Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
I have a Whirlpool sxs refrigerator not staying cool enough
I have a Whirlpool side by side refrigerator (GD25DFXN02) that is running but it's not cold enough. It would cool down for awhile but then lose it's cooling temp. There isn't any loud noises coming from the compressor, cleaned the coils underneath, unplugged the fridge to see if it needed to defrost (no water pooling), fans appear to be working. But, I did hear a faint clicking noise on the refrigerator side where the controls on the top are. Can anyone help? This fridge has given us no other problems in the 9-10 years we have had it.
  • 1462 Answers
SOURCE: Whirlpool side by side Refrigerator not cooling, two -- where -18 temp used to be.
the fact the bowl was filled with water and that you said the inside of the freezer was coated with ice, indicates a failure of the defrost system.
now the ice has gone, reset the temps and wait to see what happens
Posted on Oct 15, 2008
  • 22 Answers
SOURCE: kenmore model 88892 sxs refrigerator started to
There is a tray that is in the bottom, remove the cover thats located just under the doors in front. You will see it most of time black in color and it will be easy to pull out be careful for it will be full. Its from condensation most the time in the summer this happens really no problem. if thats not it check the ice maker water supply line that could be it also.
Posted on Aug 09, 2009
  • 1218 Answers
SOURCE: Have a whirlpool side by side refriferator estate
Plastic box you're referring to contains the start components for the compressor. The clicking sound sound you hear is the protective overload shutting the compressor off because it won't start.
Two possibilities
1. The components inside the plastic box (cover) are defective and need replaced. You can remove them, by snapping off the cover and pulling them straight off. Most appliance parts houses will be happy to test them.
2. The compressor has failed internally.
Note: In my personal experience when dealing with whirlpool Estate models, 99% of the time it has been a failed compressor.
Posted on Oct 28, 2009
dmftrucker
  • 1922 Answers
SOURCE: Whirlpool refrigerator side by side freezer won't freeze
your over-load/contactor is defective, un plug it from compressor and shake it if it rattles its bad
Posted on Nov 02, 2009
aasc
  • 1606 Answers
SOURCE: Where is defrost timer in maytag MSD2756GEQ SxS
Inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control
Posted on Jun 13, 2010
Whirlpool ref. panel light will not stay on. how do I make it stay on
Sounds like a machine operating ok. Buy a nightlight or contact the manufacturer for a user manual.
Jun 01, 2015 | Whirlpool ED5FHEXVS - Ref Sxs 25 - Sxs...
Water at the bottom of the refrigerator side
Without knowing the model I assume you are talking about a SXS. If you have water on this side it may be coming from the water reservoir if you have a water dispenser on the freezer door. Some SXS refrigerators have a quick cool compartment and these usually have a small refrigerator coil that can build up with ice and if the drain is blocked water can run under the crispers.
Aug 13, 2014 | Refrigerators
I have the whirlpool conquest GS6SHA and it is not staying cold enough and the freezer is not defrosting properly
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 13, 2011 | Whirlpool Refrigerators
ED5JHEXTQ00 Whirlpool SxS fridge not cooling below 45 deg F on either side. I got a start relay from the local Whirlpool parts shop but it's even close to what is on the unit. Took the existing one...
well if the comp. is running long enough and it is not cooling then u might be low on freon. if so then u have a leak in the system. thats bad. but it could be also the comp . picked up something and u have a obstruction, and thats not good either.. ok. later gator
Feb 17, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Lg sxs fridge not getting cold
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 16, 2010 | LG LSC26905TT Side by Side Refrigerator
Compreser not coming on
I've had to replace many compressor start relays on 5-10 year old whirlpool SxS refrigerators. If the fan next to it is running but comp is not, that would be my first guess. does it humm then "click" ?
Jun 11, 2009 | Whirlpool ED2FHGX Side by Side...
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH
You need to look inside the freezer at the rear wall cover and see if it is frosted over. If your refrigerator is not defrosting that can cause the refrigerator side and the freezer side also not to cool to the desired temp.
Mar 30, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Heat strip is to hot on freezer door frame whirlpool frige sxs.....
Two things can cause this:
1. Dirty coils.
2. Bad condensor fan motor (this cools the coils). The fan motor can be accessed from the back by removing the lower panel.
Dec 03, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE sxs defrost problem
How long does it take for the frost to build up, improper placement of the bi-metal will cause a defrost issue by not letting the heater stay on long enough.
Let me know how you make out.
Thanks,
Bill
Apr 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
277 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
