Question about Mitsubishi VS-60601 60" Rear Projection Television
VS-60601 Mitsubishi Problem...
Hi, we have a Model VS-60601 Serial # 113332 Mitsubishi that is about 5 years old I think. The problem that we are having is that whenever we turn on the TV, the little green light turns on and the TV sounds like it is turning on, but then it turns off. My husband tried to look behind the TV and looked at the circuit board. He said the circuit board had black on it.
  • Anonymous Feb 12, 2008
    convergence problem
  • vgomez7538 Nov 20, 2008
    my mitsubishi tv has the same problem, it sounds like is turning on (green light comes on) then goes off... it happened before and I used the original remote and it turn on.. but now is not working even with the original remote..
  • Mitsubishi Master
  • 8,617 Answers
That model is famous for the CRts leaking onto the chassis which causes all kinds of problems and can cause the main circuit board to short as well as destroy the solder. Try looking at the board for evidence of a pastey substance that would indicate CRT coolant leakage. Let me know what you find.
Posted on May 04, 2008
What is CRT
Cathode Ray Tube. A CRT is an old school television or monitor that is very heavy.
Nov 06, 2013 | Mitsubishi VS-60601 60" Rear Projection...
Where is the Convergence IC on my Mitsubishi VS-60601 1997 Serial #104094. You told me what the problem was with my TV and showed me what a Convergence IC looks like, but now that the projector TV is...
Convergence IC will be mounted on a big Aluinuim Heat Sink They are Big Black ICs and will have Parts # on Them example STK392-570 There is 2 of them together.
Mats Electronics has them 1-800-628-1118
Nov 04, 2010 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi VS-60601 60 in.
I just encountered the same problem. What was your solution?
Sep 12, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi big screen model VS 60601 convergence adjustment
you need new convergence ICs. If you can respond to this same post and verify the model number of your mitsubishi, I wll post the correct ICs that your model needs.
Aug 17, 2008 | Televison & Video
1998 Mitsubishi vs-60601 picture is dull and not as vibrant as it should be
the first thing I would do is to clean the lenses of the CRTs they may be coated with dust that will dim the picture. other than that the CRTs may be failing since the phospher of CRTs fade in brightness over time and the only solution is to replace all three CRTs. the CRTs I have discovered are no longer availible.
May 04, 2008 | Mitsubishi VS-60601 60" Rear Projection...
sounds like a loose video cable. Check your connections
Mar 03, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubushi Big Screen TV Screen Protector vs 60601
that will have to be a dealer orderd item.. Unless you can find one used. I would try the tv shops in your area , they may have a used mitsubishi screen
Jan 21, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi ws-65819
The correct part# for the two convergence ic's is = STK392-570. The repair is close to $400
Aug 21, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi VS 60601 picture
You need to change the convergence IC's my friend. If you know how to solder and work on printed circuit boards, this is an easy repair, BUT if you have no experience, play it safe and let a pro do this repair for you. Good Luck
Aug 11, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Televison & Video Logo
311 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
