Question about Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer
Lint trap doesnt fit in slot completely evenly
Everything with straps gets caught and breaks costing me a fortune in bras, camis, bathing suits, all baby clothes. help
    President:
  • 2,976 Answers
Remove the trap and look in the hole and see what is keeping it from going in. If the screen is damaged, replace it.
Posted on Jun 04, 2009
    New Friend:
Cleaning out the hole under the lint trap corrected our problem. We were having the worst time with broken straps, etc. Thanks to your answer we were able to fix our problem!! Awesome!
Posted on Jun 26, 2013
Lint trap doesn't sit right in dryer. It sticks up and clothes ge caught on edges., ripping clothes
Take the lint trap out, and look inside the slot where it goes. You will see a lot of built up lint which will have to be removed so you can slide the trap back down to the bottom.
May 05, 2017 | GE Dryers
My maytag 3.5 CU. FT. Front load washer #MHWE251YG won't drain. It keeps giving the error code F9 E1.I checked the drain hose at the back for clogs, cleaned out the drain pump catch, and the pump runs
Hello. You might STILL have a clog! Front load washers are notorious for getting slips, half slips, bras, undergarments, childrens' undergarments, baby socks, coins, keys, WHATEVER, caught between the spin basket and tub. This happens due to the pressure of the clothes pushing these items against the door and they get caught in the small gap between the spin basket and the rubber bellow at the front, getting pulled inside as the basket tumbles or spins. Then, under suction from the drain pump, they can get caught in the hose BEFORE the drain trap stops them. What *I* do is this: Get a bath towel and lay it across the control panel so that it covers the back edge. Pull the washer forward approx 2.5 to 3 feet. Lean it back so that it just rests against the wall(hence the need for the towel to prevent the wall from getting marred up). Any water inside will go back AWAY from the pump. Then you can open the pump and with a flashlight, look inside to see if there is anything stuck. KEEP IN MIND, THE PUMP MIGHT BE DAMAGED AND NOT REALLY SPINNING BUT JUST RATTLING/VIBRATING. I have seen MANY bra underwires cause this. You will have to put your finger in the hole in the side of the tube where the trap fits and spin the impeller. It should have a springy, smooth movement with no "scraping" noise. If you want to dis-assemble the pump, TURN OFF POWER FIRST, take pix as you go and/or draw a diagram for the screw locations. If you are unsure about any of this, call for service. The part number for the complete drain pump is W10130913.
Aug 11, 2015 | Maytag Washing Machines
My Frigidaire front load dryer is ruining my clothes. I can only guess loose straps, strings... get caught on lint trap on door and with the continually spinning o the drum, they eventually break. I...
If you take front of dryer off, there is a half moon shaped piece of felt on top of door opening that most likely has worn and leaves a gap between drum and where that felt is. Replace that for right drum fit.
Sep 11, 2017 | Dryers
Lint filter on LG DLEX2901V sticks up in the corner and catches clothes
Look familiar? LG dryer model DLEX3250W. Lint frame does not fit the slot anymore. NOT BECAUSE OF EXTRA LINT it's because the frame is warping.
Dec 07, 2011 | LG DLEX2901V Dryer
We have had a consistent problem with our dryer. The lint filter eats any staps in the dryer. I have found straps from bras, tops, and belts twisted around the lint filter. They get caught on the edge...
sound like front felt glide assy # upper felt seal part #134440200 lower felt seal #134134700 u can order these from sears.com
these componets support the front of drum and when felt wears away then clothing slips in gap and when dreyer tumbles clothing gets snagged in gap and tears clothing and leaves black scuffs
Jan 31, 2011 | Frigidaire GLEQ2152ES Electric Dryer
The plastic lint filter does not fit properly anymore. Clothes with straps are now being caught and tangled causing the straps to break. My dryer is only about 1 year old.
if the unit not look damage then the filter hosing need to be replace but bout unit can be replace and the parts can bought in sears parts
Jan 02, 2010 | Dryers
The dryer has ruined many of my clothes, straps and tank tops get caught on the lint filter and then twist until they tear apart. how can i fix this?
Purchase a lingere mesh bag.
Put delicate items in the mesh bag (has a nylon zipper) and dry.
Purchase two or three at Target, WalMart, etc.
Oct 06, 2009 | Dryers
Outside lint trap packed and broken
I would remove the outside vent cap, clean everything out and put in a new vent cap. Hope this helps.
Jul 13, 2009 | Dryers
Our dryer lint trap won't go down all the way and is catching our clothes -- ruining spaghettis straps, bras, etc., twisting everything and catching our clothes on the corner of the trap.
It may be backwards. But the first thing I would look for is if there is lint caught in the shute keeping it from going down all the way. If it is a newer model there is a lint screen sensor that may have come unattached and keeping the lint screen from going down all the way. Good luck.
Apr 19, 2009 | Dryers
Maxi Cosi Priori Shoulder strap folded and caught fast!!
Oh yes I have been there!
I am afraid it took me 2 days of brute force. You'll break before the clip does!
I recall using pliers..
Sep 03, 2008 | Maxi-Cosi Priori
Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer Logo
489 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
