Question about Intermec EasyCoder F4 Printer
The ink tape return reel won't turn to take up the used ribbon
The ink tape return reel won't turn to take up the used black tape. It feeds the tape but won't fill up the return reel because the return reel won't turn.
You habe to turn from direct printing to transfer mode
Posted on Jun 10, 2009
  • 52 Answers
Try to turn the wheel manually and see if it turns properly. There must be a belt or gear assembly which turns both reels simultaneously. If its a belt, check to see if its broken.
Posted on Jun 04, 2009
My mark xxii ribbon won't turn
either the ribbon is bad or the ribbon feed mechanism needs repair
Dec 30, 2011 | Lexmark Office Equipment & Supplies
How do i replace ink cartridge
Remove the paper scroll from the printer. Turn off the power and make sure the print wheel has stopped moving.
Slide the printer cover toward the back of the machine to remove it. Lift out the old ribbon and replace it with the new one by facing the black side of the ribbon up. Secure one of the reels to its reel shaft, thread the ribbon around the outside of the metal guides, and secure the other reel to the opposite reel shaft.
Tighten any slack ribbon by turning one of the reels
Replace the print cover and reset the paper scroll.
May 02, 2011 | Sharp EL-2615G Calculator
Please can you send me a picture of how to install the ribbon in to the Remington Standard No.12 typewriter. Or tell me how to thread the ribbon.
Hi, first of all there is no picture diagram for this and this method am giving you is what has been used to install ribbon on different typewriters.
  • Remove the existing ribbon. Note the path that the ribbon takes as it goes from one spool to the other.
  • Roll the ribbon entirely on to one of the two reels if your replacement ribbon didn't come with a take-up reel. If your new ribbon has a take-up reel, skip this step.
  • Attach the end of the new ribbon to the take-up reel if your new ribbon doesn't already have one. In most cases, there is a sharp arrow shaped piece on the reel. Use that arrow to penetrate the ribbon and make a few winds of ribbon around the take-up reel.
  • Slip the take-up reel on the take-up spindle on the right side of the typewriter. Align any tabs designed to turn the reel to move the ribbon during typing.
  • Feed the ribbon through the path you noted when removing the old ribbon and place the main ribbon on the spindle. Give the take-up reel a few turns to make sure the ribbon moves freely through the typewriter mechanism.
Jan 18, 2011 | Office Equipment & Supplies
How do I install a new ribbon on the smith corona electra 220 typewriter and where can I find a manual for this?
This is a sensitive installation, i will advice you follow and adhere to the installation instruction from the the manual of you unit, you can search for the manual at manualsonline.com.
Take care.
Oct 23, 2010 | Smith Corona Office Equipment & Supplies
9855 ribbon take up reel not working
When you're sending data to the printer you're sending a command that is telling the printer you're NOT using a ribbon. When the printer receives the data it's shutting off the ribbon. Check your software.
You should be set for THERMAL TRANSFER.(RIBBON)
THERMAL DIRECT Means NO RIBBON
Feb 04, 2009 | Paxar Monarch 9855 Thermal Printer
Correction tape problem IBM Selectric II
Take off the ribbon, just inside the rt. side frame of the printer is the mech. for L/O feeding. There is an arm that moves back and allows the feed to ****, that mech. is probably gummy, lube with some WD40 on both sides of the printer (the left side sets up correction lifting.
DickyO
May 19, 2008 | Lexmark Wheelwriter 15 Series II...
Cassette player problem
Sounds like the take-up reel isn't turning. Often the linkage for the take-up reel is used for both Play and Fast Forward. So test the Fast Forward.
I would look for a broken belt or slipping drive wheel. The fact that the tapes are unraveling tells me that the capstan is pulling the tape out of the feed reel.
Feb 09, 2008 | Audio Players & Recorders
Intermec EasyCoder F4 Printer Logo
289 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
