It no longer sends signals to speakers and the speakers work fine with other radios.
  • Jim Sykes Jun 04, 2009
    My TX-V940 AV Tuner/Amplifier has worked fine for a number of years. Recently it stopped sending anything to the speakers. I substituted another Tuner and it works well with the speakers. I assume a part within the TX-V940 has gone bad and needs to be replaced. How do we go about testing to identify the part and then replace it.
    Thanks for the response. Please give me directions on how to test the "protection circuit" as you have requested.
  • 10,515 Answers
It's possible that the protection circuit has failed.
Check and let me know.
Thanks.
Posted on Jun 04, 2009
    Sergeant:
  • 296 Answers
"Dspng" what does this mean it comes on when i turn on my jvc receiver. I have no sound from my speakers used the same speakers on a different radio and they worked fine Rx6040 is no longer good
This could be a message indicating that the digital signal processor is defective or that digital signal processing has failed. In either event, it is likely that your JVC receiver is not working correctly.
Jul 17, 2016 | JVC Audio Players & Recorders
Kenwood TK-3131 15-channel radio. I purchased a couple of these about a month ago and try worked fine. Turned them on recently and now one doesn't function as it should...it sends a signal when the mic...
By checking initially of your radio,insert your NEW FULLY CHARGE BATTERY,Switch On your radio,select the channel the same as your other working radio,and try it once more,
If you can not heard an alert sounds when you turn on the radio, and pressing any Button/key,probably you'll having a problem on the audio circuits/speaker,etc, if it is working before,
Thank you
Jan 30, 2013 | Radio Communications
My 1988 caprice has a power antenna which is not working and is stuck all the way out and up. The radio does not work. It shows the clock but it wont turn on at all. is this a fuse? I checked it and it...
well. if your radio doesnt turn on then it cant send a signal to retract the antenna. if the fuses are ok pull the radio out and check the power and ground wires. if they are ok just buy a new radio and have it professionaly installed.
Jan 29, 2011 | Car Audio & Video
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
Jan 07, 2011 | LG Audio Players & Recorders
Speakers have played intermintintly for several
you need to find out if your vech has an amp or not call your dealer and give them the vin# adn they can ck to see if the truck was built with or with out an amp.If the truck has an amp the radio sends low level signals to the amp then the amp amplifies them and sends the signals to the speakers. so if the amp is bad and you replace the radio it still will not sent the signals to the speakers.
Feb 25, 2010 | 2001 Chevrolet Suburban
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
Great signal, so sound
My XM Boombox is also white and it is a Belkin. The folks at Delphi told me the receiver in the boombox is screwed up which over time also screws up the Delphi receiver. Belkin is sending me a new boombox and Delphi is sending me a new Roady XT.
Mar 01, 2008 | Delphi Roady XT XM Radio Receiver
AM/SW no longer functioning - FM still works fine
If it can fixed at a reasonable price, it might be better to try to have it repaired.
Hope it helps.
Sep 15, 2007 | Grundig G4000A FM/AM Radio
External Speaker Not Working
Why dont you claim warranty I think is a factory fault, the internal speaker is not working.
Jul 24, 2007 | OmniZel LC22WT 2-Way Radio
 Grubhead
Grubhead
