertimer.org/GE-timers-and-manuals.html#outdoor
2) Timer turns ON automatically at dusk.
Push button to select duration of ON time.
d is probably dawn, so dawn-dusk
Maybe A is always ON, and maybe F always OFF.
1-9 will be number of hours timer remains ON, for example ON at dusk and OFF 9 hours later.
Dec 02, 2012 | GE Home
Can I use outdoor timer indoors.Its a dusk to dawn timer but no lights will be on
If outdoor timer is programmable, and does not turn ON automatically at dusk, then timer can be used indoors.
If outdoor timer is activated by photo eye, and turns ON automatically at dusk, then it cannot be used indoors, because the timer turns ON when it senses darkness.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#HB51
Jul 29, 2011 | Intermatic Outdoor Timer/Photo Control...
Woods vacation villa 2 room tent manual needed..Please help
Woods 83660 security timer appears to be same/similar as Coleman 2001/Woods 49647
Instructions: Timer turns ON automatically at dusk
Use dial to set 4 possible options:
Off = always OFF; ON - always ON
Dusk-Dawn = ON at dusk, OFF at dawn
2,4,6,8 hours = ON at dusk, lights OFF 2,4,6,8 hours later
Woods Model 2001-49647 manual
Jul 10, 2011 | Woods INDUSTRIES 83660 OUTDOOR SECURITY...
How do you set the timer
You posted under Woods outdoor timer:
See this timer and other similar types to identify your timer for sure
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
If this is not your timer, look at other timers on the page and then add a comment, and I will post instructions for another timer.
Generally this type of timer each set the same way:
Instructions:
Timer tuns ON automatically at dusk
Set dial to Off , the timer is always OFF
Set dial to ON, the timer is always ON
Set dial to Dusk-Dawn, the timer is ON at dusk, OFF at dawn
Set dial to 2,4,6,8 hours, the timer is ON at dusk, lights OFF 2,4,6,8 hours later
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
Dec 23, 2010 | Woods Outdoor Lighting Timer
Outdoor lights timer: Intermatic HB851 photo timer with dial. How do I set it for dusk ON then off in 8 hrs.
Intermatic make HB51 timer.
If this is not your timer, then add a comment.
To set for ON at dusk, and off 8 hours later, rotate dial to the number 8.
Timer turns on automatically at dusk.
Timer set to 8 hours will start countdown when timer turns ON > and 8 hours later timer will turn off.
Make sure timer is turned away from lights so photo-eye doesn't receive feedback.
Feedback is when the photo eye gets too much light, and then timer thinks it's dawn, so lights turn off, and a moment later photo eye thinks it's dusk again and lights turn on again.
Feedback from lights will cause timer to reset the 8 hour countdown.
A car pulling in the driveway can cause feedback.
If the timer resets because of feedback, it begins the 8 hour countdown again, so the lights will not turn off until dawn.
You can test timer by putting black tape over photo eye, and then timer will turn on.
Set timer for 2 hours for example and then check if timer turned off 2 hours later.
If timer is not functioning correctly, then timer is defective.
Dec 18, 2010 | Woods Outdoor Lighting Timer
How do I set timer
manual for HB51RC
http://www.intermatic.com/%7E/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
See timer at Amazon
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk + override lets timer run during daylight hours
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Rotate selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
Dec 14, 2010 | Intermatic Outdoor Timer/Photo Control...
I baught a 3-outlet timer yardstake #15137. why does it blink on all settings except the on at all times?
Your yardstake timer has photo-eye that automatically turns lights on at dusk.
And then lights remain ON until set-time expires, or dawn arrives.
Timer automatically turns off at dawn, no matter which setting, unless timer dial set to ON
Photo-eye has to be turned away from outdoor lights or lights will blink.
That's because outdoor lights cause photo=eye to sense it's dawn, and timer turns OFF >>> a moment later photo-eye senses it's dark, and turns lights ON again.
Thus the timer turns ON-OFF.
Test this by putting black tape over photo-eye, or turning timer toward dark area. Timer should turn ON and follow set-time on dial.
Dec 11, 2010 | GE Hardware & Accessories
How do I set it and can I use it indoors?
I see nothing in the manual that says 'outdoor use only' EXCEPT timer runs on photoelectric eye.
Timer turns ON automatically at dusk, so if timer is inside, and indoor lights are ON, then timer stays OFF.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb51rc%20-%20english.ashx
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb51rc.aspx
To use timer outdoors.
Plug timer into wall.
Timer turns ON automaically at Dusk.
Rotate dial to set how long timer will stay ON.
Set timer to turn OFF 2 4 6 8 Hours after dusk
Set timer to turn off at dawn
Set timer to ON so lights are ON full time
Set timer to OFF so lights are off full time.
Dec 09, 2010 | Intermatic Outdoor Timer/Photo Control...
How to program a intermatic outdoor timer/photo control hb51rc
1. Turn dial selector to the "off" position and
plug timer into three conductor outdoor outlet.
2. Turn dial selector to timing interval
desired (i.e., 2 Hrs, 4 Hrs, 6 Hrs, 8 Hrs,
dusk to dawn, etc.).
3. Plug outdoor lights into Easy-Set™ Timer -
lights will turn on automatically at dusk.
4. Lights turn off 2 4 6 or 8 hours later
depending on dial selection
Dec 07, 2010 | Intermatic Outdoor Timer/Photo Control...
Regent Medical Regent& Painter's Halogen Work Light  Logo
482 people viewed this question
Top Regent Medical Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Regent Medical Electrical Supply Expert? Answer questions, earn points and help others
