Question about Motorola Mobility RAZR V3
I have a RAZ V3a it says I can add a mini sd card but where does
I don't see a slot for the card and the book doesn't show it either
  • 1 more comment
  • Judy Dennis Jun 04, 2009
    the phone is a V3a
    I must have gotten ripped cause I seen no slot or nothing that says remove battery to insert the card.
    I GOT RIPPED
    Brigadier General:
  • 8,619 Answers
Hi!
If it is the original V3 (no i's, xx's, m etc) after the V3, then there is no micro SD slot and as this phone does not have expandable memory, the answer is - no you can’t insert the SD Card in it.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 04, 2009
  • 1 more comment
  • Rylee Smith
    Rylee Smith Jun 04, 2009
    In the main Heading of your issue the model number is written as RAZR V3 but in the issue itself the model number is written as RAZ V3a. Please confirm the model number to enable me to provide you the model specific information.
    Thanks
    Rylee
  • Rylee Smith
    Turn your phone off & open the back cover of your Razr. At the bottom right of the battery you should see a spot to put the Micro Memory Card that says 'REMOVE BATTERY PRIOR TO MEMORY CARD INSERTION OR REMOVAL' That is where you put it!
    Thanks
    Rylee
  • Rylee Smith
    Yes i think so as the slot must be there wher i told you. I think you bought yourself a Motorola Razr V3 instead of Motorola V3 with the SD slot. I'll suggest you to get it replaced/exchanged from where you bought it.
    Thanks
    Rylee
Micro sd adapter i keeps in camera it is shows card locked
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Mar 18, 2013 | Canon Cameras
When i try to format my micro sd card system shows remove write protect how can i format it
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
I need the user guide for my Vivicam 8340 digital camera, since I want to install an SD card on it but I don't know how to do it. Thank you, in advance!
The user guide is not available online as a download. However installing an SD card is usually pretty simple. On this camera, the SD card slot is on the bottom inside the compartment where the battery is housed. Simply slide the door open, and locate the slot for the memory card. The memory card should only go in one way, so don't try to force it. If it doesn't fit fairly easily try turning the card around. Remember: the gold pins on the card go into the camera!
May 05, 2011 | Cameras
What do i buy so i can attach my digi power dp-fcr20/ mini sd/ms duo card reader/writter so i can attach my mini sd to it and sorry if hard to understand
If the card-reader states it's for a mini-sd card, then you should just be able to insert the mini-sd card into one of the slots. However, some card readers double-up on slots by making it so more than one card-type can be inserted into the same slot. See if the mini-sd card can be put into one of the slots successfully. Tip: Read your manual before doing so, so you don't get card stuck in wrong slot.
Mar 31, 2011 | Computers & Internet
I am trying to find a SD card that will work in my Samsung Digital-cam Model: SCD 103. A regular SD card will not fit in the slot on my camera. The manuel just calls for a SD card. I need more details.
The SC-D103 doesn't take SD cards. It takes Sony Memory Sticks and compatibles from third-party manufacturers such as Lexar and Sandisk. Be careful, it will not take Memory Stick PROs.
Oct 09, 2010 | Samsung SC-D103 Mini DV Digital Camcorder
My mini sd card is in raw format and my computer can't read it - how do i change it back to fat file system ?
  1. Place the mini-SD card within the mini-to-SD card adapter. Make sure the tab on the mini-SD is facing the upper side of the adapter. Slide it in slowly, being careful not to damage the pins.
  2. Slide the adapter in an SD slot on your computer. If you do not have an SD slot, place the adapter in a USB card reader, and plug that into a USB slot on your computer. Give the computer time to read the card.
  3. Open "My Computer" (usually located in your start menu) and navigate to your mini-SD card. It will usually be recognized as a drive such as "E:" or "H:."
  4. Right-click on the drive and select the "Format" option. A menu window will open.
  5. Make sure that the drive size is set correctly, and that it is set to the file system you wish to use (usually FAT32 on an SD card). If you don't know what file system you should use, just leave it at the default setting.
  6. Enter a volume label, which is the name for the drive, then press start. This process should only take a few minutes.
WARNING
  • Do not use the "Quick Format" option unless you have just recently formatted the mini-SD card. "Quick Format" doesn't completely erase all data and is not effective unless used after a full format.
  • When you format your mini-SD card, all of the data on it will be erased. Make sure to back up your files on the card before formatting
Sep 25, 2009 | Electronics - Others
SD card does not seem to fit in the SD card slot
Is the SD card a mini type or a standard SD card?
The standard SD card is 24mm wide X 32mm long.
If it is a mini SD card you need to purchase a mini SD to standard SD adapter, then you will be able to insert it in your Compaq.
Aug 13, 2009 | HP Compaq nc6230 Notebook
SD vs SDHC on the HP mini 1000
Yes , SDHC is the name given to SD cards that can hold more than 2gb of data like 4gb or 8gb. they use the same slot as SD cards
Dec 26, 2008 | HP Pavilion dv6000z Notebook
SD card slot -
The slot is for multiple card formats, usually SD/CF/xD/MMC etc...
Look at it closely you should see different contact points inside, your sd card should slip into one of the slots inside the larger slot.
BUT!!! Some user guides are printed for entire families of notebooks and mention all the available options for that type of notebook. Your laptop might not have come with an SD card slot at all even if it is mentioned in the book.
Jan 18, 2008 | Toshiba Satellite M35X-S161 Notebook
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
