Question about Tech Solution TS-4500 Shredder
Ts8000 doesnt stop running
  • 168 Answers
Either there is a piece of paper that is jammed where the paper in sensor is located, or there is paper fibers covering the paper in sensor, or the paper in sensor is defective.
The paper in sensor is usually located in the center of the shredder where you place your paper. Once you locate your sensor, you can try blowing it out with a can of air that is used to clean your keyboard out.
Since the opening for the paper or the Thoat width is 9", the switch should be close to 4.5" towards the center.
To try to help you located the sensor, take a piece of 8 1/2 " x 11 paper and fold it in 1/2 Long ways. This will place a crease in the middle of the paper. With the power off, or unplugged, place the paper in the shredder and look around where the middle of the paper (crease) lines up in the shredder. You might need a flashlight to help you located it. It will either look like a slot, or a little black lever.
Hopefully you will be able to blow the sensor out and clean it.
Good luck.
Posted on Feb 07, 2008
Fix a toilet that doesnt stop running
I would stop the water so that it stops running and then have the toilet checked by an expert
Feb 05, 2016 | Home
It heats up but doesnt stop after the clothes are dry
IT is the timer. If electronic needs to replace the board. If dial type, needs the timer
Sep 15, 2014 | Dryers
Bernzomatic ts 4000 flame adjustment
There is no adjustment on the ts4000. The ts8000 has the ability to adjust by turning the knob while depressed, however the ts4000 does not. If you use a hose with an in-line regulator between the cylinder and the torch that would give you the ability to adjust your flame. Make sure the hose and regulator used are suitable and rated accordingly.
Mar 05, 2014 | Thermador SGS36GS Gas Cooktop
Where can I get new gears for my Tech Solutions TS8000 paper shredder
Unfortunately there are no replacement parts for many shredders...they are made to throw away when the break...
Stinks... but that's the way it is...
heatman101
Jun 15, 2011 | Tech Solution TS-8000 Cross-Cut Shredder
Does it make a difference which shredder oil I use? There are so many. I have a Tech Solutions cross cut TS8000.
You can use any kind of shredder oil. They are all priced so differently, I use fellows brand for my royal shredder & it works just fine.
Feb 07, 2011 | Fellowes WilsonJones Q4 Paper Shredder Oil...
With a full charge chair stops working and won"t power up
I have a Jiffy Jet3 . the problem is when I charge the batteries
the light indicator just blinks but chair doesnt run.
I just put new batteries and still doesnt run,,,thanks J.J.F.
Feb 12, 2010 | Jet 3 Ultra Power Chair
How to empty a Tech Solutions TS8000 shredder
Pull the top of the basket toward you and the top of it should swing out. Then you can lift the basket up and out once the top of the basket is partly open. Hope this helps. Have a good day. Mac =)
Mar 09, 2007 | Tech Solution TS-8000 Cross-Cut Shredder
Tech Solution TS-4500 Shredder Logo
218 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Marvin
Marvin
Michael Galve
Michael Galve
quennie732
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
