Question about Sony CDX-565MXRF 10-Disc CD Changer
We removed our player from a car that we sold. We didn't take the disc case out before disconnecting it and now the disc case won't come out so I can remove the CD's
It has to have power
Posted on Aug 22, 2009
Dvd player won t read disc
In most cases it is either the motor which rotates the disc goes slow or the optical unit or lance goes bad. Apart from this there may be dust deposition on the lance.In first two case you need the help of a technician. Dust cleaning can be done by lance cleaning disc. Good luck.
Jan 18, 2014 | Philips Televison & Video
Disc won't record
Try other disks If same results the dvd unit is fubar.
Sep 12, 2017 | Magnavox ZV457MG9 MP3 Player
I have a Rosen entertainment DVD system and it keeps displaying Damaged Disc every time I put a disc in the player. It won't play any discs.
It has either a dirty or bad optical pickup unit (the part that reads the disc) and usually parts are not sold (only a complete DVD section if even available)
If not dirty may be cheaper just to replace the player itself.
Apr 16, 2012 | Televison & Video
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
Cd jammed won,t eject
Hi.
Try pressing repeatedly the eject button on the on dash player while turning on the stereo at the same time. If that does not work disconnect battery terminal for one minute to reset the electrics and try again pressing eject repeatedly on startup. Make sure that you have the stereo anti theft code if needed before disconnecting the battery.
If that does not work, then the unit must be disassembled. The car stereo must be removed from the dash. The unit must be disassembled removing screws at back and bottom and undoing metal casing clips. That will reveal the CD drive allowing to remove the disk.
Regards.
Ginko
Sep 14, 2011 | 2006 Pontiac G6
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
My cd player will not work. I cannot eject discs or play them. Will taking off the postive side of the battery and then reconnecting it reset player and eject discs?
It might, I won't say for sure it will work, but there is a possibility it will. Try leaving the battery disconnected for about 5 to 10 minutes.
Jul 19, 2011 | Car Audio & Video
Good evening, my cd player just stopped working in my expedition. It keeps saying cd error. Even when i try to eject the cd it says the same thing or when i swith cd's. Its a factory 6 cd changer...
I had this happen in my old dodge stratus. My trick to remove cd's was when you stopped or parked the car turn vehicle off and hit the eject button and it will usually eject the disc. remove all discs and then install them again when car is parked and not moving as vibration and bumps while driving can sometimes miss align the disc in the player. Sometimes when the stereo didn't work at all I disconnected the battery and it would reset and work. If this doesn't work it may be broken. Good Luck.
Jul 05, 2011 | 2003 Ford Expedition
2005 Corolla cd player "ate"
try disconnecting the battery for a few minutes to reset the radio. Sometimes a microprocessor will lock up. You can reset it by disconnecting the battery.
Jun 01, 2011 | Car Audio & Video
I got a LG HI FI SYSTEM. DOES NOT READ DISC.
hello,
it is either the lense of the hi fi system that may be faulty, therefore, if that is the case you take it back to the dealer that sold it to you.
or probably the disc is not compatible with the HI-FI system.
Jan 04, 2010 | Kenwood DV-6050 Multi-disc DVD Player
Sony CDX-565MXRF 10-Disc CD Changer Logo
148 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
