Question about Sony Handycam DCR-TRV22E Mini DV Digital Camcorder
A/V to DV out does not seem to work
I want to stream video from external VCR through the handycam to my computer.
The DV link works ok because I can capture no problem by playing a handycam tape and capture to the computer.
But when I setup to stream through the handycam to the computer there is no video at all.
NB: I have also tried to use the Handycam as a VCR (recorder) with A/V via the supplied cable, but that also does not work.  So I guess the problem is with the A/V input to the CAM or the settings in the menu.
I am using a NTSC/PAL capable SONY SLV-X825 VCR machine which plays OK to a TV so that is working ok.
My A/V cable is OK because I can play from the CAM to the TV.
The issue is getting the CAM to recieve Video over the A/V cable??
Getting deperate :(
Hope someone can help.
Thanks
    Master:
  • 619 Answers
Try to install video editing software to capture picture from handy cam.
Posted on Jan 10, 2008
Sony Handycam DCR-HC40 Mini DV Digital Camcorder. How do I copy tape to a PC?
I'm happy to assist you with the information to transfer the videos the computer. Refer the URL to
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C353938&fes=true
NOTE: USB streaming not supported for Windows Vista and Windows 7. Instead use i.LINK cable to transfer he videos.
Dec 23, 2010 | Sony Handycam DCR-HC40 Mini DV Digital...
The lcd screen not working
The screen is defective or the cable that connects the screen with the board seems to be loose soldering it may resolve the issue.
May 12, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
SONY CAMCORDER DCR-TRV19 DOESN'T WORK ON WINDOWS
The Windows 7 Operating System is not compatible with the USB Streaming feature of the Camcorder.
You can transfer the videos to the Windows 7 Computer using an i.LINK (Firewire) Cable.
You can use the Windows Movie Maker Software to transfer the videos from the Camcorder.
Please follow the steps mentioned in the below link to transfer the videos from the Camcorder to the Computer
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
Mar 10, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
Can not locate the driver for the sonyL15a digital handycam dv
General Information:
I understand that you're trying to transfer the videos from the Camcorder to the Computer using the USB Cable.
The USB Streaming of this Camcorder is not compatible with the Vista and Windows 7 Operating Systems.
However, you can transfer the videos to the Computer using the i.LINK(Firewire) cable or A/V Cable.
Feb 07, 2010 | Sony Handycam DCR-HC21 Mini DV Digital...
I want to take video from handycam and put on my mac
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Good Luck!!!!!!!!!!!!
Sep 26, 2009 | Sony Handycam DCR-TRV22E Mini DV Digital...
Driver for DCR-HC28
It's not possible to transfer the videos from the Camcorder to the Vista running Computer using a USB connection.
The Camcorder uses the USB STREAMING function to transfer the videos to the Computer. The Vista doesn't support the USB STREAMING function.
However, you may transfer the videos from the Camcorder to the Computer using an i.LINK/FIREWIRE cable.
If your Computer has an i.LINK/FIREWIRE port on it you can connect the Camcorder to the Computer using the i.LINK/FIREWIRE cable.
The i.LINK port is a D shaped port labelled as DV, i, IEEE1394, Firewire.
If the i.LINK port on the Computer has 4 pins on it, then you can use a 4-pin to 4-pin i.LINK cable.
If the i.LINK port on the Computer has 6 pins on it, then you can use a 4-pin to 6-pin i.LINK cable.
The i.LINK port on the Sony Camcorder is a 4-pin i.LINK port.
I will forward a link to a page where you can get the steps to transfer the videos from the Camcorder to the Computer using the i.LINK connection.
Jun 15, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
Video transfer
If you're using a Windows Vista Operating System it'snot possible to transfer the videos from the Camcorder to the Computer using the USB connection. The videos from the tape camcorders cannot be transferred to Windows Vista Operating System as there is no USB Streaming ooption available on the Windows Vista Operating System. The Camcorder uses the USB Streaming function to transfer the videos to the Computer. You may wish to purchase a i.LINK/Firewire cable to connect the Camcorder to the Computer in order to transfer the videos from the Camcorder to the Computer.
or
There is an update for driver on the Sony website to transfer the videos from the Camcorder to the Computer using the USB cable.
http://support.sony-europe.com/dime/downloads/downloads.aspx?site=odw_en_GB&m=DCR-HC42E&f=usbdrven_vista
You may also try installing the driver update for the Camcorder. The i.LINK cable gives a better video transfer qulaity than the USB transfer. The i.LINK cable used to connect the Camcorder to the computer depends on the number of pins available on the i.LINK/FIREWIRE port on the Computer. The i.LINK port on the Computer is a D shaped port which is labelled as i, DV, IEEE1394 and Firewire.
Jun 07, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
My computer is not able to detect my handycam
Please go to camera menu > settings and enable USB stream option so Windows will detect / recognize your camcorder.
Let me know if this not works to help you out.
Please intimate what Windows you are running in your PC?
Feb 14, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Cannot transfer my video data to computer?
Go to camera menu and enable USB Stream. problem will be solved.
Apr 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony Handycam dcr-trv19e
sir, i need driver software for transver my handycam to pc. my handy is sony dcr trv19e
Nov 27, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-TRV22E Mini DV Digital Camcorder Logo
148 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
