Question about Cycling
For lubricants use
I have bajaj 125cc discover and i am using castrol power one lubricant and now i want to know that is castrol power one racing 4t or castrol active x-tra 4t is suitable for my bike or not and please give me your advice that which engine oil i have to use which increase avreage of my bike.
  • 200 Answers
Castrol actevo is the BEST product for your Bike...good luck to you friend...Tim
Posted on Jun 06, 2009
Choke cable freezing what to use
Hi, Anonymous you need to remove and lubricate it and I am sorry you can't find the first and best tool you ever bought for your Bajaj but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
How to free Mikuni bs29 Carb Stuck Choke Enricher Plunger
CV40 How to adjust auto enricher
Harley Davidson Choke Cable Replacement How To Video
Bajaj Discover 100M 2014 service manual DOWNLOAD FREE FULLMANUALS COM
Top results matching Bajaj Discover service manual Scribd
Feb 01, 2014 | Bajaj Discover DTS-I Motorcycles
What is the best engine lubricants to use
The lubricants recommended by the manufacturer are the best to use.
Sep 17, 2013 | 2011 Bajaj Discover 100
Recently i purchased Discover 125cc bike ,nowadays i am facing problem while starting.If i am taking it out after two days ,then i need to kickstart it .It needs atleast 20 to 25 attempts.Recently i
Hi, Essar and the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery nearly discharged, should have 12.5 volts.
4. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.*
8. Intake air leak.
9. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.*
10. Enricher valve inoperative.*
11. Engine lubricant to heavy (winter operation).
12. Ignition is not functioning properly (possible sensor failure).
13. Faulty ignition coil.
14. Valves sticking.
* Carbureted models.
Nov 14, 2012 | Bajaj Discover DTS-I Motorcycles
What oil should i use in my dirt bike it's a 2005 kawasaki 125cc 4 stroke,and how much oil shouls i put in it I took all the old out
Just use an ordinary 4T motor oil, 15W/40 will be okay. Your oil capacity is 800ml but you could pour the 1 liter, before putting the lubricant clean the oil filter and drain plug.
Hope that helps you out!
Jun 30, 2011 | kawasaki KLX 125 Motorcycles
How much bajaj discover 125cc engine oil capacity
Hi, Anonymous I am sorry you can't find the first and best tool you ever bought for your Bajaj but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
Bajaj Chetak Oil Change Detailed
How to change your oil on Bajaj Chetak
Bajaj chetak scooter
Aug 03, 2010 | Bajaj Discover DTS-I Motorcycles
What oil is suitable for chain lubrication?
A good brand of chain oil is Castrol Chain Lube. Its super sticky and wont fly off all over the place.
Mar 27, 2010 | 2007 Bajaj Discover DTS-I
Oil for yz 125
yes that will work BUT,i have a 03 660 raptor and all i use and recommend is yamahlube.
Apr 26, 2009 | 2003 Yamaha YZ 125
Which oil to use?
Go for it. Castrol is a top brand oil.
Please rate this solution. Thanks!
Apr 12, 2009 | 2004 Husqvarna TC 450
Pulsar 150
Dear Pravin,
Always check for the oil level before you start for the first time during the day. If you can just shake the bike you'll know how thick or light the oil is. The more lighter, you'll have to change faster. Also check for color. Oil can be maroon/red/dark green/etc. depending on brand. If its really black, change it fast. Dont do top ups. Better drain the entire oil and fill fresh oil.
The oil also acts as a lubricant to the gearbox. If you feel gear shifting is becoming too slippery or too tough, check for the viscousity, as said earlier. Slipping gear shift can also be due to a loose chain. So check for that too.
By the time you finish 1500 kms or 2000kms, its better to change the oil.
It is better to use Castrol Power1 for Pulsar. It prevents overheating and also keeps the engine and gearbox smooth. It also maintains viscousity at high temperatures for better lubrication.
My experience:
I used to put servo and every 900-1000 kms i had to change oil. Now with Castrol, I change only between 1500-2000kms. I'm getting mileage between 50 and 55kms for a litre of unleaded petrol.
Hope this helps in solving your problem.
Have a nice time riding pulsar.
Always wear helmet and drive safely.
Jan 16, 2009 | 2007 Bajaj Pulsar 150
Chain lubricant
Most are spray mate but I have used chainsaw oil in the past its very good easy to clean off if it flings and I just used to put it on the chain with an old paint brush.,,,
Nov 10, 2008 | 2002 TM Racing E 250 4t
Cycling Logo
106 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
