Question about Dryers
Start the dry cycle. after a few minutes of drying it stops. i open and shut the door and turn the dial to start and the cycle starts again.only to stop again. i wait for it to cool, start the cycle.after a few minutes it stops.
  • 378 Answers
Check if the timer is too fast to reset. or maybe the temperature inside is over causing the system to shut off. Set your temperature and monitor the actual temperature. compare them the should not be over the set value.
Posted on Jun 04, 2009
How do I dry only
When using the WD-1000 as a Dryer only, are you turning the rightmost knob Clockwise to the correct starting point?
Looking at the periphery of the knob, at the bottom, see the elongated "sausage" shape, outlined in blue? Turn the knob so it passes "Stop", and points there.
At the end of a completed Wash Cycle, that is where the pointer will be pointing. Once there, the machine switches automatically to Dryer Mode.
As long as the middle dial is set to a timer length greater than zero, the drying begins. I recommend turning the middle dial to somewhere around 2:00 o'clock, which corresponds to about 90 minutes if I remember correctly.
(You'll notice that is in the "Orange" area, meaning Full Heat - which is always fine because it never gets too hot anyway)
So, turn right dial to point to the "white sausage" at the bottom of the dial; Turn middle dial to 90 mins, or so; (Left dial only controls "Spin" speed - just set to max); and close the door. (It should begin drying)
Feb 14, 2015 | Malber WD1000 Front Load Washer/Dryer
How to Clear out dish soap from the jet dry resevoir?
Use a shop vac and suck it all out. Then, spray some Pam-type cooking spray grease into the jet dry reservoir and then, A) start a normal wash cycle and stop it a few minutes after it starts the spray action. Then, open the door and look for suds. B) If you see suds, spray them with Pam spray to knock them down and then C) cancel the wash to drain it out. Repeat ABC until all the suds are gone.
Then, whatever you do, DON'T put dish soap in the jet dry reservoir again!
Good luck
Oct 21, 2014 | KitchenAid Dishwashers
Is there anyway to only dry the dishes? Sometimes the dishes don't get all the way dry and I just want to run the dry cycle again. Thanks! Dawn
You could simply open the door at the end of the cycle and let the air do the job. If your dishwasher is controlled by a manual dial, you could open the door, move the timer past the wash cycles stopping on the dry cycle and close the door to start another dry cycle. This option is expensive, by the way.
Thanks for your question @ FixYa.com
Sep 05, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Spendide 2100 won't do dry only cycle?
I own a Splendide 2100; it is installed on my sailboat. I love it, but it is a little picky. To do a "dry only", set the time you want and then ensure the dial is on "Reset" (doesn't matter which one). The LED should flash very slowly indicating it is ready to run a cycle. Turn the dial to the "Dry" indicator of the dry cycle you want. You will hear a very short gush of water (not sure why it does this) and the dryer will start. If you want to stop it before the time runs out, turn the dial to "Reset", power it off for at least a minute, then turn it back on. You should hear the lock click letting you know you can open it. Don't force the handle or you can break it.
Apr 10, 2010 | Splendide 2100XC
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Dryer only shuts off and restarts during cycle
Get a new timer. It is not that expensive and the wiring is fairly simple.
Jan 14, 2009 | Dryers
Whirlpool Dryer stopped mid cycle and won't start again
This sounds as if the internal fuse has blown. I am assuming you have checked the breakers as well. The starter switch might be bad.
Dec 24, 2008 | Whirlpool LER4634J Electric Dryer
Timer on dishwasher not working
ok start the washer after it fills and starts washing open the door again and turn the dial to drain shut the door see if it drains if it does then open the door and turn it to heated dry shut the door and get you a small glass of warm water let it sit in heated dry for about 3 minutes open the door and pour the water on the heating element and let me know if it sizzles
Mar 27, 2008 | Dishwashers
Dryers Logo
21 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
