Question about Maytag LAT3600A Top Load Washer
My machine stays on what ever program it is on . It does not advance to the next program. Ex: Stays on wash does not advance to spin then to rinse. I can not afford to call a repair man. I pretty handy myself.
  • 211 Answers
The motor within the timer assembly has likely failed. There is a small motor within the timer that advances the control knob onto the next setting. There is an unlikely possibility that one of the wires to the motor has become disconnected, but that's a very remote chance. As far as I know, the timer assembly has to be replaced as a unit, and the motor is not a separate replaceable item.
Posted on Jun 04, 2009
Hi i have an LG 5kg Fuzzy logic top loader and it will wash and fill the water but wont rinse or spin it does not beep or anything it just stops and the time displays stays on the same numbers and i can...
Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
Jan 21, 2011 | Washing Machines
Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 21, 2010 | Kenmore Washing Machines
Kenmore model 110.24642300 will not cycle through wash cycles...will stay stuck in wash cycle until the knob is manually turned to rinse/spint/etc. Would this be a bad knob or timer or both? Thanks!
Start a cycle and remove the knob. If it still stays in agitation mode and won't advance to the spin, then you have a bad timer, or no power to the timer motor(very unlikely). If your washer goes through the cycles with the knob off then you have a bad timer knob. I have seen stripped knobs causing the timer to bind up and not advance. Good Luck Appliance Specialists
Dec 31, 2009 | Washing Machines
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Aug 12, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Washing machine wil not fill - tries several times then stops and all lights except 4 go out
That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
Apr 14, 2009 | Washing Machines
Wash machine stays on wash cycle and doesnt go to rinse or spin
If the water is not getting hot, this will probably stop the programme advancing .Check heater.
Plz rate solution to prob.
Dec 10, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
cheers
Sep 23, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Maytag LAT3600A Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
