Question about Flotec Simer//Omni 2957 Submersible Sump Pump with Piggyback Tethered Vertic
We have a briggs toilet in our send floor condo. seems that the cause of a major water leak to the 1st floor unit was due to the defective toilet. Are there reports of this product with defect and if so, where can i get information about it?
  • 332 Answers
Go to briggs toilet web site, if there is a problem with a product by law they must have it on there web sie, if not go to consummer affairs
Posted on Jun 23, 2009
I have a water leak in bathroom not from toilet. How can I check the pluming in that area?
Your idea may correct. But majority of cases it is floor/ground seepage....leaks through your tiles or waterproofing layers and so on..To chk...keep on pouring water to the ground of the bathroom, near wetting areas, and close the freshwater line leading to the bathroom taps
May 18, 2016 | 2006 Tahoe Transport
, Hi good evening ,i need the lid tank for toilet tank 4440
Amazon lists one:
Product Description
Briggs - China Toilet Tank Lid for use on tank #s 4420, Altima 4430, 4433 and Abingdon 4440 tanks. Click here to buy now. Same day shipping on most orders. High quality construction. Quality Replacement Part.
Briggs China 7469 130 Toilet Tank Lid
Feb 01, 2015 | Home
Briggs 6002 toilet
I GOT NO ANSWER FOR THIS PROBLEM I WANT TO INSTAL A TOILET IN A MOBILE HOME AND GOT NO ANSWER FROM YOU
Oct 14, 2013 | Home
Eljer toilet bolts rusted causing massive flooding
Turn off the water at the supply (under the toilet, usually).Flush the tank to remove all water from the tank.Disconnect the supply from the tank.Remove bolt caps or bolt covers from where the toilet bolts to the bathroom floor.Remove bolts from the floor flange. When you lift the toilet up, you'll see a metal or plastic flange. If the toilet has been there for a long time the bolts may not pull out of the flange easily. In this case you may have to use a small hacksaw to cut the bolt below the nut.Put newspaper or an old towel on the floor so you can place the old toilet on it. Lift the toilet off the flange.Take the new bowl (assuming this is a two-piece toilet) and turn it upside down. Position the wax ring on the horn of the outlet. Install new solid brass flange bolts, mount them and position them on the centerline on either side of the outlet.Push the bowl down over the bolts and seal the outlet. The wax will squeeze down and seal.Put the new bolts, washers and bolt caps on. You may have to trim the bolt with a hacksaw.Once the bolts are secure, mount the tank.Make sure the gasket between the tank and toilet is in place. Then position the tank on the bowl. Run bolts through the tank and secure. Don't over tighten (the tank can crack).Hook up the water supply line.Connect the supply to the line on the bottom of the tank.Turn on the water.Let the tank fill.Flush once or twice to make sure the water control is properly adjusted.Put the tank lid on.Enjoy.
ford performance chip.
May 25, 2012 | Eljer Home
Problem with Briggs Vacuity toilet--fills up but won't flush (no whoosh sound). Seems like it's gonna flush but then it just...doesn't. We have taken the toilet off and also used a toilet snake but it...
Briggs vacuity toilet flushes poorly? Seal the smaller of the two gaskets between the tank and the bowl with silicone. The gasket is for sealing air only and is prone to leaks. Do this and it will bring back the woosh!
Dec 02, 2010 | Home
Leaks from tank into bowl and when flush as it
Change the flapper with a generic one that will fit that toilet... the OEM flapper is **** and it does not allow for a good flush either...
heatman101
Aug 03, 2010 | Eljer Toilet Onepiece Canterbury ...
My 25 hp briggs is smoking and leaking oil. it
if the engine is ran quite a lot evey year the valves muct be adjusted. If not it will cause a head gasket leak which it sounds you have
Apr 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
31p777 18.5 hp briggs & stratton valve cover leak
Both can cause problems. It is recommend that you do not go on a grade more the 10% for your safety and the safety for others around. But if the valve cover is leaking this can lead to major problems if not repaired on a timely matter
Apr 29, 2009 | Garden
WATER TANK CRACKED. IS IT DEFECTIVE?
There are a few things that could have happened.
Your tank could have froze and cracked.
The tank bolts could have been overtightened and cracked the tank.
Someone jarred the tank and got a crack started.
The tanks are porcelain and if you hit it with a hammer, it would break easily.
Since it has made it since 1972, I'm pretty sure that it is not a factory defect.
If I am leaving for an extended period of time, I always shut off the main water supply to the house. There are a lot of things that could leak and if you aren't there, they could leak a lot of water before catching it.
Apr 23, 2009 | Home
Flotec Simer//Omni 2957 Submersible Sump Pump with Piggyback Tethered Vertic Logo
166 people viewed this question
Top Flotec Electrical Supplies Experts
 Kenneth
Kenneth
Paul Nielson
Paul Nielson
Are you a Flotec Electrical Supply Expert? Answer questions, earn points and help others
