Question about Kodak Advantix 3100 AF APS Point and Shoot Camera
Have a kodak advantix f220 never got much use. cant find manual. put in new batteries and film aps200 . button will not depress. timer symbol showing in exp.left window. film used to roll on automatically when you pressed button after loading if memory serves me right. Do i need to replace a seperate flash battery if so where is it? asy solutions or suggestions
SOURCE: kodak easyshare cx 6330
Easy Share CX6330 zoom button came off and is lost. Where to get a new button and can I put it on/
Thanks
PF
Posted on Feb 09, 2008
  • 44 Answers
SOURCE: Stuck remaining exposure count despite new film, new film unlded
You might try closing the film compartment without film in it and press the manual rewind button. This might reset the counter circuit.
Posted on Dec 12, 2008
RattMur
  • 53 Answers
SOURCE: Kodak Z812 shuts off automatically
It is a high-powered camera, also knows as a GREAT camera. Use CRV-3 lithium duracell batteries. I have the same camera and the same "problem", but when I use that battery it lasts forever.
Posted on Jan 16, 2009
SOURCE: red flashing light on battery indicator on the loading dock.
My Z760 does the same thing. When that happens I run the battery completely down by taking pictures until it shuts down. Then when I put it on the dock it charges properly. Don't leave your camera on the dock all the time and don't try to always keep the battery fully charged--instead it will develop memory and think it needs to be fully charged to run and will give you a low battery signal earlier than it should. Wait until you actually get a low battery signal before charging and it should help, but mine will still give me the red light sometimes. Then I run the battery out like I said before. I hope this information helps. :-)
Posted on May 27, 2009
SOURCE: kodak easyshare md41 will not charge battery while
Can the kodak md41 be charged by a laptop through a USB cable?
Posted on Apr 19, 2010
I have an old Nikon Lite Touch Zoom 100 AF camera and I am having trouble loading the film. Can you use Kodak Advantix APS film in this camera or should I be using manual loading film instead?
This camera uses 35mm film, not APS film. 35mm is a larger format, giving MUCH better results, at the expense of having to manually pull the leader across to the take-up spool each time you load a roll.
Dec 29, 2010 | Nikon Lite Touch Zoom 120 ED/QD 35mm Point...
Film is stuck in kodak advantix tried a new battery and nothing happens - camera doee nothing
APS cameras are very rarely seen these days because the film loading and advance mechanism was poorly designed and engineered from the start.
Your fault is very common and given that the camera will be irreparable anyway (no spares, plus the small problem that the camera was never designed to be repaired anyway) then you need to decide whether to just chuck it away or whether to break open the camera in total darkness and manually rewind the film back into the cassette for developing.
May 12, 2010 | Nikon N75 35mm SLR Camera
E is flashing all the time when on?? can not open camera to remove film. Camera is locked--battery is new.
The flashing E means that the film has no more exposures left. When this occurs the film is usually automatically rewound into the cassette and the loading door can then be opened.
In your case, the film has not fully rewound and so the door remains locked. A fresh battery usually cures it but has not done so in your case. You can try using a pointed object such as a pen or pencil to press the manual rewind button on top of the camera (below the "select" and "enter" buttons on the top plate) but if that fails then you will need to break open the camera in total darkness to remove and rewind the film.
Breaking the camera seems drastic, but if the camera is broken then it's effectively irreparable anyway. APS cameras were a very badly engineered system and there are very few which are still working these days as the film transport mechanism was simply awful. There were various other problems with them as well, so many don't work for other reasons.
After you recover your film you can either replace the camera with another one (APS film is an almost dead format though) or switch to a conventional 35mm film camera which has better image quality as well due to the larger negatives. Either way, there is absolutely no need to actually pay for one; there are millions of them sitting unused in people's drawers and cupboards and you can either wait for one to be offered on your local FreeCycle/Freegle groups or request one. Note that a rule of these groups is that your first posting MUST be to make an offer, but you're free to respond to offers for items offered by other members.
You might want to consult this online resource from Kodak regarding your camera for further information about it.
Please take a moment to rate my answer.
Mar 13, 2010 | Kodak Advantix C650 Zoom APS Point and...
Cannon ELPH LT
The ELPH LT takes APS film, like the Kodak Advantix.
Mar 08, 2009 | Canon Elph LT 260 APS Point and Shoot...
Dont take any pictures
Change the batteries and try again.
Feb 12, 2009 | Kodak Advantix F620 Zoom APS Point and...
Film wont rewind
nadyne,
manual rewind is next to lcd panel right side. hold the button down for 3sec. the re-wind symbol will be displayed on the lcd panel.while holding down the re-wind button depress the shutter button. film will re-wind.
Dec 15, 2008 | Pentax IQZoom 928 35mm Point and Shoot...
Dec 08, 2008 | Kodak Advantix 2100 Auto APS Point and...
Problems with camera display on kodak APS (something or other......)
I am having exactly the same problem (I have a T550). On the last film I shot, the only way to advance the film was to pull the battery out and re-insert it every time. When I printed that film, all the frames are blank! Kodak's FAQ about "clearing the logic" suggests a solution for that problem. 1. Turn camera off 2. Pull battery out 3. Turn camera on 4. Click the shutter approximately 6 times 5. Turn camer off 6. Repeat step 4 7. Reinstall battery I just tried that but the problem persists. I am now going to leave the battery out for several hours; maybe this will help. Otherwise, well it is time to bite the bullet and buy a digital !
Jun 21, 2007 | Kodak Advantix T550 Auto Focus APS Point...
Kodak Advantix 3100 AF APS Point and Shoot Camera Logo
119 people viewed this question
Top Kodak Photography Experts
Michael Galve
Michael Galve
Bill Eager
micky dee
Are you a Kodak Photography Expert? Answer questions, earn points and help others
