Question about M&S Systems Audio Players & Recorders
HAVE A M&S SYSTEM AND FUSES MC902 BLOWN - M&S Systems Audio Players & Recorders
My intercom keep on clicking...and on the display as its clicking, number keep changing without anyone touching it?
Posted on Aug 21, 2009
My ford kuga has no electrics and will not start nor does the central locking system work !! Have you any idea why?
First check the battery voltage with a multi meter the voltage should be around 12.53 v if it is lower then 12v the cars Bsi unit wont wake as the Canbus electronic system is power hungry.
If the Battery voltage is correct then check the main fuses under the engine compartment and then check the interior fuses for a possible blown fuse. As the main system function are not working then the cause will most certainly be a blown higher amp fuse 30 amp / 60 amp which protects the starting and charging circuits.
Sep 05, 2015 | 2011 Ford Kuga 2.0
Fuse
Fuses don't fail often in your life time & have nothing to do with a no start, unless you have a system with issues
If you find any blown fuses, replacing it won't fix a thing, that
cause it to blow.
Go to a repair shop & discuss the problem your having
Jun 19, 2013 | 1992 Toyota Corolla
My 2008 grand vitara interior hood light got short circuit & now the radio,door lights,remote lock system not working.
fuses that look good can be bad, due to
tiny cracks, use a meter to check the fuse.
or buy a fuse checker of flush with cash.
any DMM can measure any fuse.
the fuse in the passenger compartment , near driver left knee.
LHD car.
you can use a volt meter too, to check a blown fuse
keyon, both sides of fuses read 12v.
if not, the fuse is blow, or is blowing over and over due to the dead short in that line. that is it purpose to prevent a fire.
Apr 11, 2013 | 2008 Suzuki Grand Vitara
Blown fuse on JBL amp
Are they inside. I ask because I just looked at pictures of the JBL GTO504 and there are only 2 fuses on the outside of the case. They are standard car type fuses with the current rating printed on them, looks like 20 Amp. You can just pull them out and replace them but you really need to find out why 1 has blown before replacing it.
Amp Pics Here.
May 11, 2012 | JBL GTO504 Car Amp
How can i tell if my amp is blown
check your amps fuses if they are blown thats your problem also check the fuse underneath the hood from the cable going to the amp if that fuse is blown fix it. that will turn ur amp back on. also if your blue remote wire is loose it will not tell the amp to turn on. thats how u can tell. if all fuses are intack. and blue wire is then its blown
Mar 19, 2011 | Car Audio & Video
Amplifier do not have sound. E-mail: rigo11us@yahoo.com
You may have blown the inline fuses for output sound. Amps have alot of fuses under the hood. take the amp cover off and check all fuses are not blown / wire broke inside fuse. Some fuses are hidden under circuit boards on some amps, check everywhere possible to check all fuses. If all fuses are fine and no broken wires inside them, you may have loose connection where your speaker wire ports are inside the amp. Check they arent black or loose. if they black they are blown as there usually soldered (a silver colour)
Mar 02, 2011 | Yamaha AX-596 Amplifier
JBL Eon 15 Blown Fuse
These fuses are most likely 3 Amp fuses. Please note that if the replacements blow as well, that there is a problem within the amp section that will require repair.
Dan
Aug 14, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Ashdown Perfect 10 Bass Combo keep blowng 2 man fuses
What main fuses? Fuses in the car electrical system? If so, your amp is too powerful to run through the cars electrical system, you should get a heavy guage wore ran straight from the battery, with its own dedicated fuse placed in-line, ad close to the battery as possible. Wait, is this a bass guitar combo??? Open it up, if there's wax coming from the power supply, thats prolly the culprit. Check for any obviously blown resistors or any short circuits. But most likely, its not gonna be user-servicable.
Feb 28, 2008 | Ashdown Perfect 10 Bass Combo Amp Car...
Full sound not working
I had the same problem and also traced it back to two of the four 7-amp fuses were blown. I replaced the fuses, but they immediately blew again. I used higher capacity fuses (10 amp) to see how bad the problem was and those blew. Testing the problem a third time with the speakers disconnected yielded the same results.
There's an internal short in the system.
The solution? Don't buy RCA again.
Nov 12, 2007 | RCA RS2656 Shelf System
581 people viewed this question
Top M&S Systems Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Tre Elkins
Are you a M&S Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
