Question about Cisco 7940 IP Phone
Doesn't answer calls or answers with speaker only
Either I pick up and the phone will not connect the call, or when I pick up, it delays for a second or two, and then connects with the speaker phone. Since I work in a busy office, I don't like using my speakerphone with many other people around. My phone is a Cisco IP Phone 7941 series.
  • 48 Answers
This is happening because your "Self-Cleaning" hookswitch is going bad. Since it's a carbon contact design, this will happen more and more frequently. I recommend sending your Cisco IP phones to IdacomUSA for repair and refurbishment. If you are the DIY type of person, we are also selling the pad and assembly for the Cisco hookswitch at $15 each (w/minimum order)
Posted on Jun 17, 2009
If I get this AT&T 1739 answering machine will it retreive messages when I am on the phone with someone else, also can I record my own message on it for my business
Without call waiting or a second line, callers will get a busy signal if you're already on a call. This happens at the switchboard; it doesn't matter what type of answering machine you have because the second call doesn't get that far.
You can record your own message on the 1739 but, as mentioned above, if you're already on a call then the second call never gets that far.
Mar 08, 2012 | AT&T ATT1739 Digital Answering Machine
Answer call problems
take the phone to a mobile store and have it checked
Mar 17, 2009 | AT&T Blackberry Curve 8300 Smartphone
How do you set the number of rings on a brother 560 fax machine
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Nov 26, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Set number of rings before answer machine pick up
From the main menu select the Voice Mail option in Voice mail select Ring Delay in Ring Delay you can choose the delay time before Answering Machine pick up the phone from 0 to 30 secend.Reza from Iran
Oct 01, 2008 | Siemens Gigaset S455 Cordless Phone
No dial tone
This is the time that love cannot help with. Buy yourself a new home phone where the massages will pile up. erase all massages on your mobile phone. It is time to buy a cell phone which will record all masseges that you've received.
Sep 23, 2008 | Siemens Gigaset S455 Cordless Phone
How to receive faxes automatically
First this is a good machine, I use the same one and have my fax setup for the same thing. If you have a (TAD) Telephone Answering Device first you have to set up your phone to pick up before the fax, do this by setting the phone to pick up on three rings and the fax to pick up on four. Go to Menu/Fax/Setup Receive/Ring Delay. While there make sure Easy Receive is on. The machine itself will distinguish between regular calls and facsimiles and will display this info at the time of the call on its LCD screen, make sure you are using the line connection and not the phone connection. Hope this helped.
Jul 01, 2008 | Brother MultiFunction Center MFC-440CN...
Number of rings before answering system goes on
You can adjust the Answer Delay time by going to Menu then DTAD. Adjust the Answer Delay under this menu... 6 seconds per one ring.
If you have auto attendant set up to answer for you in a multiline system, set that delay accordingly. That will be the first system to pick up, You should set up one auto attendant for every voice line coming into your phones.
Dec 18, 2007 | Lands Phones
Tapping the answer button does not answer the phone
I had the same issue until I realized that I was touching the button twice,- first answering the incoming call, then immediately hanging up!
When you first tap the button there is a slight delay and the incoming call seems to be still ringing but you've really already "answered" it. Just tap once, be patient a couple of seconds and say"Hello". Your caller will be there!
Dec 12, 2007 | Motorola Mobility H500 Wireless Headset
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Ring Tone Won't Stop
I had this problem with my old phone, it was a Samsung Sch-950 I recently upgraded my phone and new phone doesn't do it so I don't have an answer other than to get a new phone.
Oct 26, 2007 | Motorola Mobility H350 Wireless Headset
Open Questions:
See all Cisco 7940 IP Phone Questions
Cisco 7940 IP Phone Logo
1,454 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
