Question about PANDIGITAL 7-Inch Digital Photo Frame with 2 Interchangeable Frames (DPF701) Digital Picture Frame
PhotoShare 7D picture frame will not come on.
PhotoShare 7D picture frame will not turn on. The unit was working fine until we pulled the SD card in order to update the pictures. Now we can't get it to power up.
5 Suggested Answers
  • 6 Answers
SOURCE: SEQUENCING PICTURES IN BUILT-IN MEMORY
The DPF-80 has now way to sequence pics. The only way for them to play in an order is add them one at a time to the frame via the computer. The files can not be batch sent, such as sending a whole folder at one time. Windows will dictate the order in which they are transfered if you do it that way. Transfer one pic at a time. Tedious, but it works
Posted on Dec 11, 2008
  • 6 Answers
SOURCE: Unable to operate remote of Pandigital picture frame
remove the memory card and see if the remote works wit hthe built in memory pics. if it doesnt pic up your card you will just have to try another card. The frames dont read cards larger than 1 Gb very well either - reguardless of how many pics are on the card.
robmcd27
  • 423 Answers
SOURCE: Need to load pictures from panditigal frame to flash drive.
Hi Doug, I'm sorry, but your pictures are stuck on the picture frame. There is no software on the unit to move them out.
Posted on Feb 21, 2009
karan4aaki
  • 68 Answers
SOURCE: Picture Frame will not turn on. Put new batteries in.
If you are not able to find your connecting cable. and i am assuming your need is to transfer the data to comp. Well what you can do is you can take out the memory card and fix it into the card reader (you will get a card reader vey cheap anywhere.). and connect it to your comp. Now your card will work as a flash drive and you can transfer data easily then... Hope this helps you out.. :)
Posted on Mar 10, 2009
Why are there question marks where my photos should be on my photoshare 7d?
Because either the card or the internal memory are corrupted.
Jan 13, 2018 | Cameras
I need an instruction leaflet - I've forgotten how it works and how to put new pictures on it.
Hi, most of this type picture frame require an S.D. card usually the large type . There are some that are the large sd card but you can insert a small sd card into the large one . If you have a large sd card in your camera then all you have to do is insert it in the picture frame. If you have a pc you can transfer your pictures to a separate sd card and use that just for the picture frame . If you have pictures on your phone you will have to transfer them to a pc then put your sd card from your picture frame into the pc and transfer to the sd card from the picture frame.
Feb 25, 2016 | Photography
Hello. Pls I bought this OMNITECH digital photo frame in 2008 and it was working fine until I disconnect and kept it somewhere for my living room and kitchen renovations for 6 months but now the works
There should be a small hole on the back of the unit, use a pin or a needle to reset the software but be sure to remove your sd card first otherwise it could wipe all of your pictures, once this is done be sure to give it a full charge while switched off, when it has fully charged (16+Hrs) switch it on and insert your sd card, If this does not fix it then I am sorry but I know of no other fixes
Nov 11, 2014 | Photography
My 10" digital not working it comes on but not reponding the icon dont come up its not doing anything please help
hi
try to see if you have a reset hole in the back or sides if not then try to reconect the battary or to empty the battary .
May 17, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
Help w/ quantaray 10.4 digital picture frame
pls backup ur data & reformat ur sd card to fat 32 using ur pc
Jan 05, 2014 | Quantaray Photography
I am looking for the manual for the Photoco PhotoShare 7D digital picture frame.
The manufacturer's website is under construction; at some point in the future you may be able to download a manual from here:
http://www.photo-co.com/
In the meantime, seaches suggest it is possible your manual is available from one of the pay download sites. You will have to decide whether you want to pay and join one of these sites.
Dec 25, 2010 | Computers & Internet
I have a photoco photoshare 7d and i can't figure out how to make to slide show work with an sd card. Also my computer won't communicate with it when hooked up with an usb cable.
Load the pictures off the media card. Choose a picture, this mode leaves that picture on permanently. At this point hold down the menu button and the picture will change slides. It will continue to change slides after that at your chosen slide interval time :) Can't help you with the USB connection though.
Oct 10, 2009 | Cameras
PhotoShare 7D won't turn on
We can only help with the technical issues, not your emotional distress. If, as you say, the item was bought in Iraq, then it is likely that there are voltage supply differences between the country of sale and wherever you are now.
Apr 25, 2017 | PANDIGITAL 7-Inch Digital Photo Frame with...
Nextar N7-202 digital photo frame
I had the same problem and called Nextar Support. The gal I spoke with asked how big my SD card was and informed me that the capacity for this frame is only 2 GB. Sure enough, my card was 4 GB. I transferred the pictures to a 2 GB card and it works great! (Note to Nextar: might be nice if they put this somewhere in the paperwork BEFORE people buy an SD card.)
Dec 22, 2008 | Nextar N7 - 7 Digital Photo Frame with...
7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
Dec 29, 2007 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
PANDIGITAL 7-Inch Digital Photo Frame with 2 Interchangeable Frames (DPF701) Digital Picture Frame Logo
266 people viewed this question
Top PANDIGITAL Photography Experts
LP
Bill Eager
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
