Simplicity air conditioner no longer collecting water
The fan works, and the cool mode works a bit (i.e., there was about 1/2 cup of water in it after running it all night); but the dehumidifier doesn't work at all, but again the fan still runs.
I shut off the air conditioner. then when it was off, i took out the water compartment, and put it back in, after which i turned the machine back on, and voila. I think the problem was that I took out the water compartment while the machine was still running.
Posted on Jun 05, 2009
Celiera 51GW 18000BTU mini split a/c heat, water collects on top rear coil and drips into fan housing and comes out bottom
While cooling, water is supposed to drip off the evaporator coil and flow out the unit. That's a feature of air conditioning. You get a little bit of control of where the water drips to by installing tubing to conduct the water wherever you like, unless the outlet port is plugged up. Poke a toothpick up it and see if that unclogs it.
May 13, 2014 | Haier HEATER CPN10XH9 Air Conditioner
Tip
Water in Air Conditioner
Air Conditioners are designed for two purposes.
1. Cool
2. Dehumidify
The water that collects in the drain pan is used to cool the condenser.
This is done by the "slinger ring" attached to the condenser fan blade thus making a more efficent unit.
Be sure the unit is tilted properly by using a bubble type level. The unit should tilt 1/4 bubble outward.
on May 04, 2010 | Heating & Cooling
Ok So We Bought This. But We Have A Problem Does It Take Water Or Not? Thats What I Need To Know! Please Help!
The DeLonghi PACA120E Portable Air Conditioner quickly cools rooms up to 400 square feet and comes equipped with several functions that make operation easy and low maintenance. Its 3 operating modes are supplemented with no-drip technology, an adjustable thermostat, 24-hour timer, and much more. This unit truly takes the work out of cooling medium- to large-sized spaces. Multiple Modes and Functions The DeLonghi A120E-also known as the Delonghi Pinguino PAC A120E-offers 3 operating modes and 3 additional operating functions that make this model versatile and energy efficient. Cool Mode: 12,000 BTUs of cooling power help cool large rooms, offices, or basements. Dry Mode: Reduce room humidity by removing excess moisture from the air. Fan Mode: Circulate air to keep your room comfortable without using a lot of energy. Low, medium, high, and an auto-speed are all included (auto speed selects a fan speed for you). Smart Function: Your AC uses Cool and Fan mode based on ambient room temperature. This function will also select your fan speed and keeps your room comfortable without wasting energy. Sleep Function: Using a low fan speed, the AC gradually reduces operation so your room remains comfortable but the AC runs more quietly and efficiently while you sleep. Boost Function: This function is ideal for the summer months and uses the maximum fan speed to rapidly reduce your room temperature. Useful Features Using DeLonghi's patented no-drip technology, this unit is "dripless" under normal conditions, meaning the AC will discharge all of the moisture collected from the air-so you typically won't have to worry about draining the water. When dehumidifying a lot of moisture in Dry mode, excess water may collect in the internal collection tank. Once the tank is full, the air conditioner will automatically turn off to avoid overflow damage. You can also use the included continuous drain hose as a no-fuss way to eliminate excess water as needed. An adjustable thermostat provides additional convenience by allowing you to set your room temperature. The DeLonghi portable AC will cycle on and off to eliminate over-cooling and maintain the set temperature. Additional Features Washable Air Filter: A washable air filter helps remove allergens and other particles from incoming air and saves you money on replacement filters. Quiet Operation: High efficiency compressor and components result in quiet performance. Electronic Controls: The LCD screen displays the timer and temperature settings, while intuitive indicator lights accompany each operating mode. 24-Hour Timer: This feature lets you program your AC to turn on or off up to 24 hours in advance, so it only runs when needed. Window Bracket: Double window bracket is included with purchase for flexible installation. Self-Diagnosis System: The unit includes a self-diagnostic maintenance system that identifies malfunctions should they occur. Remote Control: Use the full-featured remote control to change modes, set the timer, and select a fan speed up to 23 feet away from the receiver (on the front of the unit). Portability: Easy-roll casters and dual carrying handles make it simple to move this model from space to space.
Aug 06, 2012 | DeLonghi PAC A120E 12000 BTU Portable Air...
Danby dpac 10071 air conditioner is not cooling. a red light is on next to an icon with a full cup. Does anyone know how to make it cool?
That indicates that the water collection bucket is full and needs to be drained. Once the unit is turned OFF, unplugged and drained, the unit will start up and start cooling again. The drain hole is on the rear of the unit, just above floor level. You can either drain it in a shallow sided pan capable of holding 1 quart of water. Or roll it to a floor drain or outside to drain it.
Hope this helps you and thanks for choosing FixYa.
Jul 29, 2011 | Danby DPAC10061 Air Conditioner
Bought 4 small Gold Star units in 2009. One quit cooling altogether, one blows slightly cool while the longer another stays on the less it cools. One did not cool well when it was new. All filters are in...
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28700000&pkw_=basket&model_id=5520000&NewWindow=1
Download this illustration and then using a good multimeter start basic troubleshooting.
All residential window air conditioners have a cooling system made up of four primary components, a compressor, an evaporator fan, a control or switch, capacitor.When the thermostat is calling for a colder room temperature the compressor is energized. It is normally very quiet. The evaporator is always located on the front of the air conditioner. It also has silver fins. Be sure it is clean. Use a foaming type cleaner and rinse with plain water. Because the evaporator is absorbing heat, it is very cold to the touch. The temperature drop causes any humidity in the air to collect on the evaporator - sometimes called sweat. There is a fan inside the air conditioner that circulates the air for the evaporator and condenser coils. The circulating fan and compressor are running simultaneously. The fan motor has two fan blades attached to it on either end. The fan blade on the inside part of the unit continually draws room air over the evaporator coils, which are cold. The fan blade on the outside part of the unit continually draws fresh outside air over the condenser coils, which are warm. Because the evaporator coils are cold, they cause moisture in the room to collect on them, much like a cup of ice water on a warm, humid day. When the amount of moisture increases, it begins to drip down off of the coils into the bottom pan of the air conditioner.
If the compressor fails to start or the fan you may need to replace the capacitor.
You may need a hard start kit.
Thermostat control The thermostat on a window air conditioner works by sensing the air temperature entering the air conditioner. As the air entering the unit reaches the set temperature it will cause the compressor to turn off. The blower may continue to run depending on the selection chosen on the control panel. Digital thermostats work on a similar principle but display a more precise temperature.
Test for continuity with the multimeter between the two terminals . Warm you should read continuity (contacts closed). If not change it.
Selector switches The air conditioner selector switches allow the user to choose the fan speed. The compressor always runs at the same speed regardless of the settings. If low cool is chosen, for example, the fan runs at a slower speed but the compressor still offers the same cooling capacity. There are other switches to control louver operation and other features on some units.
Jul 23, 2011 | LG Goldstar GWHD5000 wall/window Air...
I have a sharp window AC unit, model af-609x. does it have a drain hole? there is no water coming out of it, but when we take it out of the window we get soaked from water somewhere inside the unitl
All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
Jul 22, 2011 | Sharp AF-M609X Air Conditioner
I just bought a Commercial Cool air conditioner, model number CNP12XH9 and have to maznually drain the water (approx 1-1/2 cups) every hour or so. Is thisnormal?
no there is supposed to be a drain tube that goes outside you have to plumb it in, there should be a plug or fitting in the catch tray for the water.
Jul 28, 2009 | Heating & Cooling
What is the function of dry mode in ac, when to use dry mode, and when to use cool mode and what about heat mode.
Dry Mode in AC is to dehumidify the room the fan cycles on and off and the indoor unit temperature drops below freezing which causes condensate to collect on the coil and as a result the humidity level of the indoor air is reduced
Jul 13, 2009 | LG L1204R Air Conditioner
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
What is the Dry setting on air conditioner?
Hi, I know this question's been up a while and I'm not sure if you care anymore but here goes anyway.
Most air conditioners are reverse cycle, so they can heat the air in your house or cool it down. What we are concerned with is the cooling side of things. So in this mode a working liquid is sprayed into the evaporator and cools its immediate surroundings. air is blown over the evaporator which cools the air. The local temperature around the evaporator is very cold, (how cold exactly I'm not sure) so the air in this region has a very poor ability to hold water and so (especially on a humid day) water condenses out of this air on the surface of the evaporator, is collected and drained away. The cooling function and dry function both use the "cooling" mechanism of the air conditioner. Both extract water from the air in this way but the primary purpose of the cooling function is to cool the air whereas the primary function of the dry setting is to dry the air... obvious I know.
Now in the dry setting the compressor will run with fan going at I imagine a relatively slow speed to chill and extract as much water from the air as possible and to minimise circulation. After a short time the compressor and fan will cut-out and then after a short interval start up again (I'm not really sure but I assume this is either controlled by a humidity sensor OR the temperature sensor monitors for a small change in temperature and shuts off the compressor and fan when it detects this). Now in cooling mode (depending on what temperature is set) the compressor will run for longer and more frequently and therefore remove more water. So why have a dry mode if cooling mode removes more water?... Well that really has the same answer as the question "when do I use dry mode?"
Well on a particular day where the temperature would normally be considered comfortable but on this day it is unusually humid, your body will find it difficult to radiate heat via sweat because of the already high RH (relative humidity) making you uncomfortable and feel "hot". Using dry mode will reduce this RH without adjusting the temperature by much, but you will perceive an ambient temperature drop due to your body being able to discard heat more easily... hence making you more "comfortable" in same way you would normally feel at that temperature.
On the contrary if you were to use cooling mode (which is regulated by temperature) you would have to set a temperature lower than ambient so that the compressor will "kick-in" rather than the air conditioner just running its fan...agree? So that means the air conditioner will reduce RH (which we want) giving you a perceived temp drop but it is also chasing the temperature which you set which will give a REAL temperature drop. So anyway the point is; if it was an unusually humid day on what would otherwise be a comfortable temperature, using cooling (remember the temp has to be set lower than ambient) instead of dry would result in you feeling cold very quickly due to the perceived AND real temperature drop.
So really the dry setting is for days which aren't too hot, but are humid.
I think my logic makes sense.
cheers Matt
May 30, 2008 | LG L1204R Air Conditioner
Heating & Cooling Logo
438 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
