Question about Whirlpool Freezers
Freezer runs for 24 hours then melts - Whirlpool Freezers
    President:
  • 2,976 Answers
The defrost timer is going bad. It should go into defrost mode once every 24 hours but it shouldn't allow things to melt. It isn't picking back up. Relatively cheap.
Posted on Jun 04, 2009
Is my defrost timer broken or my thermostat? The freezer was holding -30 temp but now is at +30.
Is the compressor running? If not - the timer could be stuck in defrost mode. If it is ruinning, then the freezer coil should be cold. If it is choked with frost & ice - then the defrost heater isn't getting powered (bad timer or defrost terminator - or is getting powered but has burned out.
You should allow the ice and frost to melt completely before turning back on again. Typically ice and frost don't build up so bad in a few days time to cause the temperature rise you're describing If getting cold - the compressor and refrigerant is likely OK, if not the defrost circuit is suspect. If compressor running but not getting cold - a refrigerant leak / charge level may be causing the problem.
May 18, 2015 | Arctic Air 22 cu. ft. Commercial Freezer...
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
Dain line frozen
Unplug the power cord and leave the door open for 24 hours to defrost the drain line. You can also take a blow dryer and melt the ice out of the line by aiming the heat towards the frozen drain line and melting the ice within a few min allowing the water to flow again.
Feb 27, 2011 | Whirlpool 25.3 cu. ft. / 716 liter Upright...
19.7 cu. ft. / 558 liter Upright Freezer Deepfreeze AFU2004AW: the upright freezer was on its back for about 8 ho...
It is usually reccomended to let it stand in it's normal position for 24 hours prior to running to allow any oil to run back to the compressor. Unit should work.
May 18, 2010 | Amana 19.7 cu. ft. / 558 liter Upright...
Would a bad thermostat cause my danby to not completely freeze?
Should operate 24 hours before putting anything in that is not already frozen. Check it again after it has run for 24 hours. Anytime you adjust the thermostat go one click at a time and wait 24 hours for it to stabilize.
eric
Jun 30, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Water leak
probably the defrost drain blocked. remove back panel from inside freezer and melt ice off with hairdryer and follow up with hot water till water flows away freely.
you may find all the pipework iced up and if so you have a problem with defrost system.
an alternative way is to switch off for 24 hours and leave doors open
Aug 23, 2008 | Freezers
Freezers Logo
82 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
AJMAL KHAN
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
