Question about Kenmore Elite 45986 Front Load Washer
Kenmore 49962 Thinking of buying kenmore 49962 H3T which I think is the same as Whrlpool Duet wfw9490w. I have read there are problems with electronics but they have been fixed. Is this a reliable washer?
5 Suggested Answers
wheelshot
  • 102 Answers
SOURCE: After I paused my Kenmore H3t washer to add clothes, it will not
sounds like you may have a bad door switch or the door latch on the door is broken
Posted on Apr 03, 2009
  • 136 Answers
SOURCE: kenmore elite 49962 washer error code f30
hi sir, please check the following link. it tells about cause of the problem[Error Code F30]. http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
kindly rate me.. thanks for using fixya..
Posted on Feb 11, 2010
marka19
  • 1430 Answers
SOURCE: I have a kenmore elite
If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked
Check the drain pump filter for debris
If all the above checks out good . This would indicate that the pressure switch or also called the analog pressure sensor has failed. First you will need to remove the top lid. Usually 2 or 3 screws on the back and the top comes right off. The pressure switch has a clear hose and a clump of wires going to it. Then unplug the hose and blow thru it it should be clear. Check the hose for leaks or obstructions. Also in the back of the washer on the left hand side is a air dome this is where it gets it pressure reading from, make sure it is not obstructed. If all is clear the pressure switch will need to be replaced. Here is a link to help with accessing the pressure switch also if you need diagrams or illustrations of your particular model.
Posted on Oct 07, 2010
Macmarkus
  • 2605 Answers
SOURCE: My Kenmore H3T washer will not start. When a
Hello, welcome to FixYa.
I will start by saying your post indicates it is a Kenmore washer, however if you could post the complete model number and the approximate age I can speak directly about your's instead of generalizing.
Hopefully you can appreciate there are many differences even within the Kenmore brand. On most the flashing light error indicates a "door open" scenario has occurred, (obviously it isn;t...right ?) but I'll need to clarify the model number before detailing much of course. I'll watch for your reply before moving forward.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Posted on Jun 02, 2011
What do it means when the code is F/24
google it or look ion whrlpool .com it also sais it i nthe nmanual ???
Apr 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code E1 on Kenmore dryer
The electronic control detected the thermistor is open. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then if it reads open or the harness of broken. Refer to the detailed troubleshooting of this error code in the link provided below.
Troubleshooting of Error Code E1 on Kenmore Elite and Whirlpool Duet Dryers
Oct 08, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite 49962 washer error code f30
Feb 11, 2010 | Kenmore 49972 Front Load Washer
I am thinking about buying a 2003 kenmore elite washer and dryer for $500. they are a HE3t. are there any problems I should be aware of with this year and model.
No unusual problems. Keep it maintained properly - and you have a great washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 15, 2009 | Kenmore Elite 45986 Front Load Washer
Apr 02, 2009 | Kenmore Washing Machines
Kenmore elite HE3 front loader door cracking and broken latch problem
there around 300.00 1 ideal to share buy service smart agreement from sears all parts &labor will be covered up to 500.00 i have warranty it payed off big time
Nov 02, 2008 | Kenmore Elite 45986 Front Load Washer
Reading 4Gb micro card in targus TGR-CRD25 25-in-1 card reader
This is already a really old card reader which is not capable to read HC (High Capacity) memory cards. DO, the 2GB are the largest it can read.
Card readers are inexpensive today, please buy an up to date one which can read SD as well as SDHC and SDXC card types.
See also the same question from year 2007 here:
https://www.dpreview.com/forums/thread/1957326
May 29, 2017 | Electronics - Others
KENMORE H3T WASHER GREY TWISTED FRONT SEAL
I am currently replacing this bellow because of holes and five years of wear and tear. The bellow is attached to the front door assembly via a spring loaded clamp. This clamp is a solid large wire ring with loops on each end where the spring attaches. You do not have to remove the spring, just place a screwdriver between the bellow and the ring or spring to remove. This will allow you to take off the bellow from the lip of the front door assembly to reposition. The spring clamp goes on starting first from opposite of the spring and working in both directions a little at a time. ALL DONE.
Dec 20, 2006 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
380 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
