Question about Whirlpool GEW9250 Electric Dryer
Automatic setting will not work
When you select any auto dry cycle the selector light will only select quick dry or touch up no matter where the selector is pointing.  Sometimes when you keep pressing the heat setting button it will finally allow you to select an auto cycle.  At this time that does not even help.
  • 2 more comments
  • Anonymous Nov 03, 2007
    selector switch will not pick any automatic cycles. Even on the normal setting, quick dry lights up
  • Bfbear Dec 04, 2007
    Someone told me it could be the user interface board. Are there any techs out there that can address this issue??
  • Downhour Oct 13, 2008
    When I select any of the Auto-Dry settings the light goes on to the touch up. Occassionally, it will allow the auto dry to start, but shortly after the cycle starts, it begins to beep.
  • Anonymous Nov 12, 2008
    It won't go to the accudry settings.
  • 131 Answers
User interface board.
Posted on Mar 10, 2008
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
My frigidaire infinity dryer after 5 minute the cycle stop.
ADD= automatic dry detector this would explain why it stops after 5 min , must be a fault with that
ive had to clean them off inside the drum many times with glass cleaner (nothing stinky) or it will transfer to clothes
mounted just under the lint trap is two shiny steel bars , or some models it's in the back near the center softener sheets come off and coat them up
Apr 21, 2015 | Frigidaire Dryers
Dryer won't start
First, with the door opened, push and release the door switch. Does the light go on and off?
Dec 07, 2012 | GE GTDL200EMWW 27" Front-Load Electric...
I have a Whirlpool electric dryer, it is a Duet with a model # of: GEW9250PW1. When I try to select the the "normal" setting on the automatic side, it lights up the delicate light and has the...
Is the selector knob loose on the stem? Look on the knob to see if there is a set screw of some sort that you can tighten to set it where it belongs, it just seems it's loose and isn't pointing to where it should. Let me know if this works or not,
Please rate and comment, Thank you,
Sep 01, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer will not shut off in any 'auto' mode. Time display ticks down, then jumps up again and keeps running. Dryer does works properly when 'timed dry' is selected. Checked and cleaned exhaust vent. ...
How long is the vent from the dryer to the outside? Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dry-ability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
Jul 14, 2010 | Samsung DV337 Electric Dryer
Whirlpool GGW9250PW Automatic Cycle not working
We are sorry to hear of the problem with your Whirlpool dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at with your name, phone number, address and the model and serial number for your refrigerator.
Apr 04, 2017 | Whirlpool GGW9250PL Gas Dryer
Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Amana model LGA30AW automatic setting doesn't shut the dryer off
You can make adjustments to your Automatic Cycles by adjusting the Factory Dryness Level:
Changing the Automatic Cycle settings to increase or decrease drying time:
If all your loads on all Automatic Cycles are consistently less dry or more dry than you would like, you may change the default settings to increase or decrease the default dryness
Your automatic drying settings can be adjusted to adapt to different installations, environmental conditions, or personal preference. This change is retained and will affect all of your
Automatic Cycles, not just the current cycle/load. There are 5 drying settings, which are displayed using the time display:
0 Much wetter clothes, 30% less drying time.
1 Slightly wetter clothes, 15% less drying time.
2 Factory preset dryness level.
3 Slightly drier clothes, 15% more drying time.
4 Much drier clothes, 30% more drying time.
TO CHANGE THE DRYING SETTINGS: NOTE: The settings cannot be changed while the dryer is running or paused. The dryer must be in standby mode (power is off) to adjust the default settings.
  1. Before starting a cycle, touch and hold DRYNESS for 6 seconds.
  2. Touch DRYNESS to select the dryness level shown in the time display: 0, 1, 2, 3, or 4.
  3. Touch START/PAUSE to save the new dryness level setting.
Oct 05, 2017 | Amana ALG331RAW Gas Dryer
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Whirlpool model # lgr7646ez3
Here are a list of causes that may contribute to this lack of sufficient drying.
• Lint screen is clogged with lint.
• Restricted air movement.
Exhaust vent or outside
exhaust hood is clogged with
• Exhaust vent is crushed or
• One fuse is blown or circuit
breaker is tripped. The dryer
will appear to operate, but you
will not get any heat.
• Cycle Control knob or temperature
selector is set on air dry.
• Load not contacting the sensor
strips and automatic cycle
ending early.
• Fabric softener sheets blocking
exhaust grill.
• Dryer located in room with
temperature below 45ºF (7ºC).
• Large amount of moisture in
the load.
• Cold rinse water used.
• Load too large and bulky to
dry quickly.
Here are the solutions to combat the issues.
• Clean lint screen.
• Run dryer for 5-10 minutes. Hold hand under
outside exhaust hood to check air movement. If you
do not feel air moving, clean exhaust system of lint
or replace exhaust vent with heavy metal or flexible
metal vent.
• Replace with heavy metal or flexible metal vent
• Replace fuse or reset breaker.
• Select the right cycle and temperature for the types
of garments being dried.
• Level dryer.
• Use only one softener sheet per load and only use
it once.
• Move dryer to a location with temperatures above
45ºF (7ºC).
• Expect longer dry times with items that hold more
moisture (cottons).
• Expect longer dry times.
• Separate load to tumble freely.
This will help you fix this problem. i suspect an exhaust obstruction.
Mar 11, 2009 | Whirlpool LGR7646E Dryer
Whirlpool GEW9250 Electric Dryer Logo
144 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
