Question about Brother HL-2040 Laser Printer
When i print from the brother hl2040 printer there is a ink spots running down in the page. how can i fix this problem?
    Problem Solver:
  • 7 Answers
It sounds like you have damage to either your transferr roller of the drum, you could try running a laser printer cleaning sheet through it a couple of times but usually the only way to sort the problem is to replace the part that is causing the problem.
Take the drum out and turn it by hand using cog at the side to turn it to see if its marked.
Posted on Jun 04, 2009
My HL2040 laser printer will print "Print Settings" page but otherwise will not print at all.
Set this printer as the default printer or if there are multiple printers connected or installed specify the printer issue print command
Jun 06, 2015 | Brother HL-2040 Laser Printer
Ink spots left side page brother laser printer
If you are using a generic toner, replace it with cartridge from Brother. Many of these are caused by using a refilled cartridge or a generic cartridge. Use a cleaning sheet and run it though a couple of times, if this does not clear it up you need a new cartridge.
Mar 28, 2014 | Brother HL-5240 Laser Printer
How do you find page count on hl2040
Press the blue "Go" button 3 times (within two seconds). The unit will print a "Print Settings" page with everything from serial number to a replacement toner count. Page count is first item, left column, below the drum life bar graph.
Oct 13, 2009 | Brother HL-2040 Laser Printer
My brother printer is printing with 2 blind spots in the same area of each page.
Could be that the ink (or toner) is running low. Does it say the level it's at?
Jul 08, 2009 | Brother HL-5250dnt Laser Printer
When printing or copying I m getting thick black
First try running maintenance to clean print head on your machine.
If that does not solve your problem replace the ink carts OR Toner cart.
(I am unsure which you have as that was not specified)
Jun 08, 2009 | Brother DCP-8060 Laser Printer
Specks on print out of Mono Laser Printer HL2040
If its spots this could have been from the cartridge or the fusser unit...
Do a half print test...send a print page to your printer listen to the printer print as soon as you think the printer has printed some little bit switch off the printer...take the cartridge and view the printed portion can you see the spots..if not.....than its your fusser unit thats marking the paper....remove the half printed paper slowly.....not to tear it......remover the fusser unit(hot unit)........at the back of the printer....towards the top....on the unit it self you will see a Teflon paper ....move the gear on the far end of the fusser unit itself and view if there is any spots....try cleaning this spots slowly as not to damage the Teflon or mark the Teflon.....
Nov 04, 2008 | Brother HL-2040 Laser Printer
Brother HL2040 PRINTING DOTS
1- change the drum unit
2- check the fuser unit
Sep 06, 2008 | Brother HL-2040 Laser Printer
Brother laser printer printout
You need to clean your drum unit:
see http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000001044&Sympt=The+print+jobs+have+black+spots+or+black+dots.+How+can+I+improve+the+print+quality%3f&Model=3&ProductGroup=1&Keyword=dot&ProductID=HL2040
Worked for me!!
Dec 19, 2007 | Office Equipment & Supplies
Brother HL-2040 Laser Printer Logo
175 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
