My laptop already use window vista...but when i'm want to format to window xp,error happen and say no hard drive detect....can u slove my problem....?????
  • 822 Answers
Check data cable and power cables to your hard drives. check also Bios.
Posted on Jun 04, 2009
  • 432 Answers
Either in the bios where you can alter the hard drive settings see if you can see the hard drive mode in IDE mode or disable AHCI.
If that does not resolve the issue then use nlite ( http://www.nliteos.com )
then download the sata drivers for your motherboard and slip stream those with your xp disc and it should be fine
Non-system disk or disk error message appears and does not remove, even when all cd-rom; disks, have been removed.
hi there,
please make sure that there is no USB flashdrive or any other USB device connected to the computer.
If that's cleared and the same error happens please try to reseat the hard drive because chances are it is not detected by your computer. (you would have to unscrew a small cover from the back of the laptop and take the hard drive off and put it back in)
If that does not work try going to the BIOS and check if the computer detects the hard drive if not and you've already reseated the hard drive then it means that your hard drive has gone bad and it needs to be replaced.
If it detects the hard drive then try booting from a windows cd If you're using windows 7 or Vista go to Windows Recovery Environment or if you're using XP go to the recovery console.
Once you're on the command prompt issue a chkdsk /r or fixmbr command.
If that still does not work, you might have to reinstall Windows on your computer.
Hope this helps!
Jun 28, 2011 | HEWLETT-PACKARD ProBook 6550b XA673AW...
I have problem to install window xp in my laptop, which already have window vista....my notebook donot support to install xp..please tell is there any way to install xp...
What is your problem specifically? Is it that there is no hard disk detected when you try to install windows xp?
Try using third party software to detect the hard disk on your laptop
Try this link. It will basically give you your hard drive driver while installing windows xp. You will also need an external floppy disk drive if you dont have diskette drive in your laptop.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-70477
Jan 24, 2010 | Computers & Internet
I have a Dell-Inspiron Laptop 1526 I had my hard drive replace by Dell once this year already, when I turn on the computer it starts to work and then stop Running Vista my warranty was up Sept 3 2009 like...
Your trying to downgrade this means you have to use vista cd to format the hard driver, and after the laptop restart, load the Xp. Also sometimes this code comes if you donot use the original xp windows.
Thanks for using Fixy
Oct 12, 2009 | Dell Inspiron 1150 Notebook
Installation for xp problem
all the hardware on the laptop is most likely configured for windows vista meaning it will not allow xp to load up because your hardware cant run it
Oct 09, 2009 | Compaq Presario Notebook
Install windows XP
You sure your HD isn't bad? You could try a low-level format and then try to install, I am assuming you don't mind loosing any data already on the disk.
Sep 09, 2009 | Computers & Internet
I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
May 04, 2009 | Compaq Evo N610C Notebook
WINDOWS XP SERVICE PACK 2
try to change HDD to IDE from ACHI in BIOS, then you can normal install xp. if there are no this option in BIOS, then you have to make a installation CD included ICH 7M driver to install.
Feb 17, 2009 | Computers & Internet
Format vista to xp
you need to format first your hard drive...
Jul 11, 2008 | Dell Latitude D600 Notebook
Help to install xp windows sp2 instead vista please
Boot to the XP CD and format the hard drive. You will loose all info that has not been backed up on the drive.After the format, it will continue to loan windows XP. Make sure you have the product code before doing this.
Apr 28, 2008 | Toshiba Satellite A205-S4777 Notebook
How to install XP in toshiba Satellite L45-S7423 laptop
I found it!!!>>>
Just go to Toshiba support web site Download the Storage Manager Driver for XP 32 then have an External floppy drive with formatted Disk ,install the drivers Files in the floppy connect the floppy drive put the XP sys CD Boot from the CD as in Solution #1 or by press on F12 tell choices boot screen popup select the CD then after that when the third party appear press F6 to chose the Driver for HDD to get recognized by the system. J
Mar 27, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
