I have a WD1600BEVE 2.5'' HDD which I have put in a USB 2 External case. However none of my pc's recognise it. The power light is lit and it just sits ther buzzing. Can anybody tell me how to get Win XP Pro to recognise this drive please ?.
  • 696 Answers
Hello, XP Pro detects these devices automatically and contains all the required drivers. If it is "buzzing" there is a problem, hopefully with the shell you installed it in. Try a new shell, if it works you're done, if it doesn't and you need the files from that drive then you need the help of a data recovery pro. If that is the case reply here with a comment containing your country and city and I will recommend an appropriate facility to assist you. Chris
Posted on Jun 05, 2009
Western Digital My Passport 1TB HDD turns on, spins up, but none of my computers recognize it. What could be the problem?
You should open the case of that HDD and put the disk into a different HDD enclosure. If only the chip is wrong which operates the HDD this should work.
Ebay link for the item you need:
http://www.ebay.com/itm/New-USB-2-0-External-SATA-2-5-HDD-Hard-Drive-Enclosure-Case-Red-/221264431009
In case the HDD is wrong and it is not readable by any computers, than it will cost a fortune to recover the files.
It may also be impossible.
Alternatively, You can take out the HDD from the casing and connect it to a PC over SATA. Maybe this way the hdd would work.
Oct 15, 2017 | Western Digital Computers & Internet
My computer does not recognise simpletech 250GB HDD drive when connected. The lights glow only. Earlier I had used this on my TV. Could it be that the system got corrupted
Buy an external USB hub that has an AC power adapter.
Your computer is not providing enough power to spin up the drive.
A self powered hub will provide the necessary power. 7 Port USB 2 0 HUB AC Adapter Monoprice com
Mar 10, 2015 | SimpleTech SimpleDrive 250GB 3.5" USB 2.0...
I have a seagate Freeagent Go 500gb and suddenly it is not recognized by my laptop.
Try with another PC, If still not recognising, then You have to open the Casing of your external drive. If you have any Warrenty remaining for this Drive, then let company people fix this. if no warrenty then Remove the HDD from the casing, Connect HDD to the PC with another External casing, and backup your Data. If no ditection with this method, then your HDD is Dead. Keep finger crossed best of luck
Feb 01, 2011 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
My Fantom II Hard drive only has a red light on
Sounds like the drive has gone faulty, all you can do is take drive out of case, get USB to HDD - USB "Dongle" and hook up HDD, and see if it works on PC & USB, If YES, then Case and interface are faulty, otherwise the HDD is faulty.
May 01, 2010 | Fantom Titanium II (TFD500C16) 500 GB USB...
Seagat 500GB Portable GO external HDD not recognised on PC
first of all you should try it on deferent pc , if its ok then that leads us to insufficient power provided through usb ports , try using back usb ports not the ON-front, and if the problem still try using dual-usb cable like thishttp://www.cooldrives.com/usb-power-cable-mini-b.html and if the external hdd doesn't work at all it might be the usb controller board inside the hdd cage needs to be changed if you cant find a similar one you may buy a new empty cage
Mar 05, 2010 | Computers & Internet
WD320 GB 2.0 USB external hard drive is not working.
bad driver chip... call the manufacturer.. have the HDD changed...
Jul 09, 2009 | Western Digital Passport 320GB External...
Sony Vaio USB ports not recognised by XP
It is common problem on most of the PC USB ports does not recognise external hardware.It is mainly due to lack power supplied by the USB Ports..You can try with Old Pentium4 maschines.IT Reads well..
Another thing dont use extension ports to plug external HDD..always use backside on board ports.\
IF it helps rate me
Jun 25, 2009 | Sony VAIO Digital Studio PCV-RX560 PC...
PC won't recognize external usb HDD
You may not have installed the HDD correctly in the case... I had the same problem with my Thecus N1050 enclosure, the green power light on the enclosure would come on and the drive would spin up but my PC would not see the HDD!!??... I thought, becuase i could hear the drive spinning that i had it installed correctly but this wasn't the case, when i removed the enclosure again and FIRMLY pushed the HDD into the connector (all the way in) and connected it back up to my PC, it recognised it instantly. Hope this helps!
Jul 25, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Computers & Internet Logo
425 people viewed this question
David Payne
David Payne
