How do you adjust tracking on a dvd player? Also
How do you adjust tracking on a dvd player? Also playing in B&W not color.
  • 134 Answers
SOURCE: My DVD player is playing only black & white,
see if you television works fine. if yes, check the wires of the player see if they're connected properly.if the video is still in black and white.
Posted on Mar 05, 2010
SOURCE: Sony DVD player color adjustment (Model #DVP-N5400D)
Solved the problem!Well, After reading two manuals on the Sony DVD player, I saw one cable not connected: the S Video connection. I connected that. Tried it out again, seemed a little better, but still not the full range of reds. At that point I thought the problem was either: 1) the cables from the DVD player to the TV or 2) the DVD player is the problem So, I thought I'd start with replacing the cables. Labeled them as to where they went, took them out and went to Radio Shack and explained my problem. The clerk I spoke to was very nice, said he had seen this problem before, and said there was a menu on the DVD for adjusting RGB settings.
So, I went back home, plugged in the cable, and went all thru the 2 Sony DVD booklets and the display menu on the TV. There was nothing mentioned re: color settings. Went thru the DVD menu many times, looking, looking. I felt I had come up with nothing.
Turned everything off. Turned back on. Put in a DVD: It looks great! :)
So, hoping it never happens again..cause I'm not sure I can repeat it! Maybe it was removing all the cables from their sockets and restarting...I know that sometimes works with computers...anyway.. At least I didn't have to buy a new DVD! Lesson: unplug, re:plug...before you trash it!
M~
Posted on Mar 07, 2008
Grubhead
  • 5449 Answers
SOURCE: I have a GBV441 DVD/VCR player which is shaky and
I think the DVD player might either be set to output RGB, or if you are watching it via a scart to TV, and the TV is not RGB type. Alternative the TV is an RGB type and your player needs switching to RGB output.
Posted on Jun 20, 2009
SOURCE: Panasonic DVD-RV31 DVD Player plays black & white only (no color)
Hi,make sure your tv channel says av2 and not av2s as this will play in b/w,hope this helps
Posted on Jul 11, 2009
SOURCE: my dvd player does not play in color only black
don´t you by mistake change the video format check that on the menu
Posted on Oct 06, 2009
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) - Amazon.com
www.amazon.com/Onkyo...Player-Black/.../B001AMS...
Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
Have a Toshiba RDXV60KB. Will play some prerecorded vhs vids but not others. It's as is the tracking is out. Can I manually adjust the tracking or is it back to the repairers.
Many if the unit has a vol or channel buttons those will when in play become manual tracking adjustments, it depends if they are there or not.
Dec 07, 2012 | Toshiba DVR660 DVD Recorder/VCR
Is there a way to adjust tracking for VCR play?
try this , while playing the tape , press ch+ & ch- both at the same time and watch the screen to see if it works , AJ
Nov 12, 2009 | Toshiba SD-34VB DVD Player / VCR Combo
My player only plays in black and white. why
Check all your buttons on your machine. There should be a color adjustment knob located on it, where you can have anywhere from sharp color right to black and white. Adjust your color until it comes in with the prefered color you want.
Sep 01, 2009 | Durabrand DVD-1002 DVD Player
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Sumsung DVD-V2000
This unit needs its tracking circuits aligned, starting with the mechanical adjustments of the transport....accordianman
Sep 11, 2008 | Samsung DVD-V2000 DVD Player/VCR
DVD - S520 Player stuck on initialize
please check you TV color system. you are not using the right color frequency. if your TV has got an auto color region select then set it to auto. otherwise, select the TV color mode until you get the right color frequency
Jun 03, 2008 | Yamaha DVD-S520 DVD Player
Color problem
CONNECT YOUR DVD PLAYER TO SOME OTHER TV .IF THE COLORS ARE OK ,THEN YOUR TV IS AT FAULT .
THE COLORS OF YOUR TV CAN EASILY BE RE ADJUSTED BY A TV SERVICE MAN.
THE CORRECT RATIO OF RED ,GREEN ,BLUE NEEDS TO BE ADJUSTED .
Jun 02, 2008 | Sanyo DVW-6000 DVD Player/VCR
Televison & Video Logo
605 people viewed this question
Top Televison & Video Experts
