Question about Craftsman Garden
Transmission is locked up in 2nd gear ...how do i repair the problem...i do work on mowers but i have never worked on the transaxle on a craftsman rider...model # 502.255090 ...serial # 29207245 .... if you can send me a diagram of the rearend/transmission i can go from there ... thank you kenneth berry
  • 83 Answers
SOURCE: OPERATING INSTRUCTIONS FOR SOVEREIGN/MOUNTFIELD COMPACT RIDER LAW
I see that is a British machine. I've looked everywhere and it seem they do not have operator's manuals online. Your best bet is call the manufacture in England. It seem they don't have any American distributors. The number is 0-845-600-3207. The 0 is the country code and you'll need to dial it. If you get an operator they can help. I've never called England so good luck.
Posted on Mar 31, 2009
  • 6 Answers
SOURCE: Craftsman Transmission problem
Some of these tractors have a friction wheel that is driven off of a flat wheel on the bottom of the engine drive shaft. The rubber ring on this friction wheel could be worn out, or it could be out of adjustment.
Posted on Apr 22, 2009
SOURCE: I just got a used murray riding mower model #30544X92A
Go to Murray.com and they have their manuals and parts list. If you don't see your model E-Mail them your model and ask for the info. I did this with my older model Murray and the next day they E-mailed me back with the manual and parts list..
Posted on Apr 27, 2009
  • 246 Answers
SOURCE: mower wont stay running
Hello nater357:
>>From your Description it Sounds like a Bad Carburetor Solenoid, Restricted Carburetor Passages or a Stuck Carburetor Float Needle Valve.
>>The Following is a Basic Instruction File I made for Checking the Carburetor Solenoid. Any Input is Appreciated.
>>**Check for Current/Voltage (10.5 VDC Minimum) to the Carburetor Shut Off Solenoid. If the Carburetor Shut Off Solenoid has Current, then On Some Solenoids you can Remove the Needle and Replace the Solenoid to Test them.
>>****PLEASE DO NOT OPERATE THE MOWER WITH THE SOLENOID BYPASSED IN THIS MANNER. THIS IS "ONLY" FOR TESTING.****
>>For Others, Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 1/2" to 3/4" Long for the Horizontal Mount Solenoids and 1/4" to 1/2" Long for the Vertical Mount Solenoids. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid.
>>***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES***
>>Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jet Properly.** **Use 440 Wet Dry Sand Paper and Engine Oil to Clean the Pin. Wet the Sand Paper with Oil Until it is Flexible and then Lightly Polish the Pin. There is Some Slop/Free Play in the Solenoid Pin. Usually the Electromagnet is Simply Not Pulling the Pin as it Should or there is a Small Bur on the Pin. Use 440 Wet Dry Sand Paper and Engine Oil to Clean the Pin. Wet the Sand Paper with Oil Until it is Flexible and then Lightly Polish the Pin. Clean and Lightly Oil the Pin before Inserting it Back into the Solenoid. Just a Film of Oil is All it Takes.**
>>If the Carburetor Solenoid is Good, then
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
  • 130 Answers
SOURCE: change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
Posted on Jul 22, 2009
Heal lever won't press down to engage transmission on hydrostatic transmission
Hydrostatic Drive Problems?? - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
May 30, 2006 - Hydro-Gear Transaxle:218-3010L I got this tractor as part of the deal when I ... After spraying the heck out of it and pressing the brake pedal down several ... I pull on the handle in the back and it moves the lever but still won't move. ..... while in the air and turning the wheels with the transmission engaged? mtd lawn tractor wont pull hills
Oct 18, 2009
briggs trouble
Jul 5, 2008
Peerless transaxle repair, Husqvarna mower
Oct 13, 2006
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Missing: heal
HYDROSTATIC TRANSMISSIONS - Small Engine Information
smallengineinformation.com/?page_id=370
Jan 14, 2016 | Garden
Will a toro rear end work on a craftsman 42 in?
I'am not sure,but a Craftsman tractor has a Peerless Transaxle,model # LTH2000. You didn't say,if the tractor you have is a manual transmission or a transaxle type.I will say this,that at Craftsman,they usually have their own brand of transmissions. Another brand might not be adaptable. I know this answer,may not be what your looking for.There is so many,ways a transmission can be installed on the different,brand of tractors. I would call Sears,and ask them,if a Toro would adapt,to a Craftsman tractor,you might get lucky. Sincerely,Brad Locke 11/23/15
Jun 26, 2015 | Craftsman Garden
How do you add pump oil and transaxle oil to transmission on craftsman mower 917.289140?
These are sealed transaxles and normally don't need oil added. There is a vent cap where oil can be added but this is normally done when the transaxles are being repair while removed from the mower.
Feb 04, 2015 | Craftsman Garden
Hydrostatic transmission is slipping
This is a serious problem. If you are a serious repair person,you may be able to make a proper repair on a Hydrostatic Transaxle. I have seen this transaxle(Peerless Model, dissembled. There are gears,bearings and a whole lot small parts to a transaxle. I wouldn't want to take on,this task. Call Sears, for a repair appointment or get in touch with another professional repair shop. The problem,you have could be a simple,Adjustment or a major overhaul repair. I would not attempt,to give you any advice on how to make the correct repair. It will require,a repair manual. I know this may not answer,your question. But this is what i would do. Sincerely,Brad Locke
Feb 24, 2014 | Sears Craftsman 46 in Tractor Mulch Blade
I have a Sears riding mower model #917.255460 that the hydrostat transmission and wheels have locked up. Any thoughts how to fix.
I have answered,this similar question,and have given advice,what i would do. If you are a just a week end doer, i would not attempt to try to make your own repairs. This Hydrostatic Transaxle,is quite a complicated piece,You will need a profession,service technician to work on this. It has so many bearings,gears and a lot of small parts. This sound like,a gear is slipping,when the tractor is put in gear and under a load. It could be as simple as servicing,the Transaxle. I have seen this problem,when the Transaxle had air trapped in it. Your Owner's Manual,explains what to do,if there is air in the transaxle. You have to move the tractor about five in both directions. This usually,takes care of the problem. This occurs,sometimes after servicing the Transaxle. There is something thing you can do,check,for leaks of oil around the axles and or,at the Transaxle it self. It could be low on transmission oil. If this is the case,you will need to replace the seals. Unless,you know what your doing,i wouldn't attempt to dissemble the Transaxle assembly. Instead,call Sears for a repair service or call any lawn mower shop,that does this kind of repair.Sincerely,Brad Locke
Feb 15, 2014 | Sears Garden
How do I add oil to my sears garden tractors transaxle model no. 917.273320
I'am not sure about this model. Craftsman,usually services the Transaxle at the factory. Requiring no further servicing,unless you have a leak developing,then an overhaul of the transaxle has to be made.I would get a professional in a mower shop,to make this repair. Or Sears does this sort of work. I have seen this Transaxle,(A Peerless Transaxle),torn down for repairs. There is more small parts to this transaxle,then anyone other than a Sears Tech or someone trained to do this. Its more work,than a weekend doer can possible do. Hope this is answers your question,Brad Locke DTD. 12/03/15
Aug 06, 2013 | Sears Garden
Need repair manual for craftsman model number
I don't know of an available repair manual, but you can get a parts diagram by going here... http://www.searspartsdirect.com/partsdirect/index.action Enter your model number, then scroll down to Subcomponents, and click on Transaxle.
Jun 30, 2009 | Craftsman Garden
Apr 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
123 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
