Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Replace light in freezer
Were is the light in the freezer?
  • Monkeylad Apr 12, 2008
    Same problem, how do you fix it?
  • 868 Answers
The light is behind a panel that usually has a 1/4 inch screw holding the cover over it.You may have to remove items in front of it to see it.Generally its towards the top section
Posted on May 29, 2008
How do I fix the freezer light in my Whirlpool side-by-side/freezer on bottom fridge?
first make sure the light bulb works for sure. then most likely it is the door switch. easy to replace. pull out, disconnect and replace. while you are at it, touch the two wires together and make sure the light goes on so you know it is the switch.
Aug 09, 2015 | Whirlpool Refrigerators
How do I replace my freezer light
An owners manual I found online says:
Freezer
  1. Pinch rear tabs on light cover and pull straight down.
  2. Remove light bulb.
  3. Replace bulb with appliance bulb no greater than 40 watts.
  4. Insert front tabs of light cover into freezer liner and snap rear portion over light assembly until rear tabs engage.
The manual illustrates the bulb is behind a plastic grille right by the temperature control knob.
Aug 05, 2014 | Amana ARB1917CSR Bottom Freezer...
Skandiluxe freezer seals
Hi
Most freezer lights are screw on bulbs. Unscrew the bulb unticlockwise and replace with a new one.
Feb 15, 2014 | Freezers
How to replace the light bulb in the Maytag french door bottom freezer
Hopefully you have figured this out. Its fairly simple to do. If your freezer if full you will need to empty enough that you can place your hand in and on the Plastic Light cover. Its in the center at the top of the freezer. This cover is removed by simply applying a little pressure to the right and left corner and pulling toward you and down. The light cover with very little pressure should mover and pull down. Once it begins to lower in the back just keep a hold of it and mover your hand toward the rear of the freezer and the front tabs will slide out.
After changing the light bulb, simply put the front two tabs of the front of the cover in first and snap back into place by pushing up. Takes about 3 minutes to change the light bulb. Good Luck!
Dec 24, 2012 | Maytag MFD2560HES Bottom Freezer French...
My freezer is not working. The light on the front is not on. Does this mean that either the switch with light is not working or the power cord is not working?
check first the convenience outlet or the main breaker reset if trip off or replace together the cord test it the continuity using ohmmeter also check the over load protector of the compressor replace if busted. also check the bulb if busted replace it.
Feb 23, 2011 | GE 7 cu. ft. Chest Freezer FCM7DR
I can't find where to replace the light bulb in my
Light dispenser Number: WR02X10675
http://www.repairclinic.com/Appliance-Parts?s=t-WR02X10675-%3d%3d
3$ good luck
Jan 03, 2010 | GE Hotpoint Top-Freezer Refrigerator
Ice builds up in freezer, and vibration noise only when freezer is closed. When freezer open vibration noise stops. starts when pressing the switch which turns off the light.
Replace the fan motor AND blade . ( evaporator fan motor ) . This motor is located inside the freezer , behind the rear panel . The switch , is a fan/light switch , when closed , turns on fan , and light off . When open , light on , and fan off . normal operation .
Oct 07, 2009 | Amana Refrigerators
Indicator lights out
Check the power to the lights and replace if burned.
You also can check the door switch.
 It may be stuck or broken.
Feb 18, 2008 | Freezers
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
50 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
