Question about Briggs & Stratton Garden
BRIGGS ENGINE REPLACE THE POINTS - Briggs & Stratton Garden
  • panilling9
    panilling9 May 11, 2010
    must be an older engine
    Usually you replace points and condenser as combo
    dont know what you have but most points are located under the flywheel and under another cap after fly wheel is removed set at .020
    need more engine info model,type, code to further assist
Briggs carb diagram
the only adj is speed idle. on the air vane. its very apparent where that is its usually a very large screw with a spring around it.
you can replace the points with a scr points replacement module. 3 wires on a little module .makes it electronic ignition then. have to remove the top to git to points. not easy.
Aug 03, 2014 | Briggs & Stratton Garden
How do i get the flywheel off to get to the points i have no spark
use a three prong pulley puller and pull it off before this are you sure you have points chek blad brake is disengaging befor pull fly wheel
May 13, 2012 | Briggs & Stratton Briggs Stratton...
Trying to change the points on an old briggs and stratton 8 hp engine
Need to know what model Older engines have points "under" the flywheel. Use a wheel puller to remove after removing the nut in the center of the flywheel. Newer motors have an electronic ignition module. Follow the small wire from the magnetio. If it goes under the flywheel then you have points. If it goes to a small device on side of motor, you have electronic. You can go to http://www.briggsandstratton.com/ and look up your odel number.
Jun 23, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
I'm wanting to change points & condenser
At that age, it's highly likely that there aren't any! You don't say what engine is fitted, but if it's a Briggs or a Tecumseh, they went solid state in 1982. If that's the case, just replace the coil module.
May 12, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Started briggs 15.5 hp engine. Ran for 5 minutes large plume of white smoke came from exhaust and now oil is dripping from exhaust pipe. clean air filter and has good oil level.
make sure you have the correct amount of oil in it and that its not overfull. after that replace the points and condenser underneath the flywheel that is underneath the shround on the top of the motor. make sure the points are gauged right. you can buy a manual for biggs and straton that will tell u what to gauge the points at. you will need "feeler gauges" to re-gauge the points. they are a little set of gauges that are really thin pieces of spring metal.
Dec 26, 2009 | Briggs & Stratton Garden
My 17hp ohv briggs & straten runs fine until it warms up. then it pulses and dies. what could be causing this?
If I were a betting man I would say that the coil is breaking down with heat and causing irratic spark when it is warm, if for some strange reason this motor has a condensor and points then I would say the condensor is breaking down when it heats up but I do not believe your engine has points so again I would say replace your coil and the engine should stay running after it warms up. Hope This Helps Don
Dec 06, 2009 | Briggs & Stratton Garden
Cant get a spark on my briggs and stratton 4hp engine, trying to
gap from coil to flywheel is .010. if you've replaced coil, points and condenser with no spark i would try replacing the coil and points with an magnetron kit or a coil that allows for the elimination of points.
Mar 21, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Garden Logo
95 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
