Question about T-Mobile Wing™ Smartphone
The device will not turn off. Power button is not working.No problems with the other functions. I turned it off last night and plugged it in to recharge, and this morning the device was on and I haven't been able to turn it off.
I took the back off and removed the battery--found water inside. I dried everything off, then let everything air dry for a while. A few hours later, the phone was fine.
Posted on Jun 08, 2009
My iphone 5c stopped working suddenly, its screen darkened and it does not work. What is the problem?
Reset the phone:
  • Plug the charger into the phone.
  • Hold down the Home button while holding down the On/Off button.
  • Continue holding these down until (hopefully) the Apple displays on the screen.
Mar 08, 2015 | iPhone 5c Cell Phones
My plmv169dcd stopped working,looks like it has no power, but there is power at plug in. is there a reset button>
Not quite enough information. But, there is no reset button. Open unit check fuse. test all 3 door switches. They are the number one cause of problems and can take out the fuse or not. Other than that it will take more trouble shooting to find the problem
Dec 03, 2014 | Electrolux Frigidaire Professional Series...
Ipad won't turn on. Worked fine last night, got down to about 5% battery left. Plugged in overnight and it won't turn on. Tried different power cables, no success. Tried plugging into PC no luck. ...
You could try a hard reset.
Hold down the power button and the home button at the same time until the device completely shuts down and the Apple logo appears.
Hope that helps!
Sep 24, 2013 | Apple iPad (16 GB) WiFi Tablet PC
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
I shut down my Dell Dimension E510 last night and today when I pressed the on button, the computer wont turn on - not even an orange light on the power button. I tried disconnecting all connected...
Try this procedure! click here. After checking your power supply and it is working fine, put it back again into your computer casing. Next thing to do is to check your motherboard switch (power on). Look for the manual of your motherboard and look for the power on switch. If you find it then get a screw driver and short the pin using the screw driver. Be careful not to touch the other pin! But you have to check all the computer components to determine what is exactly the cause why it's not functioning. If it's not turning on your computer while you short the power switch on that means probably your motherboard fail. Other option is, in order to troubleshoot the problem of your computer you must have an extra computer with the same model and plug all your components there one by one to determine what is exactly the problem of your computer. Then you can decide what computer parts need to be replace. Have a nice day!
Dec 23, 2010 | Dell Dimension E510 PC Desktop
Mitsubishi WD-52525 was working fine and now it will not turn on
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Tom tom wont turn on.
turn device over and look for tiny reset button near to power connect strip. then use a blunt safety pin to reset,this should allow you to then turn it on,this works on 500 ,700 ,900 , 510 , 710 , 910 , hope this helps .
Jun 06, 2009 | GPS
Wont come on
Instead of just unplugging the TV, perform a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV still won't turn on, then it appears something is wrong with it's mainboard since the TV is still receiving power because the standby light is still coming on.  The cost of fixing an older TV's mainboard could be costly or impossible if the part is discontinued.
Mar 25, 2009 | Beko 324250WN 28" TV
Startup problems
check your keyboard connection (unplug and plug again). If not works try another of same type.
Dec 24, 2007 | HP Compaq Presario V2000 Notebook
T-Mobile Wing™ Smartphone Logo
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
