Question about AMD Athlon , 750 MHz Processor
Can't boot 2nd OS system from partitioned HD.
Partitioned HD has two OS, Windows 7 and XP. Operated fine until update download from Microsoft and now it always goes to C, no message from the BIOS for choice of booting. MoBo is M3N78 PRO. What changes do I make in the BIOS? Switch to OS/2? Unnecessary previously.
  • terrazas198 Jun 04, 2009
    With a new OS I'm reluctant to remove MS's updates. Don't understand how the updates could have affected the BIOS with updates. What does that option in the BIOS do? Won't that put me back to dual boot?
    Genius:
  • 1,605 Answers
Go to add and remove software, deleted the last update from Microsoft. it should put you back to dual boot. try to install the update manually one at a time. find the one that prevent you from dual boot and discard the update. you should be OK w/o ceratin updates.
Posted on Jun 04, 2009
  • Frank
    Frank Jun 04, 2009
    no update will affact the BIOS. only flash BIOS can do that. what the Microsoft update did is to reinstated the boot order.
    removing the updates will not affact any of the OS. the last update has to do .net software and office system. the one prior to this is Vista
    sp1, that may be one that is cause the problem.
    you can always wait for sp2. just becareful how you use the machine in the mean time.
I have a PC with C2D E7200 2.53GHz Processor, 250GB HDD & 2 GB RAM, I HAve 5 Partition on the HDD and i have partitioned it as C: 20.5GB__D: 68.3GB__E: 68.3GB__F: 38.3GB__G: 37.2 GB. On C Partition WIN...
#1 Use windows backup in Windows 7 to create a full system backup of the OS to DVD or a removable drive. (And well as any data on any other partition)
#2 Repartition drive to roughtly 50 50 split
#3 Install XP to partition 1, Install 7 to partition 2 then restore the backup of 7 to partition 2,
Nov 22, 2010 | Microsoft Windows XP Professional With...
I have partitioned my C drive and now have a 2nd
On the setup you need to select the xp partition if its not visible you will need to load additional SATA drivers when the setup asks you to
Mar 21, 2009 | Computers & Internet
Tip
Installing Windows XP
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Every one who owns a computer should maintain it on their own from time to time.
Reinstalling your Operating System is one of the methods of computer maintenance, and is a bit complex.
With these steps, you will successfully install Windows XP into your computer.
These steps are similar to other Windows OS installations (Vista, Windows 7).
Below is the detailed procedure of installing Microsoft Windows XP:
  • Before installing Windows XP or any other operating system, you should backup all your data. Data can be backed up on a separate partition, if the hard disk is partitioned or you can back it up on external storage devices like CDs or on a network.
  • Restart the computer and go to the Setup menu by pressing F2 and change the first boot device to CD, press Esc and save settings.
  • Insert the CD labeled Microsoft Windows XP into the computer and restart the computer.
  • When the pc restarts, a message will appear telling you to press any key to boot from CD, press a key immediately the message appears and the setup process will begin.
  • After the files have been loaded, Windows will start and it will give you an option of repairing using Recovery Console by pressing “R” or continue with setup by pressing “ENTER”; press enter to continue with setup.
  • Setup will list all your disk partitions, highlight the partition where you want to install Windows, this is mainly partition “C”, press “D” to delete the partition, then press “L” to confirm.
  • Highlight the partition you deleted, and then press “C” to create a new partition, press “ENTER” to create the partition.
  • Press “ENTER” again to install Windows on the New (Raw) Partition you have created.
  • Format the partition using NTFS file system.
  • After format has completed, Windows will restart and setup will prompt you to boot from CD again. Ignore the message and let setup continue automatically.
  • Follow the next steps which will ask you to setup the system Time and Date, Network and enter a serial key, until setup finishes.
  • After setup has finished, Windows will restart and will welcome you for the first time; Microsoft Windows XP will have successfully been installed on your computer.
on Jan 07, 2010 | Computers & Internet
Greetings, I need help trying to recover some files on my pc. I had an XP installation working fine on a single hd setup with about 25 gb free space. I tried partitioning the drive (c to free up that empty...
http://pcsupport.about.com/od/findbyerrormessage/a/missinghaldll.htm
It seems like that "free" partition manager, was not free after all. When it's something as important as your HD you should seriously consider anything free as "if this doesn't work, u'll get NO help" type of thing. It sounds like it's trying to boot from the part of the drive that you partitioned and now can't because there is no OS there (or a damaged one). Depending upon how important the folders are u may want to consider professional recovery. Wish I had better news.
Apr 27, 2010 | Microsoft Windows XP Home Edition
Hello, how to install windows xp?
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To install Windows XP, use the following steps.
Jan 08, 2010 | Computers & Internet
I have a Vista machine. I Partitioned my HD for
That laptop is shipped with windows vista and there are no drivers for windows xp in Dell website.
Reason why you cant see HD is very simple because Windows XP don't have drivers for that HD Controller.
Oct 11, 2009 | Dell XPS M1530 Laptop
I have installed Ubantu in my aspire 5050. Now I want to install win XP so that I can open MS Office from Linux
do you want to make a dual-boot system? you must have installed windows OS first and leave a non-partitioned drive in your hard Disk. Then you can install Ubuntu next, instaling it to the non-partitioned drive. When the PC boots, you will be prompted to what OS to boot.
Anyway, you can Install Windows XP in any free Drive. But it is dangerous since Windows Installer might destroy your Ubuntu installation files.
Oct 05, 2009 | Computers & Internet
Windows XP will not pickup my 2nd hard drive (intermittent fault)
most likely it is getting ready to crash, remove your files and replace the HD very quickly.
Rmatheson@wowway.com
Aug 16, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
REMOVING XP MANUALLY
Use a non-destructive partitioning software (like Partition Magic) to remove the partition with the unneeded OS and resize the other partition to use all of the hard-drive. If you still see the other Windows installation listed in the boot options then you can edit the Boot.ini file by following the following guide from Microsoft:
http://support.microsoft.com/kb/289022
Just remove the offending OS from the [operating systems] section and make sure that the installation you are keeping is the one in the default line.
May 12, 2008 | Computers & Internet
2nd HDD installed as slave but still unloaded with software
Simple, if your hardware is working all OK do this:
AND DO THIS CUZ WINDOWS XP HOME EDITION lacks of the needed administrative tools.
Go to the net and find PARTITION MAGIG or PARTITION MANAGER... download the windows version of any of those and partition the HD with them.
REMEMBER:
1. PARTITION MUST BE LOGICAL, NOT PRIMARY
2. PARTITION MUST BE NTFS (Windows XP version) that you will see in Partition Magic options...
3. If you format from Windows, disk must be intitialized as BASIC type.
if you do this and you suceed the HD will work, if not, it has a problem, either logical or physic.
Good Luck
Mar 10, 2008 | Maxtor Hard Drive
AMD Athlon , 750 MHz Processor Logo
234 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
