Question about Maytag Dependable Care LAT9706
Maytag LAT8650BAW won't drain
The washer does not spin nor drain. I have had this washer about 15 years and it has only had a few minor repairs. I've made all of the repairs myself- based on info from others like whomever may be reading this. I know that opening the washer and replacing parts is easy, so I am eager for a diagnosis.
Thanks
Mark
  • 1294 Answers
SOURCE: Maytag washer will not spin
If your washer does everything but does not spin, it is your outlet filter which is blocked. Locate this and clean out, it has to work fine. Refer user's manual.
Posted on Jun 05, 2007
Lumpy816
  • 246 Answers
SOURCE: ensignia maytag washer noise
The bearings on Maytag Ensignia's are part of the seals that keep the water in. Once you start hearing the bearings begining to go, you likely will have a leak following shortly thereafter as the bearing greased is washed out by your laundry soap. Up front. This is a procedure that requires specialty tools and takes me about 45-60 minutes to complete. The easiest way to tackel this job is to take your model number (just on the back side of the console) and take it to a local appliance parts store. Ask them for a tub seal kit. (I can't give you a part number since there is no model number listed) but they should be able to pull it up for you. When they bring it up to the front, inside the seal kit is not only step-by-step directions, but also the part numbers for the specialized tools required as well. If you opt to go the repairman route, I'll forewarn you, the company I worked for charged around 250-300 for the repair on this. Send me back a message if you have any troubles or other questions.
Posted on Jul 01, 2008
  • 1028 Answers
SOURCE: washer not spinning or draining
$300/hr??? i thought sears/ae was high..remove front or back pump is located more toward rear and may be easier to acess..front comes off by removing the door hinge screws and screws on opposite side roll vertical sides out and front will drop forwaed and lift off at bottom pump may just be plugged if all else fails cancel maytag and call sears or a&e
Posted on Jul 17, 2008
  • 4 Answers
SOURCE: maytag atlantis will agitate won't spin
I had the same problem with my Atlantis a couple of months ago. It turned out to be the bearing for the tub drive pulley. When you look under the washer there are three pulleys. The one for the motor is ont he left, the drain pulley on the right and the big one in the middle for the tub. What I found is that when the bearing went bad, the tub would fill and turn for washing, but it would not turn at all for spinning. I could turn the pulley by hand but the tub refused to budge. I removed the main pulley and could see that the bearing had exploded. You can't buy just the bearing but the whole pulley kit is like $35 so I got off easy. I put the machine back together (which is tricky) but it works fine now. The pulley kit comes with complete instructions but it's really straightforward. The tricky part is that you have to pull down on the end of the drive shaft in order to get the retainer ring onto the pulley. That can be difficult if you don't have a lot of room to work or have a partner to assist. You can replace the whole thing or just the bearing and save the pulley for a rainy day if you want. I opted for the whole replacement. But I saved the old. cause ya neva know!
Posted on Jan 16, 2009
SOURCE: The washer is not draining
THERE'S A PUMP UNDERNEATH CIT GETS CLOGGED ALL THE TIME ( COINS AND OTHER THINGS WILL BE THERE ) . REMOVE AND CLEAN IT WILL BE FINE AFTER .
Posted on Jan 15, 2010
MAYTAG NEPTUNE WON'T SPIN OR DRAIN
If it can't drain, it shouldn't spin. Pump blocked? Broken pump? Level sensor broken?
Sep 05, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune MAH5500BWW front loader didn't drain after a wash cycle. first time wife put it on spin for a few minutes and it drained, no problem. A week later that didn't work, code...
Yes you need a new control board. The fact that the motor and impeller was damaged and loosened. You should try taking your Washer in for maintenance check or call the repair man.
Jun 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
Should I buy a gently used Maytag dependable care plus model# LAT8824AAE washer? What's the reliability of this machine?
Maytag makes very dependable machines. They are fairly easy to repair and parts are easy to find. If I was in the market for a used washer, a Maytag would be my first choice. Since its used there is no guaranty that the thing isn't going to need repairs. If you can see it run through a cycle before buying it would be a plus. My first washer was a mid seventies model Maytag. I had two minor repairs twice in 15 years and its been working ever since at my buddy's. I hope this helps you.
Aug 27, 2009 | Maytag LAT3600A Top Load Washer
Washer does not spin. Motor runs, tub drains, it
Probably some minor annoyance that you can easily remedy. On these machines if you overload it with a rug or comforter OR you run it with lots of clothes and low water setting then that old drive coupling will break. It is easy to fix. Take a look at these repair PIX
Aug 21, 2009 | Maytag Washing Machines
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
Aug 10, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
71 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
