Question about iLO (2 GB) MP3 Player
Blinking on & off
Why is it blinking on and off? And how can I make it stop?
  • 8,596 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
Light blinks six times and stops and then blinks 6 times and stops. Dalton mobility electric scooter.
Could be throttle control not in centre position on switch on. check the throttle control or wig-wag is not loose.
Oct 05, 2014 | Health & Beauty
Hazzadas lights don't stop blinking need to know
Does the blinking stop when you open ignition?
Sep 07, 2013 | 2008 Smart fortwo
How to stop red blinking "paper"? couldn't stop
There is probably a paper jam since you shut it off as it was printing. Turn off the printer. Remove the tray and look inside. Remove any sheets of paper you see. Open the back of the printer (the pass-thru door) and remove any paper you see. Turn on the printer. If that fails, check the blink status against the manual's troubleshooting guide to locate a different solution.
Aug 27, 2010 | Brother HL-2040 Laser Printer
Power switch blinking
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
Nov 12, 2009 | HP DeskJet 3740 InkJet Printer
Light is blinking but will not print
Nov 09, 2009 | HP Deskjet D1341 InkJet Printer
How to set time for aquastar N0 4095
When looking at the face, you have 4 pushers. Top left is for regatta function countdown. Top right is regatta function start-stop-reset. Bottom left is Hours-Minutes and Nite Lite. Bottom right is regatta function "catch up". Assuming that you want to set Hours and Minutes, press and hold the bottom left for 3 seconds...Hours will start blinking, press the pusher successively until the desired hour is reached. Then wait until it stops blinking. To set minutes, press and hold for 3 seconds, the hours will again begin to blink, then release and re-press for an additional 3 seconds and the minutes will blink, Then press successively until desired minutes have been reached. Stop pressing and wait until the blinking has stopped. Once it has stopped blinking your time has been successfully registered. Good Luck. Hope this helps!
Nov 02, 2009 | Watches
The green light will not stop blinking and I can't get the printer to work
Oct 26, 2009 | HP Deskjet 3845 InkJet Printer
Light constantly blinks
Oct 20, 2009 | HP DeskJet 3520 InkJet Printer
Led has been blinking for two hours .
is it blinking constantly > or is it a number of blinks then a pause...count the blinks before the pause ..this is a repair code for your tv
Dec 09, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Power Failure, now the power/timer blinking light won't stop blinking
Four bad caps in DM module = common repair for qualified
Mits tech.................................T.
Nov 03, 2007 | Televison & Video
iLO (2 GB) MP3 Player Logo
18 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Jon Piercy
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
